LET'S TALK ABOUT DYNAMIC COMPRESSION, SHALL WE? #828349
10/12/10 06:25 PM
10/12/10 06:25 PM
organ
maximum entropy Offline OP
organ
i did a little on line research to refresh/confuse my memory. any stock/super stock racers out there willing to divulge that little tidbit about their combination?
Re: LET'S TALK ABOUT DYNAMIC COMPRESSION, SHALL WE? [Re: maximum entropy] #828350
10/12/10 09:35 PM
10/12/10 09:35 PM
New York
polyspheric Offline
polyspheric  Offline
New York
It only matters if octane isn't high enough.
Even when this is true, it vanishes above about 4,000 RPM and has no effect on peak torque or power.
Boffin Emeritus
Re: LET'S TALK ABOUT DYNAMIC COMPRESSION, SHALL WE? [Re: polyspheric] #828351
10/13/10 05:22 AM
10/13/10 05:22 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Re: LET'S TALK ABOUT DYNAMIC COMPRESSION, SHALL WE? [Re: polyspheric] #828352
10/13/10 03:57 PM
10/13/10 03:57 PM
organ
organ
are you saying that the importance of dynamic compression ratio is overstated?
Re: LET'S TALK ABOUT DYNAMIC COMPRESSION, SHALL WE? [Re: polyspheric] #828353
10/13/10 04:20 PM
10/13/10 04:20 PM
UK
602heavy Offline
602heavy  Offline
UK
You got me real confused here.........the more the cylinder can ingest the higher the dynamic/cylinder pressure...
Re: LET'S TALK ABOUT DYNAMIC COMPRESSION, SHALL WE? [Re: 602heavy] #828354
10/13/10 04:37 PM
10/13/10 04:37 PM
organ
organ
true, but don't confuse cylinder pressure with dynamic compression ratio, which, like static c/r, is a calculated number that doesn't change.
Re: LET'S TALK ABOUT DYNAMIC COMPRESSION, SHALL WE? [Re: maximum entropy] #828355
10/13/10 04:54 PM
10/13/10 04:54 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
No.
Dynamic Compression is a fancy term to describe re-calculating compression ratio from the point the intake valve closes. The new compression ratio can then be used to calculate an estimated cranking compression pressure, and the cranking pressure can be used (roughly) to estimate the fuel octane requirements.
If the Dynamic compression is too low you will be giving up some low end power, if it is too high, the engine may need higher octane fuel to prevent detonation.
When the engine reaches a higher RPM where there is no reversion from the upward movement of the piston from BDC the dynamic compression has little meaning to how the engine will perform.
Re: LET'S TALK ABOUT DYNAMIC COMPRESSION, SHALL WE? [Re: 451Mopar] #828356
10/13/10 04:58 PM
10/13/10 04:58 PM
organ
organ
i'm really tempted to try a cam that's way too big (on paper) for my combo. just for the hellovit. the old hotrodder's proclivity!
Re: LET'S TALK ABOUT DYNAMIC COMPRESSION, SHALL WE? [Re: maximum entropy] #828357
10/13/10 05:27 PM
10/13/10 05:27 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
It's done all the time, just use alot of gear and converter so the engine does not notice the loss of low RPM torque.
Re: LET'S TALK ABOUT DYNAMIC COMPRESSION, SHALL WE? [Re: 451Mopar] #828358
10/13/10 05:50 PM
10/13/10 05:50 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Yup.
Got a smog 400 with a 509 cam and 120 psi cranking?
Use a 9" converter.
Use fade-out point of DCR varies with the build, but (as said above) once reversion stops the engine sees static CR, and perhaps more if VE is above parity.
What's it good for?
How happy you'll be with a low compression engine - the DCR numbers tell you how "soft" it will be at low speed, and a guess at if it will knock.
JM2¢? I think it gives a fair comparison of torque around 1,000 RPM to estimate how your new cam will affect your stall speed: multiply DCR × displacement at intake closing. If the number is down more than 10%, the idle will be worse and the converter may not do as much.
The reverse: if the cam is selected, tells you how much static CR you need to make it stronger off-idle.
Again: don't just pick the psi #, which is only the knock value. It's also acting on a much smaller cylinder.
Boffin Emeritus
Re: LET'S TALK ABOUT DYNAMIC COMPRESSION, SHALL WE? [Re: polyspheric] #828359
10/13/10 05:57 PM
10/13/10 05:57 PM
organ
organ
JM2¢? I think it gives a fair comparison of torque around 1,000 RPM to estimate how your new cam will affect your stall speed: multiply DCR × displacement at intake closing.It's also acting on a much smaller cylinder.
interesting perspective on the cylinder volume. i didn't (consciously) think of it that way. thanks.
Re: LET'S TALK ABOUT DYNAMIC COMPRESSION, SHALL WE? [Re: 451Mopar] #828360
10/13/10 11:11 PM
10/13/10 11:11 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
General question....
So can you raise or lower your dynamic compression with a camshaft change? Is that what happens with a more or less aggressive cam?
Michael
Re: LET'S TALK ABOUT DYNAMIC COMPRESSION, SHALL WE? [Re: maximum entropy] #828361
10/13/10 11:20 PM
10/13/10 11:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Do it, I do all of the time from what I`m told.
Re: LET'S TALK ABOUT DYNAMIC COMPRESSION, SHALL WE? [Re: Thumperdart] #828362
10/13/10 11:50 PM
10/13/10 11:50 PM
Cab_Burge Online work
Cab_Burge  Online Work
Software programs are written by people Some of those people have hands on knowledge and some don't. Some are writing programs based on theory, how fast will it go at the track is what I like to see Not on paper I don't want to brag, if your not testing by thrashing and developing new combinations your getting left behind
Re: LET'S TALK ABOUT DYNAMIC COMPRESSION, SHALL WE? [Re: SILVER67] #828363
10/14/10 01:43 PM
10/14/10 01:43 PM
organ
organ
Michael
yes. that and changing the static compression ratio. earlier intake valve closing, and/or higher static compression both raise the dynamic cr, and vice-versa.
Re: LET'S TALK ABOUT DYNAMIC COMPRESSION, SHALL WE? [Re: maximum entropy] #828364
10/14/10 02:21 PM
10/14/10 02:21 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Michael
don't even have to change the cam...just advance or retard it to change the intake close point....a low buck trick on stock 400's is to advance the cam 4-6 degrees, it boosts DCR and helps with low end torque by closing the intake valve sooner.
2017 Grand Cherokee Overland
Re: LET'S TALK ABOUT DYNAMIC COMPRESSION, SHALL WE? [Re: patrick] #828365
10/14/10 03:17 PM
10/14/10 03:17 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Dynamic ratio, is mostly controlled by cam timing events and is VERY important number to know, for certain applications. I mostly deal with the cranking number, but is all relative. For what I do, nitrous motors, I need to know this. If I have two pretty much identical motors and they both have static CR of 14.5:1, but one has a cranking psi of 160 and the other has 200, because of cam events, that will very much effect the way I tune the nitrous.
Monte
Re: LET'S TALK ABOUT DYNAMIC COMPRESSION, SHALL WE? [Re: maximum entropy] #828366
10/14/10 05:07 PM
10/14/10 05:07 PM
UK
602heavy Offline
602heavy  Offline
UK
Dynamic CR is calculated much the same as how static CR is calculated , knowing static CR will help net you a bench mark on what type cam the engine will use , dynamic CR #s WILL change throughout the rpm range of the engine , many have the misconseption DCR is a constant , if this were so to what benefit would it be? , DCR is a calculation of swept volume when intake valve is on it's seat , the higher the VE climbs the higher the DCR , or should i say ECR.
Re: LET'S TALK ABOUT DYNAMIC COMPRESSION, SHALL WE? [Re: 602heavy] #828367
10/14/10 05:43 PM
10/14/10 05:43 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I don't know the specifics, but after reading some stuff on fuel octane vs. static & dynamic CRs by a guy named Tim Wusz (I think) who used to work for Union 76 and moved to Rockett, it was obvious that it's a real balancing act to try to push the static CR too high w/ octane-limited fuel. Even the "big camshaft" band-aid approach only works up to a certain point in the RPM range (the example Tim W. gave in what I was reading was 7000), beyond which the engine was still probably going to encounter issues from insufficient octane.
Re: LET'S TALK ABOUT DYNAMIC COMPRESSION, SHALL WE? [Re: BradH] #828368
10/14/10 10:48 PM
10/14/10 10:48 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Because I deal with street engines I use the DCR fairly often. I think if you have a certain fuel type (meaning octane) to run, not taking into account DCR means you're overlooking a crutial ingredient. It's a much better way for me to predict the low speed potential for detonation. I also agree that as rpm rises it's importance is reduced. If you can run any fuel type you want, I dont think it's as critical because you can always use the fuel to stay away from the problems too much pressure for a given chamber brings.
