Page 6 of 6 1 2 3 4 5 6
Re: Vapor Lock [Re: Challenger 1] #837060
10/30/10 02:08 AM
10/30/10 02:08 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Measure the rod. If it needs replaced, check around about getting a good one. I think ARP still makes one worth buying, but these days everybody is downgrading so ask around about that. Don't want to revisit this next month.
Buy a good tubing bender and flare tool. Bluepoint makes a nice flare tool, will last as long as you can keep people from stealing it from you.
Make a new setup to attach to the carb. Get a T and some other fitings to make it work. That China made POS on there now isn't getting it. Cheap chrome to flake off, is bent all to crap now.
Replace the fuel line from tank to pump.
Do what you have to with steel lines and the tools to get rid of all that rubber line. That is about as much as you need in the entire car going off the frame to the pump in those pics. You have more than that anyway by the tiem you add up all the little spots.
Looks like more at the front of the engine going up to the clear filter that needs to be eliminated and replaced with a steel one. Get rid of that as well.
You need to put new hose from the sender to the steel line, from the line to the pump, and just use the little pieces that come with your new steel filter. That is all of the rubber line you need. Should be no more than about 12" total.
Used new clamps.
Re: Vapor Lock [Re: SomeCarGuy] #837061
10/30/10 01:50 PM
10/30/10 01:50 PM
Brandon, Ms
cornet684me Offline OP
Brandon, Ms
here is a pic of the Fuel pump rod, nothing wrong with it, the car ran fine when i just hook up a house straight from the fuel pump, when i connect the hard line from the tank, the fuel filter goes empty after i crank the car and it is idling, i really do not have the money to do all the new stuff right now, i am trying to get this motor back running so i can sell it, and then i plan on replacing everything, i don't understand why when i hook up the hard line from the tank and put a hose from a gas can attached to the hard line bypassing my tank and sending unit, the fuel filter goes empty, i have checked the complete hard line and there are no leaks, it almost acts as though the fuel pump just stops working when i hook this line up?
Re: Vapor Lock [Re: SomeCarGuy] #837062
10/30/10 01:54 PM
10/30/10 01:54 PM
Brandon, Ms
Brandon, Ms
i ran the car with the rubber hose replaced with a steel line, i only have rubber hose from the tank to the hard line , from the hard line to fuel pump, and the 2 pieces on the see thru filter, what is the difference between a steel filter and see thru, i have always ran the see thru filters with no problems?
Re: Vapor Lock [Re: cornet684me] #837063
10/30/10 01:58 PM
10/30/10 01:58 PM
the pump/rod/line to carb/filter are good and the prob is rearward from the pump. That only leaves the hard line rearward (including the 2 neoprene connector hoses) OR the pickup assy. did you hook the jar to the neoprene connector hose at the tank? This'll tell you if it's the hard line/2 neoprene hoses OR the pickup assy.
Re: Vapor Lock [Re: RapidRobert] #837064
10/30/10 02:06 PM
10/30/10 02:06 PM
Brandon, Ms
Brandon, Ms
i hooked up the hard line from the tank to the fuel pump, a 4inch 5/16 hose and 2 new clamps to the fuel pump, the on the rear, i hooked up the hard line up with a hose with clamp and then into my gas can
Re: Vapor Lock [Re: cornet684me] #837065
10/30/10 02:15 PM
10/30/10 02:15 PM
Oh OK I reread your post & yes you did that. I know you blew thru it but it's gotta have major blockage or sucking air big time (more likely the hoses if sucking air unless the hard line is real old in a humid climate (or salty gulf air). Might check it again (we ARE getting close (er) ) Whenever I get a straw w a minute crack in it w my McDonalds vanilla milkshake I get just enough to whet my taste buds then very little after that
Re: Vapor Lock [Re: RapidRobert] #837066
10/30/10 02:20 PM
10/30/10 02:20 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Good analogy..
Re: Vapor Lock [Re: RapidRobert] #837067
10/30/10 02:22 PM
10/30/10 02:22 PM
Brandon, Ms
Brandon, Ms
the hard line is the original, the car has been undercoated and the fuel line looks okay from the outside, so to save some money right now, can i buy a roll of that cheap alum. fuel line and run me a new line for now, so i can get the car back running to get the 440sold and then i am going back with my new 440 i just bought this week, so my question is, can i run a temp line for now to get the car running ? upon further investigation , the gas tank has had some repairs and i really need to replace, so my plan is , get the car back running, sell the current 440 and i will do all the upgrades, new tank, 3/8 stainless line, new 3/8 sending unit, i really just need the car running to get the motor gone
Re: Vapor Lock [Re: RapidRobert] #837068
10/30/10 02:24 PM
10/30/10 02:24 PM
Brandon, Ms
Brandon, Ms
i hate when you leave the drive thur and the go to drink your coke and then you suck air, the line is wrapped around and going to interstate, so i just take off the top and drink, i understand this maybe what is happening with my gas line
Re: Vapor Lock [Re: cornet684me] #837069
10/30/10 02:25 PM
10/30/10 02:25 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
What have i been saying, the hard line obvisously is the problem, or that short rubber hose that goes between the cross-frame by the trans crossmember, your running in circles, if your getting fuel from the pump too the carb, but once you try & run through the hardline is gets restrictive .
You have ruled out the Tank/pick-up/rod/pump, this sounds like a re-pete to me, i told you to yank out all that hardline & replace it, either with a role of 3/8 aluminum line from summit/jegs, The aluminum is very easy to bend & its cheap too, just use your old line as a template, OR a factory line, but there not cheap.
The mech. fuel pump will not have a problem sucking fuel from a long distance through curves/bends IF theres NO restrictions or air. . Its not "ROCKET SIENCE"
If theres "air" it would be dripping fuel on the ground.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Vapor Lock [Re: joedust451] #837070
10/30/10 02:31 PM
10/30/10 02:31 PM
Brandon, Ms
Brandon, Ms
thanks Joe, there are no fuel leaking on the ground , sorry for all the repeats, i am just frustrated , i will get a new hard line and i will get back with everyone, i thank everyone for there patience with me, i guess my problem is,
i was trying to get by and i should have known to do it right the 1st time, i am on the way to parts house to get roll of fuel line and i will post the results when i crank up the car
Re: Vapor Lock [Re: joedust451] #837071
10/30/10 02:32 PM
10/30/10 02:32 PM
SomeCarGuy Offline
SomeCarGuy  Offline
Possible crack in the sender? Sucking air at that point. Won't have any leaks to see then.
Common spot to rot out the main line is running through the trans crossmember. Some fuel could leak there and you wouldn't necessarily see it.
Re: Vapor Lock [Re: SomeCarGuy] #837072
10/30/10 02:35 PM
10/30/10 02:35 PM
Brandon, Ms
Brandon, Ms
i have bypassed the sending unit right , i think i will just go ahead and do a new hard line for now
thanks
Re: Vapor Lock [Re: cornet684me] #837073
10/30/10 04:29 PM
10/30/10 04:29 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I'm sure you will have problems finding "aluminum" line locally, i know i couldn't, the only other bet is "copper" at Home Depot or Lowe's, its a bit pricey & hard to bend for tight corners around the frame rail, the aluminum is the easiest & not as likely to kink.
Once the hard lines been re-placed (along with the short rubber hose at the crossmember) & by ANY chance its still having issues, it'll make it alot easier to narrow it down.
When i disconnect my hard line from the pump, it'll poor gas instintly & drain the tank, Oh but i'm running a fuel cell .
Let us know how it works out!!
http://www.jegs.com/i/Moroso/710/65330/10002/-1
http://www.jegs.com/i/JEGS/555/15100/10002/-1
Re: Vapor Lock [Re: joedust451] #837074
11/07/10 10:42 PM
11/07/10 10:42 PM
Brandon, Ms
Brandon, Ms
UPDATE: i guess i should have disclosed that i was running the stock 5/16" gas line due to the fact my car came from factory with a 318, i have learned that a big block needs at least 3/8", i ran a new line from the fuel pump to the tank 3/8" aluminum line, i have posted a pic. of the full fuel filter!
thanks to everyone that put a in, this pic was after i ran down the highway and at 180 on the temp gauge
Re: Vapor Lock [Re: cornet684me] #837075
11/07/10 10:48 PM
11/07/10 10:48 PM
Brandon, Ms
Brandon, Ms
the orange gas was what the rubber lines do to gas when it sits in there a while
i replace every thing with metal, i have very limited rubber on the line now
surprisingly the 44year old 5/16" fuel line was not rusted, i cut it up and saved what i could for future uses.
Re: Vapor Lock [Re: joedust451] #837076
11/07/10 10:52 PM
11/07/10 10:52 PM
Brandon, Ms
Brandon, Ms
Joe, thanks for the link to Jegs, i went on line and ordered, the new line was at my door step by the 3rd day, i went with the Moroso,
cheap however very stong.
can you believe that i got put it in without a break, 1 line from fuel pump to the tank, i have to admit it took the better part of the whole day yesterday fighting with the shocks and exhaust.
thanks
Re: Vapor Lock [Re: cornet684me] #837077
11/08/10 12:37 AM
11/08/10 12:37 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
thanks
Glad you got it fixed, but i will tell you a buddy of mine ran mid 11s in his BB A body for 8 yrs. with the factory 5/16 line, BUT he ran a helper Elec. pump, I'm still convinced the factory line had issues somewhere because that gas NOW looks crystal clear .
