Re: Thermoquad on RPM Air Gap
[Re: ademon]
#832199
10/17/10 07:27 PM
10/17/10 07:27 PM
Posts: 3,623 Millinocket, Maine
JonC
Millinocket, Maine
i looked at my ld340 and there isn't much room there also, it looks like if you open it to the good gasket or plastic spacer there would only be about .030 on the secondary side unless you weld. NE1 have a pic of a LD340 opened up to T-quad size.
I don't have a picture, but I hogged my LD340 out a few years back and there is plenty of room left after doing it and I'm using the big bore TQ with no issues at all.
[Re: MoparforLife]
#832200
10/17/10 07:28 PM
10/17/10 07:28 PM
JonC
Millinocket, Maine
You would have the same problem with and LD340. They are not set up for a thermoquad either. yes it will work with a little grinding but why not just get an adapter.
On a non shaker Ebody, there isn't a lot of room under the hood for a LD340, TQ and adapter plate.
[Re: CokeBottleKid]
#832204
10/17/10 10:02 PM
10/17/10 10:02 PM
Posts: 30,457 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
I foolishly had that same combination for a litte (Thermobog on an RPM air gap). Just use an adapter... or better yet use a real carb.
A properly tweaked THERMOquad does NOT have a BOG issue at all ...PEPSIkid
And an ADAPTER is fine on a truck or RV ... but anything HP .. those adapters are NOT the plan.
[Re: dOoC]
#832205
10/17/10 10:13 PM
10/17/10 10:13 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Yet another case of blaming the part rather than the mechanic
[Re: ScottSmith_Harms]
#832207
10/17/10 11:06 PM
10/17/10 11:06 PM
Posts: 8,180 Detroit, MI
CokeBottleKid
Detroit, MI
Say what you want, there's a reason OTHER carter designs like the AFB is still being produced and thermobogs aren't.
[Re: CokeBottleKid]
#832208
10/17/10 11:09 PM
10/17/10 11:09 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
reason is a dummy can work on them.
[Re: ademon]
#832209
10/17/10 11:35 PM
10/17/10 11:35 PM
dOoC
Florida STAYcation
The REASON is ... is those AFB designs are simple UNefficent carbs that are EZ to produce ...... compared to the TQ.
And this stupid thermobog title ? ... if you TWEAK the carb right(with the proper tool ) ....
The CORRECT title would be thermoKICK .... as the secondaries come-in and SPIN the tires !
[Re: ademon]
#832210
10/17/10 11:41 PM
10/17/10 11:41 PM
CokeBottleKid
Detroit, MI
Let me be clear I'm not touting any of the carter designs, just pointing out which of their crappy ones are still in production.
[Re: dOoC]
#832213
10/18/10 12:31 AM
10/18/10 12:31 AM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
[Re: CokeBottleKid]
#832214
10/18/10 12:33 AM
10/18/10 12:33 AM
moparpollack
Lil Herman
Lil Herman
85086
A mopar m1 will work with no mods it's set up for a spread bore carb.
