Re: stock 440 pistons, how far down in the hole?
[Re: John_Kunkel]
#83451
07/04/08 12:33 AM
07/04/08 12:33 AM
67, 70-72 ran a piston with a compression height of 1.991.
'72 was the first year of the really lowered compression (8.2 advertised), the compression height on those is 1.926" which puts it close to .150" down.
cept' for the 72 440+6. that big dog still had 9.5-10.0:1 cr.. depending on who you believe.
[Re: DaytonaTurbo]
#83452
07/04/08 02:54 AM
07/04/08 02:54 AM
Posts: 1,183 eganville ont
440beep
eganville ont
70 440 4bbl hp are 9.7l flat tops 71 440 4bbl hp are 9.5 l flat tops 71 440 4bbl lp are 8.8.1 flat tops 70 440 6bbl hp are 10.5 71 440 6bbl hp are 10.3
Plymouth's gonna getcha!
There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters
71 gtx 440 4speed air grabber blue on blue with white vinyl roof
[Re: DaytonaTurbo]
#83455
07/04/08 10:21 AM
07/04/08 10:21 AM
Posts: 75,098 A Banana Republic near you.
JohnRR
Either way, at the end of the day, what does it really matter? Nobody builds a performance engine with stock pistons these days and no two engines were built exactly the same. Go with your aftermarket pistons, have your block decked to get zero deck and call it a day.
what matters is there is some potential misinformation in this thread . too many times i have seen people that haven't researched the combo they want get STUCK with a low compression PIG because they either assumed that they were buying correct replacement parts when what they were really buying was the aftermarkets COMPROMISE to having to carry an EXACT replacement for every model year , at least thats how it works with big block MOPAR engines .
take the 383 for example , 2 or 3 basic compression ratios built over multiple years with first a closed chamber head then an open chamber head , dicounting a DOMED piston, both TRW/SPEEDPRO and KB carry ONE piston to cover ALL those variations
[Re: VITC_GTX]
#83456
07/04/08 10:25 AM
07/04/08 10:25 AM
JohnRR
Trying to figure out the compression in my '70 GTX with original 440 (without tearing the motor apart). I'm getting tired of fighting pre-detonation and want to try and do something. First thing I want to do is figure out my CR.
I have ported 906's that are shaved .006" (assuming 78 cc's), .030" over bores, stock replacement forged pistons. If I can find what the average depth of the pistons are (and look at compression thickness of my head gaskets) I can closely estimate my CR.
What's the average depth in the hole for a '70 440?
Van lets try to actually ANSWER your question instead of GUESSING what you have .
heads shaved , by you ? if so what head gasket did you throw it back together with ?
[Re: JohnRR]
#83458
07/04/08 01:58 PM
07/04/08 01:58 PM
Posts: 4,931 Tri-Cities, Washington
VITC_GTX
I did not put the motor together. I have all receipts showing parts and head machine work. The receipts shows that the heads were shaved .006". I know I can't count on everything I read (or believe everything Ma Mopar said) but I was just trying to see if I have a compression problem, quench problem, or another problem.
[Re: VITC_GTX]
#83460
07/04/08 03:52 PM
07/04/08 03:52 PM
JohnRR
do the receipts show what pistons were used ? i just noticed you said its .030 and stock replacement pistons , which could be anything and will effect the compression ratio greatly .
unless its got KB step heads you can rest asuure that you have NO quench
[Re: JohnRR]
#83462
07/04/08 06:04 PM
07/04/08 06:04 PM
VITC_GTX
The part number for the pistons is SPE 2286P .030. I was told these were Speed Pro forged replacements for the '70 440, but have nothing to back that up.
