benefits of cnc engine machining? #837272
10/24/10 04:47 AM
10/24/10 04:47 AM
Delray beach, Florida
P
Performance Only Offline OP
P
i thought i'd throw a few video's together to share with you.
here's one that involves probing the cylinder bores to blueprint them to the proper location and angle to the crankshaft. it's pretty easy to imagine the benefits of having the bore spacing and 45 degree angle correct.
i need to finish the video's of bushing lifter bores, correcting angles, location, sizing, etc. it's amazing how far off some of the blocks are that we've done.
ley me know if you'd like to see more.
http://www.youtube.com/watch?v=kpya5RpLWR0
http://www.youtube.com/watch?v=-ZmTQQuQT8w
machine shop owner and engine builder
Re: benefits of cnc engine machining? [Re: Performance Only] #837273
10/24/10 09:01 AM
10/24/10 09:01 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
How about some closeup vids?
I cant see anything happening.
Re: benefits of cnc engine machining? [Re: Performance Only] #837274
10/24/10 09:10 AM
10/24/10 09:10 AM
Q
Quicktree Offline
Quicktree  Offline
Q
thats a nasty ole big block
Re: benefits of cnc engine machining? [Re: Performance Only] #837275
10/24/10 09:26 AM
10/24/10 09:26 AM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
How come no coolant? A .125 cut is a hefty bite, I'm sure some heat was generated.
Re: benefits of cnc engine machining? [Re: Performance Only] #837276
10/24/10 09:50 AM
10/24/10 09:50 AM
NC
440Jim Offline
440Jim  Offline
NC
And a good CNC block lightening program can be helpful on some aftermarket iron blocks. The machine time is expensive, but you don't have to pay an operator to do it for many hours, just let the machine cut !
Re: benefits of cnc engine machining? [Re: Performance Only] #837277
10/24/10 10:11 AM
10/24/10 10:11 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I know this may be a stupid question but, how does probing the bores ensure you machine them in the correct location if they have been bored in the wrong location in the first place?
Re: benefits of cnc engine machining? [Re: JBurch] #837278
10/24/10 11:00 AM
10/24/10 11:00 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Not really, cast iron cuts like butter, USUALLY. OP, I think you are overthinking things, that probe wasnt cheap, and doesnt do more than standard edge finding (unless you like measuring from hole to hole- quickly,). But hey, knock yourself out.
Re: benefits of cnc engine machining? [Re: The Shadow] #837279
10/24/10 12:27 PM
10/24/10 12:27 PM
P
P
the probe measures the size of the hole and its location in relationship to the factory blueprint specs. if the holes are in the wrong location, which is common to some degree, the boring head can correct them as long as they aren't out of place more than the amount of material to be removed.
the machine will allow you to bore at the indicated location, or at the blueprint location or anywhere in between.
Terry, i'm not sure why you think the probe is "just" an edge finder.
Re: benefits of cnc engine machining? [Re: Performance Only] #837280
10/24/10 12:44 PM
10/24/10 12:44 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
On THAT machine it is.
Re: benefits of cnc engine machining? [Re: Hot 340] #837281
10/24/10 01:05 PM
10/24/10 01:05 PM
P
P
since we're using that probe to help map out and write other programs with some pretty intricate shapes, it's clearly not an edgefinder only as you think. perhaps your just not aware of what it's capable of with the new software.
Re: benefits of cnc engine machining? [Re: Performance Only] #837282
10/24/10 02:17 PM
10/24/10 02:17 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
What is the reference point to start machining? The BHJ Blok-Tru fixtures locate off the main and cam bores. I'm not entirely convinced that the cam bore is a good reference point if there was core shift on the block or the original machining was off. I've been thinking about the best method of locating the block to machine it. Would you sonic check the bores to see if they need shifted and then remachine everything else to match those locations? I'm sure almost everyone starts off the main bores, but who's to say they were put in correctly to start? I'm probably thinking too much about it, just thinking out loud here.
What sort of software are you using with the probe?
Floyd Lippencott IV
Re: benefits of cnc engine machining? [Re: Performance Only] #837283
10/24/10 02:23 PM
10/24/10 02:23 PM
Az
Crizila Offline
Crizila  Offline
Az
Fell asleep on the 3rd hole. I like the concept - showing your shops / machine capabilities and education of clients, but I think most could get the idea ( with some dialog ) on just one hole.
Fastest 300
Re: benefits of cnc engine machining? [Re: Crizila] #837284
10/24/10 02:43 PM
10/24/10 02:43 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
x2, i like threads like this... show us more.
Re: benefits of cnc engine machining? [Re: mr_340] #837285
10/24/10 02:45 PM
10/24/10 02:45 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Starting point now would probably be the head dowels. But I wouldnt move much if everything soniced ok on pass car stuff.
Re: benefits of cnc engine machining? [Re: Hot 340] #837286
10/24/10 03:16 PM
10/24/10 03:16 PM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
The operative word here is "USUALLY".
Was it cast from virgin iron, or recycled scrap with carburizer thrown in to come up with a grade 30 iron. What's the Nickel content? Hemi block, I would guess that qualifies as a high Nickel block; it's not gonna machine like a soft chevy block. And you are correct .125in is not a real serious cut, I was thinking that coolant would hold the part thermally stable, and improve tool life, thus improving finished product. Why measure to 5 decimal places, repeat to 4, and have thermal instability take the benefits away at 3?
Just my
Re: benefits of cnc engine machining? [Re: JBurch] #837287
10/24/10 03:22 PM
10/24/10 03:22 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Boring is done to within .004-.005, then the final ( hopefully 2 step) finish honing is done, which then allows you to take into account the thermal changes in the blocks/cylinders, as you go from end to end, side to side to let the adjacent cylinders cool. Most often you will do the honing, let sit overnight, then touch hone next day with no heat.This is where your 4th digit comes into play.
RIP Monte Smith
Re: benefits of cnc engine machining? [Re: JBurch] #837288
10/24/10 03:59 PM
10/24/10 03:59 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
We just machined first XR2 Block couple weeks ago, & definitely can tell the iron they are using is not near the quality of an R3 race block. XR had hard spots in it that was tearing up cutters & end mills.
Re: benefits of cnc engine machining? [Re: Performance Only] #837289
10/24/10 05:55 PM
10/24/10 05:55 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
Absolutely! Looking good Dan! We have the same machine minus the 4th axis. The probe's reference point is whatever you set it up to be. Primarily, you want to set the bores up to use the crank centerline as the reference and correct the bores back onto the crank centerline. The bore spacing is also corrected if off. For lifter bushings, you can reference off the front thrust face. Correcting the lifter bores is crucial on any block. By doing so, it keeps the valve events the same between cylinders. Why buy a fancy CNC ground cam and put it a 40year old machined block
Re: benefits of cnc engine machining? [Re: CRE2004] #837290
10/24/10 06:05 PM
10/24/10 06:05 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
How do you establish X axis this way?
Re: benefits of cnc engine machining? [Re: Hot 340] #837291
10/24/10 07:02 PM
10/24/10 07:02 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
I dunno how the Rottler establishes blueprint points, but the RMC probes the crank CL, the Cam CL, & also probes the factory dowel pin locations on the corners of the pan rail area, which is what a block would be machined off of @ the factory.
Then it probes the deck in 10 locations per side & all the bores in 4 locations & grids the block out for you to show how far off it is from blueprint positions.
To probe the lifter bores to see how far off they are, you have to do it manually.
