Page 3 of 6 1 2 3 4 5 6
Re: Vapor Lock [Re: convx4] #837000
10/25/10 12:11 AM
10/25/10 12:11 AM
Brandon, Ms
cornet684me Offline OP
Brandon, Ms
at this point, i have really ruled out Vapor lock, i have not had the car running long enough and hot enough for Vapor Lock, i apprently have a fuel problem, tank, fuel pump, fuel pump rod
or ???, hopefully when i do the test tommorrow i can determine if the pump is pumping a steay stream.
thanks
Re: Vapor Lock [Re: ireland383] #837001
10/25/10 12:16 AM
10/25/10 12:16 AM
Brandon, Ms
Brandon, Ms
so i need to take the rod out and just measure the rod?
Re: Vapor Lock [Re: cornet684me] #837002
10/25/10 12:21 AM
10/25/10 12:21 AM
1st do Joe's test w 2 jugs. W the carb bowl full (fill it 1st w a turkey baster) you'll have 5-10 seconds b 4 the bowl runs dry & that'll be enough time to see if the pump is pulsating a good stream & if not then yes take out the plug & the rod
Re: Vapor Lock [Re: joedust451] #837003
10/25/10 12:38 AM
10/25/10 12:38 AM
In most cases it "will not" keep the filter completely full.
I've seen alot of em w as much fuel in the filter as the one in the last pic.
Re: Vapor Lock [Re: RapidRobert] #837004
10/25/10 12:40 AM
10/25/10 12:40 AM
Brandon, Ms
Brandon, Ms
thanks Robert, i will try that tommorrow, i saw the lady across the street today and she was giving me evil eyes because i have been in the garage running the 440 all weekend
Re: Vapor Lock [Re: cornet684me] #837005
10/25/10 12:44 AM
10/25/10 12:44 AM
well I'm a firm believer in not antagonizing the old folks esp as I turn 60 next spring
Re: Vapor Lock [Re: RapidRobert] #837006
10/25/10 12:48 AM
10/25/10 12:48 AM
Brandon, Ms
Brandon, Ms
she is just a sore head, she is not old, i think she is just an unhappy person, i guess when i get the car back running, i sound go over and ask her if she wants to ride in a real car
Re: Vapor Lock [Re: cornet684me] #837007
10/25/10 12:52 AM
10/25/10 12:52 AM
But do wait until she stops the evil eye. W women it's all in the timing. Good luck w it (the car) & holler back when you find something, I gotta hit the hay.
Re: Vapor Lock [Re: RapidRobert] #837008
10/25/10 01:46 AM
10/25/10 01:46 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Got that right , they can & WILL be nasty when pravoked !!!!
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Vapor Lock [Re: cornet684me] #837009
10/25/10 07:50 AM
10/25/10 07:50 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Yes, pull the pump out and take out the plug underneath it. The rod should come down if it is not mushroomed on the cam end. Good luck.
Re: Vapor Lock [Re: joedust451] #837010
10/25/10 10:23 PM
10/25/10 10:23 PM
Brandon, Ms
Brandon, Ms
okay guys, i think i have narrowed it down to the fuel line from the tank and the sending unit, i really did not think i needed to replace since it was a daily driver for so long, i guess i am going to go ahead and replace the tank, sending unit and the fuel line? i have attached a pic. of the fuel filter while running from a hose put in a gas can, i let it run till normal temp of engine and it never fell before half full, is this where the fuel is suppose to be on this type of fuel filter?
Re: Vapor Lock [Re: ireland383] #837011
10/25/10 10:27 PM
10/25/10 10:27 PM
Brandon, Ms
Brandon, Ms
i checked the rod when i put the new pump on, it did look mushroomed, however i did not take it out and measure it
Re: Vapor Lock [Re: RapidRobert] #837012
10/25/10 10:30 PM
10/25/10 10:30 PM
Brandon, Ms
Brandon, Ms
do what do you think Robert, wld you just get a new sending unit or replace everything?
Re: Vapor Lock [Re: cornet684me] #837013
10/26/10 04:46 AM
10/26/10 04:46 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
cornet684me,
I recently went through some fuel issues with my 68 Road Runner. New lines, new sender, new sock filter, etc. As the car warmed up I would lose fuel pressure and during my troubleshooting I installed a temporary glass filter and watched it fill up and empty out while running the motor. As it turned out one of my hose clamps holding the rubber hose to the hard fuel line was not quite tight. The clamp was close to the exhaust manifold and when cold everything was fine. As the engine bay heated up the rubber hose got soft enough to let some air in around the hard line and the fuel pump was sucking more air than fuel. I put a second worm clamp at that location and the fuel pump now keeps the filter full at idle.
Go figure...
Re: Vapor Lock [Re: cornet684me] #837014
10/26/10 08:28 AM
10/26/10 08:28 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'd be taking it out and measuring it before I did anything else.
Re: Vapor Lock [Re: cornet684me] #837015
10/26/10 10:35 PM
10/26/10 10:35 PM
Brandon, Ms
Brandon, Ms
update- dropped the tank, the tank is as clean as a new one, the sending you perfect shape, i am going to blow out the hard line, i guess i need to pull the fuel pump rod, i tested the pump and it tested fine, i have checked out everything and do not know why the fuel filter goes empty when the car is running?
Re: Vapor Lock [Re: cornet684me] #837016
10/26/10 11:35 PM
10/26/10 11:35 PM
I did not think i needed to replace since it was a daily driver for so long, i guess i am going to go ahead and replace the tank, sending unit and the fuel line? i have attached a pic. of the fuel filter while running from a hose put in a gas can, i let it run till normal temp of engine and it never fell before half full, is this where the fuel is suppose to be on this type of fuel filter?
Randy I read this thru several times to try & get a handle on the prob & possibly contribute. Yes if it never fell below half full then the pump/rod is Ok & the prob is rearward from the pump as long as it isn't escessive heat that is boiling it & we're thinking no on that but b 4 you drop the tank/sender I'd continue on w the same test you just did (a jar of gas connected to the pump inlet) & let it run until it is real good & hot (assuming you havent already) & see if it vapor locks/dies idling in your driveway & you can keep tabs on the filter. If it stays good & by now you've visually checked the hard line/2 neoprene connector pieces) I would take the jar and your hose and plumb it to the rear of the hard line there as it enters the sender & repeat. That only leaves the sender as you dont want to have to mess w it or the tank if you dont have to. I know you said the tank/sender looked OK but the sender may have a crack but one thing at a time & the jar hooked up to the rear line will tell you something. EDIT & you're not running E10 (gasahol) right?
Re: Vapor Lock [Re: RapidRobert] #837017
10/27/10 12:37 AM
10/27/10 12:37 AM
Brandon, Ms
Brandon, Ms
hey Robert, i really appreciate you trying to keep up with my problem, i have already drop the tank, i will test the hard line tommorrow, i am going to hook up a hose from the hard line in the rear and see what happens, so if it test out then it wld have to be the sending unit right?
Re: Vapor Lock [Re: cornet684me] #837018
10/27/10 12:41 AM
10/27/10 12:41 AM
Brandon, Ms
Brandon, Ms
you know Robert, i do think that the gas is 10% ethonal, i cannot find a station around my house that says real gas, i have 1 station about 13miles from the house, do you think this gas is the problem?
Re: Vapor Lock [Re: cornet684me] #837019
10/27/10 12:44 AM
10/27/10 12:44 AM
Brandon, Ms
Brandon, Ms
here is pic of the sending unit, the inter gas tank is perfect, no rust and no dirt, no need to replace the tank,
