mechanical injection ? #833680
10/19/10 11:23 AM
10/19/10 11:23 AM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
How big of a role does the intake and throttle body play with port injection? It seems there is no limit to the size of throttle bodies being used. Is more air capabilty better and is a tunnel ram better with 2 throttle bodies or is a single plain that flows well just as good. I'm just speaking general terms. In specfic terms will my B-1 orginal single plain work well with a terminator on top or would you go tunnelram?
Re: mechanical injection ? [Re: mac56] #833681
10/19/10 12:00 PM
10/19/10 12:00 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
IMO, a tunnel ram with hat injection has more potential then a low rise intake with one or even two throttle bodies. But I have no scientific data to back that up!! lol
Re: mechanical injection ? [Re: MegaDart] #833682
10/19/10 12:37 PM
10/19/10 12:37 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Is that a Hat on top of your tunnelram Wayne?
Re: mechanical injection ? [Re: mac56] #833683
10/19/10 12:47 PM
10/19/10 12:47 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I run a tunnel ram with 2 Ron's Terminators(2950 cfm) on mine. It works really well. I have never run 1 on just a single carb. intake,so I really cannot say its better. This is my first time running alochol,but all my engines have always run better and made more power with a tunnel ram on racing gas.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: mechanical injection ? [Re: MRMOPAR622] #833684
10/19/10 12:52 PM
10/19/10 12:52 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Almost forgot I'm sure Ron's or any of the others can get you running good with your intake. It might not be a bad idea to step up to a better intake now instead of later.
Re: mechanical injection ? [Re: MRMOPAR622] #833685
10/19/10 01:12 PM
10/19/10 01:12 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
The plenum in a tunnel ram helps airflow, both in wet or dry systems. A well ported tunnel ram with a hat or a pair of throttle bodies can actually make more power over a broader rpm range than an 8-stack system.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: mechanical injection ? [Re: mac56] #833686
10/19/10 01:12 PM
10/19/10 01:12 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
Yes it was an Enderle bug catcher
Re: mechanical injection ? [Re: MegaDart] #833687
10/19/10 02:02 PM
10/19/10 02:02 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I run efi with a bug catcher, and the bigger the butterfly, the more sensative it is to throttle inputs.I would think, the same applies for the mechanical injection as well.
Re: mechanical injection ? [Re: Dragula] #833688
10/19/10 07:24 PM
10/19/10 07:24 PM
New York
polyspheric Offline
polyspheric  Offline
New York
This true, and very annoying: the amount of air entering for a specific change in throttle disc angle is higher as the disc diameter goes up, and it makes the car "nervous".
What needed is a snail-cam link for variable ratio:
http://victorylibrary.com/mopar/TB-linkage.htm
Boffin Emeritus
Re: mechanical injection ? [Re: mac56] #833689
10/19/10 09:32 PM
10/19/10 09:32 PM
NC
440Jim Offline
440Jim  Offline
NC
How big of a role does the intake and throttle body play with mechanical port injection?
Good question. I was wondering if my Ron's Flying Toilet mechanical injection would benefit from a "carb" spacer on the single "carb" intake (Indy), like many carbureted systems do in my application.
Re: mechanical injection ? [Re: 440Jim] #833690
10/19/10 10:44 PM
10/19/10 10:44 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
I was wondering that same thing just the other night.
Re: mechanical injection ? [Re: Bigbeep] #833691
10/19/10 10:58 PM
10/19/10 10:58 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I can only say from my buddy's 540 cube alky chevy , his car with one large toilet with a sniper intake ran just as fast as it did with two on a tunnel ram. Less tuning low hood scoop, goes like a bat out of heck.
Re: mechanical injection ? [Re: polyspheric] #833692
10/20/10 02:10 AM
10/20/10 02:10 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
Were do you come up with this stuff ?
I have raced a B1 540 CID with a 2300 cfm T2 mechanical fuel injection system and it was not a light switch throttle . It behaved quite predictable and was not any angrier than when I had a carburetor on it.
The engine I have in the cuda has 2 1500 CFM throttle bodies on it with a .870 " lift cam shaft that will idle at 700 RPM .
I would not hesitate to parallel park it between two BMW's , its a complete 2000 HP pussycat .
Engines are not mathematical formulas and never will be , that being said that's why there are a hundred different ways to skin the proverbial cat.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: mechanical injection ? [Re: 440Jim] #833693
10/20/10 06:33 AM
10/20/10 06:33 AM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
That would be awesome if I could just put a 2 inch spacer under a single terminator to get a little more volume and just run a single.
Re: mechanical injection ? [Re: mac56] #833694
10/20/10 01:11 PM
10/20/10 01:11 PM
St. Charles, MO.
St. Charles, MO.
Since it's dry airflow, put the intake on a flow bench, and try out the different thickness spacers and see what it changes, if anything.
Re: mechanical injection ? [Re: Slingshot383] #833695
10/20/10 01:54 PM
10/20/10 01:54 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Thanks for the idea
Re: mechanical injection ? [Re: mac56] #833696
10/20/10 09:19 PM
10/20/10 09:19 PM
NC
440Jim Offline
440Jim  Offline
NC
If you do that, be sure and include the throttle body, not just the spacer.
Re: mechanical injection ? [Re: 440Jim] #833697
10/21/10 06:39 AM
10/21/10 06:39 AM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Thanks Jim. Have you used the set up you pictured?
Re: mechanical injection ? [Re: mac56] #833698
10/21/10 10:53 PM
10/21/10 10:53 PM
NC
440Jim Offline
440Jim  Offline
NC
I have been running that Ron's Flying Toilet injection on an Indy 400-3 (Dominator flange) intake for the last 2 seasons (2009 and 2010).
Re: mechanical injection ? [Re: 440Jim] #833699
10/22/10 06:33 AM
10/22/10 06:33 AM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Did you find a noticeable difference when you switched from a carburetor?
