Before / After -- keep those belts tight boys !!
#831449
10/16/10 11:15 PM
10/16/10 11:15 PM
Posts: 35,057 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Local Rustang went flying the other night at Spinnerdale Driver is fine car, not so much .. Before
Re: Before / After -- keep those belts tight boys !!
[Re: bigdad]
#831452
10/16/10 11:23 PM
10/16/10 11:23 PM
Triple Threat
Renton Washington
Well it had a nice set of bead lock wheels so it must have been making some steam. Any word on what happened?
Edit I see at least one turbo in the wreckage.
[Re: bigdad]
#831458
10/16/10 11:29 PM
10/16/10 11:29 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Real real sad. That car ran real hard with a pretty basic combo. Glad the driver is ok tho.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: Evil Spirit]
#831462
10/17/10 12:46 AM
10/17/10 12:46 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Was the cage welded at all? It looks like it really came apart.
Glad to hear the driver is OK
[Re: BloFish]
#831465
10/17/10 07:20 AM
10/17/10 07:20 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Wow indeed...! All of this because of a loose fan-belt? After a crash like that, I consider the guy 'lucky' the car didn't catch on fire aswell, with all that mangled stuff on there.
[Re: Dart1031]
#831466
10/17/10 07:51 AM
10/17/10 07:51 AM
Quicktree
Glad he's OK. I wonder why the roll cage broke at the weld though?
thats the first thing I thought. glad he's ok but I would really be concerned with that
[Re: bigdad]
#831467
10/17/10 09:05 AM
10/17/10 09:05 AM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
WOW,,,he must have had some plans for more boost,,look at the size of that inner cooler laying beside car!!! LOL Glad he is OK. Quite a loss of good machinery.
If you like drag racing, support your local track.
[Re: bigdad]
#831468
10/17/10 09:57 AM
10/17/10 09:57 AM
Posts: 16,936 NC
440Jim
NC
And the 10.5 thing is big, great when track is perfect but, when its not ..
Crashing here is normal, that an big wheelstands that result in smashed pans , etc
I hate to see anyone wreck. But this only reinforces my dislike for the 10.5 classes. They seem unsafe to me.
