What timing setting for /6
#82817
07/01/08 06:54 PM
07/01/08 06:54 PM
I'd like to adjust the timing on my 65 dart. 225 /6. (1977?) The original repair manual says to set to 2.5. I think it was BTD but it could have been ATD. It's in the book I'll relook it up before adjusting it. However, the tab with the marks on it has 10 and 5 painted on on the other side of TDC from the manuals setting from a previous owner. and when reading a recent post at /6 forum. They were swearing by 16! which isn't even on the tab. http://www.slantsix.org/forum/viewtopic.php?t=27635&postdays=0&postorder=asc&start=75"The advanced timing comes in handy to complement the fuel correction. I have tried to run around 10 degrees but I get better economy at 16 degrees. It has a little crisper response to the throttle changes. The gentlemen that owns our local carb shop swears that 16 degrees initial is the ticket for a stock or nearly stock slant in terms of best mileage." So how do I know what to set it at? I'd like to go for MPG versus power.
Re: What timing setting for /6
[Re: mopowergtx]
#82819
07/01/08 08:17 PM
07/01/08 08:17 PM
Posts: 20,183 Park Forest, IL
slantzilla
Park Forest, IL
If you really want to get fancy you can weld the advancer slots partially shut. Then you can run a ton of initial and still limit total to keep out of ping.
I normally ran at least 15 initial on a street car. Setting it by the book will really make them doggy.
[Re: slantzilla]
#82820
07/02/08 01:52 AM
07/02/08 01:52 AM
Thanks for the answers. I have a few quick clarifying questions.
BTDC is advanced timing right? ATDC is ? timeing
is initial timing the timing at the warmed up "curb" idle?
What is and how do I check total timing? is that just reving the engine to 3000 and checking the timing?
I didn't know that timing changed with rpm. if so that must be why adjusting the curb idle first is important.
"dieseling on hot days" is that where the car continues to run even after turning it off? I thought that was a sign of a vacuum leak though of course more than one thing can be a cause just confirming my old logic.
#82821
07/02/08 06:02 AM
07/02/08 06:02 AM
Posts: 3,075 Eastern Ohio
mopowergtx
Eastern Ohio
Before Top Dead Center BTDC
Dieseling is running on a few seconds after you shut off the key
Intial timing is the timing you are setting while idling warm.
Yes the timing changes while its running. Through your vaccum advance and internal mechanical weights. If your unfamiliar or uncomfortable checking total timing just set the intial timing at 10 degrees BTDC(which is what the timing tabs on the engine are marked in)like normal and keep increasing it a degree at a time till you reach a sweet spot for your application. Of course after each adjustment you need to drive it awhile to see how it does on the road not just idling in the driveway. Or set it at 10 to 15 degrees BTDC and forget about it you'll be close enough.
[Re: mopowergtx]
#82822
07/02/08 11:35 AM
07/02/08 11:35 AM
"set it at 10 to 15 degrees BTDC and forget about it" OK this sounds about like what I was going to do for a while anyway. I really should be working on my house and not my car but I'm so tired of not driving my car. With the price of gas though it makes sense to get it tuned up to optimum and keep fiddling. I just need to get a decent baseline mpg to start though. I'm getting like 12mpg which I just can't afford. I know there are other things to check on as well but wanted to adjust idles, timing and valves first.
so if the timing changes with rpm what idle speeds should I be shooting for if timing isn't by the book anyway? I think the book calls for 500 or 550 curb idle and 700 fast idle. does that seem right? i seem to recall people saying the fast idle isn't as important as long as it starts well in cold weather.
[Re: mopowergtx]
#82825
07/03/08 03:54 AM
07/03/08 03:54 AM
18?!?!?!?! 18!?!!??!!? I can't afford my commute at 18. I need atleast mid 20s. Can I expect that if I convert to a super six setup? I was thinking I'd do that anyway. It might not be worth the time to tune the 1920 if I'm only going to get 18 anyway. this post had givin me some hope. http://www.slantsix.org/forum/viewtopic.php?t=27635perhaps it's better to start with a 2 barrel anyway. Since I had just bought my timing light I could take it back and put the money toward the needed one but I don't know which to get: https://board.moparts.org/ubbthreads/show...e=0#Post4527819
