benefits of cnc engine machining?
#837272
10/24/10 04:47 AM
10/24/10 04:47 AM
Posts: 2,091 Delray beach, Florida
Performance Only
i thought i'd throw a few video's together to share with you. here's one that involves probing the cylinder bores to blueprint them to the proper location and angle to the crankshaft. it's pretty easy to imagine the benefits of having the bore spacing and 45 degree angle correct. i need to finish the video's of bushing lifter bores, correcting angles, location, sizing, etc. it's amazing how far off some of the blocks are that we've done. ley me know if you'd like to see more. http://www.youtube.com/watch?v=kpya5RpLWR0http://www.youtube.com/watch?v=-ZmTQQuQT8w
machine shop owner and engine builder
Re: benefits of cnc engine machining?
[Re: Performance Only]
#837277
10/24/10 10:11 AM
10/24/10 10:11 AM
Posts: 2,175 Duloc
The Shadow
Duloc
I know this may be a stupid question but, how does probing the bores ensure you machine them in the correct location if they have been bored in the wrong location in the first place?
[Re: JBurch]
#837278
10/24/10 11:00 AM
10/24/10 11:00 AM
Posts: 3,401 Pa
Hot 340
Pa
How come no coolant? A .125 cut is a hefty bite, I'm sure some heat was generated.
Not really, cast iron cuts like butter, USUALLY. OP, I think you are overthinking things, that probe wasnt cheap, and doesnt do more than standard edge finding (unless you like measuring from hole to hole- quickly,). But hey, knock yourself out.
#837280
10/24/10 12:44 PM
10/24/10 12:44 PM
Posts: 3,401 Pa
Hot 340
Pa
the probe measures the size of the hole and its location in relationship to the factory blueprint specs. if the holes are in the wrong location, which is common to some degree, the boring head can correct them as long as they aren't out of place more than the amount of material to be removed. the machine will allow you to bore at the indicated location, or at the blueprint location or anywhere in between.
Terry, i'm not sure why you think the probe is "just" an edge finder.
On THAT machine it is.
[Re: Hot 340]
#837281
10/24/10 01:05 PM
10/24/10 01:05 PM
Performance Only
since we're using that probe to help map out and write other programs with some pretty intricate shapes, it's clearly not an edgefinder only as you think. perhaps your just not aware of what it's capable of with the new software.
#837282
10/24/10 02:17 PM
10/24/10 02:17 PM
Posts: 3,511 DFW
mr_340
DFW
What is the reference point to start machining? The BHJ Blok-Tru fixtures locate off the main and cam bores. I'm not entirely convinced that the cam bore is a good reference point if there was core shift on the block or the original machining was off. I've been thinking about the best method of locating the block to machine it. Would you sonic check the bores to see if they need shifted and then remachine everything else to match those locations? I'm sure almost everyone starts off the main bores, but who's to say they were put in correctly to start? I'm probably thinking too much about it, just thinking out loud here.
What sort of software are you using with the probe?
Floyd Lippencott IV
#837283
10/24/10 02:23 PM
10/24/10 02:23 PM
Posts: 7,506 Az
Crizila
Az
Fell asleep on the 3rd hole. I like the concept - showing your shops / machine capabilities and education of clients, but I think most could get the idea ( with some dialog ) on just one hole.
Fastest 300
[Re: Crizila]
#837284
10/24/10 02:43 PM
10/24/10 02:43 PM
Posts: 3,401 Pa
Hot 340
Pa
x2, i like threads like this... show us more.
[Re: mr_340]
#837285
10/24/10 02:45 PM
10/24/10 02:45 PM
Posts: 3,401 Pa
Hot 340
Pa
Starting point now would probably be the head dowels. But I wouldnt move much if everything soniced ok on pass car stuff.
[Re: Hot 340]
#837286
10/24/10 03:16 PM
10/24/10 03:16 PM
Posts: 644 Owego, NY
JBurch
Owego, NY
The operative word here is "USUALLY".
Was it cast from virgin iron, or recycled scrap with carburizer thrown in to come up with a grade 30 iron. What's the Nickel content? Hemi block, I would guess that qualifies as a high Nickel block; it's not gonna machine like a soft chevy block. And you are correct .125in is not a real serious cut, I was thinking that coolant would hold the part thermally stable, and improve tool life, thus improving finished product. Why measure to 5 decimal places, repeat to 4, and have thermal instability take the benefits away at 3?
Just my
[Re: JBurch]
#837287
10/24/10 03:22 PM
10/24/10 03:22 PM
Posts: 3,547 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Boring is done to within .004-.005, then the final ( hopefully 2 step) finish honing is done, which then allows you to take into account the thermal changes in the blocks/cylinders, as you go from end to end, side to side to let the adjacent cylinders cool. Most often you will do the honing, let sit overnight, then touch hone next day with no heat.This is where your 4th digit comes into play.
RIP Monte Smith
[Re: JBurch]
#837288
10/24/10 03:59 PM
10/24/10 03:59 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
We just machined first XR2 Block couple weeks ago, & definitely can tell the iron they are using is not near the quality of an R3 race block. XR had hard spots in it that was tearing up cutters & end mills.
#837289
10/24/10 05:55 PM
10/24/10 05:55 PM
Posts: 2,503 Illinois
CRE2004
super gas
super gas
Illinois
Absolutely! Looking good Dan! We have the same machine minus the 4th axis. The probe's reference point is whatever you set it up to be. Primarily, you want to set the bores up to use the crank centerline as the reference and correct the bores back onto the crank centerline. The bore spacing is also corrected if off. For lifter bushings, you can reference off the front thrust face. Correcting the lifter bores is crucial on any block. By doing so, it keeps the valve events the same between cylinders. Why buy a fancy CNC ground cam and put it a 40year old machined block
