Re: Slicks
[Re: Kudakidd]
#834445
10/20/10 03:13 PM
10/20/10 03:13 PM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
I'd say timing ( a lower initial helps sometimes) next carb - accel pump shot and jet extensions my dad had 3.23's in his car - we had a 750 holley dialed in for the track - larger acc pump shot and backed the timing down initial and it ran great off the line - 10 BTDC IIRC with a MP dizzy so it was not at 38 total. we swapped carbs for a more street friendly ( 670 cfm holley and there is a huge bog off the line now - back to square one! VIDEO HERE keep in mind its leaving under 3 grand and 3.23's
Re: Slicks Bite, Car Bogs - What to do?
[Re: ProStDodge]
#834446
10/20/10 03:21 PM
10/20/10 03:21 PM
Posts: 672 Roanoke Va
gearjammerdart
Roanoke Va
install an automatic - the car will be faster, break fewer parts, and suddenly get more consistent.
Been there - done that - went faster
Then you could eat a hot dog and drink a coke as you let your air/electric stifter shift for you. You might as well stay home and play a play station IMO.
[Re: Kudakidd]
#834447
10/20/10 03:26 PM
10/20/10 03:26 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
440 in a A-body? Need a bit more gear, 4.10's should work better. Any 28.5-29" tires in your possesion? Are you running a Holley or Carter and what cfm? On either type, check your pump shot settings, and linkage travel. How is your total vs. initial ignition timing? Food for
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Slicks
[Re: Kudakidd]
#834450
10/20/10 07:58 PM
10/20/10 07:58 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
The carb is a 750cfm Mighty Demon, that I checked and rebuilt. 73 in the primaries/ 83 in the secondaries. #31 accelerator nozzles and a pink cam. I think I'm out of pump fuel leaving at 4k rpm. Anyone have a pump cam chart. I think I need the extra gas to come in later. I'm not going to change rear gears, although I know 3.55's aren't optimum for my combo.
I'd jump up to 76-84's and leave at 4800-5k and see what happends.
[Re: Kudakidd]
#834453
10/21/10 01:33 AM
10/21/10 01:33 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
440 in a Duster, and yes it's a 4 speed. Even popping the clutch at 4 grand, the car will still lay down and hesitate giving me 2.10 60 footers! I'm using M/T drag Radials set at 18psi. I tries moving the card accelerator pump cam to the #2 position and it didn't help at all. Best time on a 60 degree nite was 13.16 at 106 mph. Any help?
The way your describing it, it seems like a carb tune problem. Laying down,,, Hesitation,, etc.
But there appears to be some other issues as well. IMO. For instance if the comp is around 10.1 with that cam and tire you should have a problem with Hook, not bog!
On the carb, the pink cam may be to much, thats as big as it gets, if set in the #2 position. You may be flooding the heck out of it on launch. Try a blue cam, that works good for alot mild combos.
At 106 MPH your about a second short on ET, due to your poor launch. You have at least 12.40 ET second ride there with that MPH.
And IMO, if you have 10.+ comp, I dont see why you couldnt bump into the 11,s with a 440 in a Duster with that 509 cam.
I just think your combo needs some track test and tune time. mike
[Re: Kudakidd]
#834454
10/21/10 02:49 AM
10/21/10 02:49 AM
Posts: 1,266 New York, USA
Chargerfan68
New York, USA
I know with my heavy B-body, I tried all launch rpms, and my car must launch at 6000-6500 rpm. I just ran my fastest 60 ft. with a 6500 rpm launch.
You need to make sure you have super heavy duty u-joints and yokes to survive that. I broke everything in between the motor and rear. Finally upgraded to billit yokes both sides with 1350 spicer solid ujoints and no breakage now.
Good luck, Greg.
chico
[Re: Sport440]
#834456
10/21/10 11:24 AM
10/21/10 11:24 AM
Posts: 7,910 Witness Protection Program
Kudakidd
Maybe that's the problem, the compression ratio is only 9:1.
[Re: Big Squeeze]
#834457
10/21/10 11:24 AM
10/21/10 11:24 AM
Mr.Yuck
Brookeville, Md
At 106 MPH your about a second short on ET, due to your poor launch. You have at least 12.10 ET second ride there with that MPH.
12.10 @ 106???.......Only time that happens is if a car is running out of fuel or hitting the chip at 1,000 feet.......
yeah my old coronet ran 12.90's at 104 w/ 1.68 60 foot times. I'd say 106 is good for 12.60-70. Your gear is killing you and will cause your clutch to hate you.
[Re: Kudakidd]
#834458
10/21/10 02:29 PM
10/21/10 02:29 PM
Posts: 4,017 South Park, Pa.
68LAR
South Park, Pa.
There are many things that must be considered with your combo: 1. You have a stick car. When you launch, most likely you are leaving off of the secondary, not the primary side of the carb. 2. If the car bogs, some adjustment must be made to have something slip. Something has to slip, clutch or tires, you make the choice. It has to be one of the two. With an automatic, most of the time it is the converter. But something has to slip to keep the engine rpms "UP". 3. With your combo, and not knowing what flywheel you are using, it sounds like you are out of the power band of the cam at launch. 4. Radial tires and stick cars usually don't work well together. Most stick cars will blow a radial tire off at will. Some things I'd try: 1. Make sure you have a good heavy shot from the secondary squirters. There shouldn't be any "dead spot" when the rear throttle blades are activated. 2. Leave at a higher RPM and raise your tire pressure. 3. Make sure you have your valves adjusted properly. Too much preload will allow the lifters to pump up and restrict engine rpm. 4. Distributor timing should be all out at idle or no later than 1800 rpm. 5. You might want to try a small diameter tire, just for racing. 6. A 440 in an "A" body should have no problem launching. There should be plenty or torque. I would think that your compression ratio is kind of low for that cam, but you should still be able to make it work to some extent. What is your cranking compression? You don't want to be below 165. Ideal would be in the 180 range. These are things that I've tried and learned over the years. Many of them are in use right now with my car. Good luck and have fun hitting the gears.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: Kudakidd]
#834459
10/21/10 04:09 PM
10/21/10 04:09 PM
Posts: 21,066 in a cattle trailer down by th...
Guitar Jones
My buddy would just hammer the throttle and let valve float be the rev limiter. Lot's of fun!!
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Mr.Yuck]
#834460
10/21/10 07:27 PM
10/21/10 07:27 PM
Sport440
Canton, Ohio
You guys are right, a 12.10 is a big stretch for a 106 mph. 12.3,s to 40,s is where it should be running, without the bog. I fixed it/edited it. mike
Re: chico
[Re: Kudakidd]
#834462
10/21/10 08:06 PM
10/21/10 08:06 PM
Sport440
Canton, Ohio
Your compression isnt the best , but I dont think its the problem.
Theres something wrong with the engine tune, IMO.
Even with your 3.55 gear that engine should be capable of easy 12.40,s Sub 12,s with hook and a great tune in that A body car.
My A body 440 Sport started out with 9.5 comp. and a mp 484 cam. With 3.91 gears and a Stock vert, with tall tire I ran a 12.47 @ 113 MPH.
With a set of slicks, 11.75 @ 113 mph stock vert. all @ 3350#
Ive seen where bone stock 440,s in Abodys will run 12.40,s.
So Im convident without a doubt, that once you find the tune problem. Your MPH and ET will come around.
You should be able to Blow those tires away at will. There should be No dead spot or hesitation in the tune.
You need to verify that your timing is around 35* at RPM
Check your plugs for richness or misfire.
Dont laugh , Ive had #7 cylinder drop out because of a misfire, caused by a burnt spark plug wire at the header. And I couldnt tell it by sound.
As I stated earlier, the pink cam is one of the biggest pump cams. Suppose its running rich The Pink cam is only going to enrichen it. Bogs are not Only a lean condition.
See what the plugs going to tell you, or abuddy behind the car.
On your MPH, what fuel pump do you have? If its bone stock, it may be starving you at the top and you may not even feel it.
Just a few things that I would check if it were my car. One more, Id do a compression check too. mike
