Page 2 of 4 1 2 3 4
Re: Hemi Oil Pump [Re: Mopar_Rich] #829808
10/17/10 06:34 PM
10/17/10 06:34 PM
QLD Australia
Keith Black® Offline OP
QLD Australia
Rich, I have very little room for the lines, so running with one is my preferred option.
Looking at the #21230, with the pump it looks like there are 3 pump inlet possibilities ...and if you count the front one on the block 4..!!?
Does this mean you can use ANY one inlet and just plug the others off?
(just being sure)
Darren Beale
Keith Black Racing Engines®
Re: Hemi Oil Pump [Re: Keith Black®] #829809
10/17/10 06:54 PM
10/17/10 06:54 PM
Iowa
coronetville Offline
Iowa
I have for sale two milodon systems
Re: Hemi Oil Pump [Re: Keith Black®] #829810
10/17/10 07:01 PM
10/17/10 07:01 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
In theory, yes. But you should look at the pump's impeller and use the inlet that obviously has the least restriction. This is usually the inlet that comes in from the side of the cover just like Andy's.
Re: Hemi Oil Pump [Re: Keith Black®] #829811
10/17/10 07:11 PM
10/17/10 07:11 PM
detroit area
moderncylinder Offline
detroit area
you have 3 possibilities,, you CANNOT use the one in the block,,, in using that one oil has to flow through the pump,, like a stock pump does, the pump has a hole on the mounting surface to the block to pass the oil through, the milodon pump does NOT have that ability..
i run a single line to 9500rpm,,, i use a -16line though but many i know have used 12 lines to 9500
Re: Hemi Oil Pump [Re: moderncylinder] #829812
10/17/10 07:19 PM
10/17/10 07:19 PM
QLD Australia
QLD Australia
thanks everyone. I'll get the #21230.
...& plug the block inlet, then decide on mock up which inlet to use based on space.
Darren Beale
Re: Hemi Oil Pump [Re: moderncylinder] #829813
10/17/10 10:52 PM
10/17/10 10:52 PM
AndyF Offline
AndyF  Offline
I suggested to Steve at Milodon that he make a version of his oil pump for the World block. They could make a pump body that works with their gear set but doesn't have the external inlet. That kind of pump would still have the same volume as their existing pump but would be 3/4 of an inch shorter for more clearance and would be a dual inlet pump when used with their cover and the World block.
Re: Hemi Oil Pump [Re: AndyF] #829814
10/18/10 05:44 AM
10/18/10 05:44 AM
QLD Australia
QLD Australia
Sounds like a good idea, be great if they implement it. I still reckon your cover would clear my engine mount if I use only one inlet (which is all I need).
In any event I bought the Milodon cover today.
I bought the pump a while ago... hope they're a good pump (!.?)
Darren Beale
Re: Hemi Oil Pump [Re: Keith Black®] #829815
11/05/10 12:53 AM
11/05/10 12:53 AM
QLD Australia
QLD Australia
.. AND .... ta da.. the pump cover doesn't fit!
Does anyone make an oil pump cover:
1. external pick up, and
2. remote filer
that will clear the engine mount.? Help please
Darren Beale
Re: Hemi Oil Pump [Re: Keith Black®] #829816
11/05/10 12:55 AM
11/05/10 12:55 AM
QLD Australia
QLD Australia
another pic... without the cover on....
Darren Beale
Re: Hemi Oil Pump [Re: Keith Black®] #829817
11/05/10 12:56 AM
11/05/10 12:56 AM
QLD Australia
QLD Australia
and pump & cover.
Darren Beale
Re: Hemi Oil Pump [Re: Keith Black®] #829818
11/05/10 04:08 AM
11/05/10 04:08 AM
QLD Australia
QLD Australia
...I am wondering what have other people have used with the Standard engine mount Hemi's that require external pickup and a remote filter?
Indy..?
Help greatly appreciated.
Darren Beale
Re: Hemi Oil Pump [Re: Keith Black®] #829819
11/05/10 04:38 AM
11/05/10 04:38 AM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
I still think you will be ok with the milodon pump and a stock pump cover like I use, for the remote filter use this on the stock pump cover.
http://www.summitracing.com/parts/TRD-1113/
edit
http://www.summitracing.com/parts/CTR-22-926/?rtype=10
Re: Hemi Oil Pump [Re: Twin Turbo Mower] #829820
11/05/10 08:55 AM
11/05/10 08:55 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Indy and World blocks usually have a port on the block that can be used for an external pickup and use a stock pump.Most all other external pickup covers require modification of the engine mount.
Re: Hemi Oil Pump [Re: Keith Black®] #829821
11/05/10 09:08 AM
11/05/10 09:08 AM
P
PasiR Online content
PasiR  Online Content
P
2. remote filer
It is possible to do but you need to modify your motor mount. I can share you some pics.
Re: Hemi Oil Pump [Re: AndyF] #829822
11/05/10 09:43 AM
11/05/10 09:43 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
This is the cover I use. It has #12 AN fittings machined into the cover with a straight shot to the external oil lines.
What's the reason this one would not work ? It looks like the cover you purchased sticks rearward too far , this one does not look as bad ?
Re: Hemi Oil Pump [Re: Mopar_Rich] #829823
11/05/10 02:45 PM
11/05/10 02:45 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Re: I always run two lines
If the rotor cavity is segmented for 2 inlets (like a multi-stage dry sump), you've fine - but you have to run both or you're down 50% on volume.
If it's a common chamber to the rotor, you cannot run 2 lines unless you know that neither pickup will be exposed.
Why?
Because if only one pickup is submerged, the rotor has a choice to draw from either:
1. the thick, gooey, viscous oil from the wet pickup, or
2. the nice clean air from the exposed pick-up.
Guess what happens?
Boffin Emeritus
Re: Hemi Oil Pump [Re: Keith Black®] #829824
11/05/10 03:24 PM
11/05/10 03:24 PM
AndyF Offline
AndyF  Offline
Looks like you need the pump that I was suggesting that Milodon should build. You already have an inlet in the block so you don't need a pump with the inlet on it. That would shorten the assembly by 3/4 of an inch which would probably allow things to fit together.
It isn't a tough project to do, just takes money. The other option (which would be much easier) would be to switch over to a factory Hemi oil pump body.
Re: Hemi Oil Pump [Re: JohnRR] #829825
11/05/10 03:28 PM
11/05/10 03:28 PM
AndyF Offline
AndyF  Offline
That cover is one that I custom designed for my car. It wouldn't work for his application because I think he wants an external inlet on the cover.
Re: Hemi Oil Pump [Re: polyspheric] #829826
11/05/10 05:52 PM
11/05/10 05:52 PM
QLD Australia
QLD Australia
Jeff, the consensus has been that I will be ok with one pickup??? typical use < 7,000 rpm, probably a lot less most of the time (streetcar).
Darren Beale
Re: Hemi Oil Pump [Re: AndyF] #829827
11/05/10 05:58 PM
11/05/10 05:58 PM
QLD Australia
QLD Australia
Andy, the cover looks great.. however I think the issue is that the pump is too thick, so a thinner cover will help but may not solve the problem.
Are there any other HV pumps available... Indy..? ..
I need a really good pump but don't have the room! sigh.
Must have 1 x external feed line (can use block if needed), and provide for a remote filter.
Is the standard hemi pump up to the job of supply very high output street engine...?
Darren Beale
Page 2 of 4 1 2 3 4
