Re: Punctured a new slick....now what?
[Re: Dago Red]
#832059
10/18/10 12:20 AM
10/18/10 12:20 AM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I'm a chicken, when I punctured a brand new slick last summer(8" long threaded rod laying on Norwalk's race surface ![](/ubbthreads/images/graemlins/frown.gif) ) on the 2nd pass I waited til I had the money to buy a new slick. I tried for a year to sell that slick for $20 and ended up throwing it away. It really sucked since I race on such a tight budget but I'm a freak about safety. Sounds like the plugs/patches work pretty well though.
[Re: ProSport]
#832060
10/18/10 03:29 PM
10/18/10 03:29 PM
Posts: 20,702 in a cattle trailer down by th...
Guitar Jones
Any of the slick manufacturers will tell you to never repair a slick with either a patch or a plug. I have patched a slick in the past, the trick is NOT grinding on the inside surface of the slick. I cleaned it really, really good many times with laquer thinner and let it dry. The patch held for over a year until I changed slicks but then again it's NOT recommended.
[Re: Guitar Jones]
#832061
10/18/10 03:52 PM
10/18/10 03:52 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
while my old coronet was not in your league (12.0's 1.65 60 foot) I ran over something on the way to the track, had to sit by the air compress between rounds, won the entire even, drove my big butt trophey home on a slick going down, took the tire up to the local gas station, they did the roughing up the inside, used somekind of glue and patch kit and hit it w/ a torch. Lasted that season and one more before I sold the car. They were M/T ET streets.
[Re: Mr.Yuck]
#832062
10/18/10 04:03 PM
10/18/10 04:03 PM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
I had a nail go through a 28x12.5 ET Street on my car several years ago and did not have tubes in them at the time. I used a normal plug like I use on my lawnmower. ![](/ubbthreads/images/graemlins/biggrin.gif) Ran it for a long time after that, until the tire was worn out, and never had any problems. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Paul_Fancsali]
#832064
10/18/10 05:09 PM
10/18/10 05:09 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
We plug them all the time without issue whatsoever.
RIP Monte Smith
