Re: Torsion bars which way [Re: boydsdodge] #832836
10/20/10 09:26 PM
10/20/10 09:26 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
When I pulled them Saturday I'm sure that they had the L and R on both ends but some slighty different numbers. they are going back in tomorrow so I'll right down what the numbers are on both ends and post!
sags too much with the drag bars just too heavy a car I guess 3625 ish with me in it!!
Re: Torsion bars which way [Re: Dodgem] #832837
10/20/10 10:01 PM
10/20/10 10:01 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The bars do need to be installed correctly L and R and they will be marked. Except for the 1" and thicker bars.
I cant find a #920 bar anywhere. But, there is a .920 diameter bar. The numbers for that are 448,and 9 for the a body and 780 and 1 for the B and E bodies. mike
Re: Torsion bars which way [Re: Dodgem] #832838
10/20/10 11:11 PM
10/20/10 11:11 PM
AndyF Offline
AndyF  Offline
I had my T bars out to try drag bars and want to put them back in!! They are marked left and right but which way is the back???? (or front??)
Thanks in advance!!
Original bars have the paint splotches towards the rear of the car. I think that is just to make it easier to ID the car going down the assembly line. Also, original cars have two paint splotches on one side only.
Re: Torsion bars which way [Re: AndyF] #832839
10/21/10 12:51 AM
10/21/10 12:51 AM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Re: Torsion bars which way [Re: Dodgem] #832840
10/21/10 01:07 AM
10/21/10 01:07 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
These are MP P5249157
.920
the original .960's are long gone
http://chucker54.stores.yahoo.net/torsionbars.html
http://chucker54.stores.yahoo.net/mop920diambe.html
Then those bars should be stamped 780R and 781L As long as you have them on thier correct sides. It doesnt matter witch way the bar is installed front to back, as the twist will be in the same direction.
But since they are aftermarket bars they may be stamped on only one end. If thats the case, you will want to install the stamped end toward the rear for a easy visual identification for you or anybody else for future identification.
Further, the "Even" numbered bar is always the ":Right" side bar. mike
Re: Torsion bars which way [Re: Sport440] #832841
10/21/10 04:08 PM
10/21/10 04:08 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Ok
781L 780R
237 under line on one end both bars
other end
781L 780R
T Y under line on other end both bars
Re: Torsion bars which way [Re: Dodgem] #832842
10/24/10 10:01 AM
10/24/10 10:01 AM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
OK the .920 bars are back in and I put the ends with
the T Y under the 780/781 L and R to the front left in left of course
the backs are 780/781 L & R with 237 under to the rear.
What a difference When I took them out last Saturday I had somehow got them switched and the Left was in the right side and Right was in the left side and it took all the adjustment to get it to the ride height I wanted. Guess they got switched when I put the motor in last spring as i pulled the bars for more room.
Anywho now it only takes about 40 to 50 % of the adjustment to get it to the ride height I want.
Thanks for all the help.
Re: Torsion bars which way [Re: Dodgem] #832843
10/24/10 10:11 AM
10/24/10 10:11 AM
Hamilton,Ohio
P
POZEST Offline
POZEST  Offline
P
Hamilton,Ohio
