Re: Help on my sb magnum build, solid roller?
[Re: DJVCuda]
#835352
10/22/10 12:58 PM
10/22/10 12:58 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
good point. my truck is manual locks, windows, mirrors, etc. so I'm sure that saves me some more weight as well
**Photobucket sucks**
[Re: 70Cuda383]
#835354
10/22/10 01:30 PM
10/22/10 01:30 PM
Posts: 32 Zanesville, Ohio
Last_in
Zanesville, Ohio
Also, his truck is in full street trim. no weight reduction, full factory interior, full factory sheet metal, plus he's got AC, Power steering, a decent stereo system...
Stereo system is coming out this weekend, I found a buyer for all that stuff! I rather have a backseat now.
What is your max RPM now? And where does the good pull end - RPM?
Max RPM I'm not sure of, probably around 6.5K. I spun it past 6k with no problem. Factory tach only goes to 6k so I would peg it but it kept pulling. It actually pulls pretty solid all the way through, I wish I didn't take it out of the truck already and go check for you.
[Re: Last_in]
#835355
10/23/10 11:05 AM
10/23/10 11:05 AM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
I've been running my 408 set up for the first year now and made a few adjustments:
first, I don't think reaching 7000 rpm will be a problem, I took the engine there once and did not seem to hate it...but why go there ??
I ditched the injection to go with an 800 cfm holley and turns great! I started the season with a 280/292 hyd roller (230/238 @ .050) and turned very good, very smooth idle very street friendly. 180 psi cranking pressure, 8sec flat on the 1/8 mile before having oil pressure problems...
After almost 2 months I reinstalled the engine with a solid 250/250 @ .050 (290/290) from comp cams 165 psi cranking pressure, best 7.6 1/8 mile and 11.96 1/4 mile with very bad '60 (1.71) but still a lot more tuning to do on the car so I figure 11.50 is in the reach easy..
Then , my thoughts on a solid roller.I'm really not afrain to go there, and pretty sure I can pull a lot of HP froom that. So if you want to go there, I'm with you all the way!
BTW, did I mentioned I'm running the RHS iron heads with the small 1.92 valves ? changing to the big 2.02 valves this winter will give me 50 cfm in ported form, Do you think the high 10's are in reach? I think so too......
My choice would be something like a 250/256 @ .050 solid roller with a LS of 108 for a sweet spot of 3000-7000 (something in the ballpark)
Dan Dan
[Re: Wedgeman]
#835356
10/23/10 11:12 AM
10/23/10 11:12 AM
Posts: 637 Kokomo,IN
StripeHOG
Kokomo,IN
why are you so hellbent on 7000 rpms????? use your torque, you need power down low due to your weight!!!! *add* or you'll need a converter so loose you'll lose streetability, do you mean 10's w/ nitrous???
Andrew Brough D372
1969 Dodge Dart GTS
1.43 60'best
6.82 1/8 98mph
"the light came on and I ran out of talent"
