68 440 engine restoration #825277
10/08/10 09:17 PM
10/08/10 09:17 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Looking for an idea on what a job like this would/should cost. Taking a 71 440 and doing a complete rebuild using a KB piston (Quench built W/346 heads)and balanced.Needs to include these parts that need to be bought. A stock oil pan,intake,exhaust manifolds, all pulleys for use with A/C, power steering brackets, alternator brackets, alternator,fuel pump,water pump, after market Edelbrock carb? and all painted/restored to look like an engine put in a 68 Charger. This is to include all machine work and assembly/paint of engine. Engine is out of car but is to be ready to drop in and run.
Dan
Re: 68 440 engine restoration [Re: mopar4ya] #825278
10/08/10 09:30 PM
10/08/10 09:30 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I'm confused? a 68 or a 71 440?
At any rate I'd guess a build a 440 like you are shooting for could easily run 7-10K depending on machine work, type of internal parts, and how many accessories you need to go buy to complete it (manifolds etc.).
Re: 68 440 engine restoration [Re: mopar4ya] #825279
10/08/10 09:56 PM
10/08/10 09:56 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
If you pay someone to do it all, it could cost you a lot. I would say $2250 major parts (include Cam, lifters, springs), $600 rings, bearings, gaskets, hoses belts and miscellaneous, $2000 machine work including but not limited to, all the cleaning, sizing rods, grinding and polishing crank, balancing, probably a .030 pressing the pistons off and new ones on, overbore, honing, valve job, milling the heads .020 (you should check the deck height if you want to ensure good compression) and at least about $750 to completely assemble and paint. Just figure $6000 or more plus the pulleys and brackets ...which you have to find
Re: 68 440 engine restoration [Re: ScottSmith_Harms] #825280
10/08/10 10:14 PM
10/08/10 10:14 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Hi Scott,
I know this is a loaded question. The guy brought me a 71 engine with a hodgepodge of parts on it. Everything from 1971 to 1977 including a truck oil pan. I can use the block,heads and internals. But I need to come up with everything else to make it look close to a 68 engine. He wants to go with a set of Mopar valve covers, don't care about what I use for a carb but it needs to bolt on a stock looking 68-69 intake and I need to come up with the rest of the parts to make it look / work in his 68 Charger that has AC and power steering.
I will be doing a complete rebuild of the engine with KB pistons,Felpro gaskets,Clevite bearings, probably a Compcams cam kit, all name brand parts. Then detailing and painting the engine.
I know and he knows it will not be 100% correct in every way, but he wants it to look some what right.
I told him he would have around $3500-$4000 in it and he is trying to beat me down.
I think this is very fair and wondered what the rest of the country is getting for something like this.
Dan!
Re: 68 440 engine restoration [Re: mopar4ya] #825281
10/08/10 10:53 PM
10/08/10 10:53 PM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
If you have to come up with the rest of the parts, I would say 4K is close. We have a bunch of time in the 68 we are about to finish. We had to make all parts look correct for 68 except we added a sanden compressor in place of the "Big V-Twin".
Brad
Dorn Autocraft
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: 68 440 engine restoration [Re: BradD] #825282
10/08/10 11:31 PM
10/08/10 11:31 PM
Warrenton, VA
Warrenton, VA
Let us know how much $ you end up in it?
Re: 68 440 engine restoration [Re: mopar4ya] #825283
10/08/10 11:59 PM
10/08/10 11:59 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Considering how machine work alone can push to over $1000 depending on what needs done.
To make a fair comparison, I built a 1971 340 2 years ago. My customer had over $4000 in a small block, and only about $500 of that was labor. With machine work costs, I put close to a grand in the heads alone,, cam, springs and all new valves,keepers and retainers .
Pistons and rings were almost $500, just the basic misc pieces ( gaskets, timing set, oil pump etc etc) was nearly $500
not to mention finding 1968 A/C parts is not an easy task
Re: 68 440 engine restoration [Re: gtx6970] #825284
10/09/10 12:16 AM
10/09/10 12:16 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
If the guy wants to grind you, tell him $2000 + parts & sublet (machining, balancing, etc) expenses; that way if he supplies junk it's not gonna hurt you, and if he gets involved in hunting parts he'll better understand the expenses.
Re: 68 440 engine restoration [Re: mopar4ya] #825285
10/09/10 12:19 AM
10/09/10 12:19 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Dan, don't know if this is of any help but this is my '68 383 road runner with A/C and stock valve covers. It actually has an Edelebrock aluminum intake manifold with the Edelebrock and info ground off with a Holley Street Avenger carb, a MSD ignition coil painted black, a Mopar Performance electronic distributor with the wiring inside of the stock wiring harness and the ECU inside of the car under the dash (you can see the red lead at the bulk head junction block by the master cylinder where it goes inside of the car
Comp cam, springs, good compression, etc., inside the engine but all made to look as stock as possible....runs good and it's driven a lot as can be seen by the dead bugs on the condenser
And yeah I'd say $3500-$4000 would be the range to DO IT RIGHT!
MikeR
Re: 68 440 engine restoration [Re: gtx6970] #825286
10/09/10 12:32 AM
10/09/10 12:32 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Yeah tell me about it Bill BTW THANKS Bill!
From the radiator cap to the heater and breather hoses, A/C brackets, compresser mount, to those wire harness clamps and straps, bolts and lots, lots more there's a bunch of A+M Hightech Automotive in this engine bay and car, thanks Bill
MikeR
Re: 68 440 engine restoration [Re: A12] #825287
10/09/10 01:12 AM
10/09/10 01:12 AM
Warrenton, VA
Warrenton, VA
Mike, he's talking about only having the block, crank, rods and heads and doing a first class machine job with everything else bought new and paying someone to do the work. I'll bet it will cost him close to double what you spent in yours because you did a lot of work yourself.
Re: 68 440 engine restoration [Re: RoadRunnerJD] #825288
10/09/10 01:56 AM
10/09/10 01:56 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
John you and everyone here are absolutely right it will take more than what I have into my 383 and now that I re-read Dan's post it's going to take more than the $4k he quoted. What I have into the A/C if I hadn't gotten the help from a lot of Moparts members () would have been a about 1/3 of what Dan quoted alone, and then add in finding correct exhaust manifold, brackets, pulleys.........yikes Dan if you can do it NOW because there is no way you can do all of what you plan to do for $4,000 and for sure not anything less. I had most of my A/C components and still that was a good chunk of change, doing the engine and doing it right well I was wrong it's going to be a lot more than your quote. I just looked at a Mopar engine builder's service work price quotes and you can have a couple of grand in just cleaning, machining, prep work and that doesn't include parts (i.e., cam, pistons, rings, carb, bearings, gaskets, distributor, wires, hoses, etc.) assembly, getting it running and then tuning..... and I'm about to start on another project thanks for the wake-up call
Dan, and this guy is trying to beat you down on the price, he needs a wake-up call too, what's his number I call him at 5 am his time
MikeR
Re: 68 440 engine restoration [Re: A12] #825289
10/09/10 04:02 AM
10/09/10 04:02 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Best advice I can give you is to tell the guy to find someone else.. If he's beating you up now your better off to heed the warning sign...
Re: 68 440 engine restoration [Re: mopar4ya] #825290
10/09/10 10:08 AM
10/09/10 10:08 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
Dan, I have a 73 440 in the shop right now that is getting built to 67 appearance.KB pistons +30, not my choice, ARP bolts and recon stock rods, 10/10 crank and balance assembly, 452 heads w/ stainless valves, needed exhaust guides only complete Lunati cam, lifters, springs and reatiners, rebuilt carb, ect in other words a complete do over. Parts are cost plus 10 and giving my labor away as is my habit he'll have almost right at 3500 so for you to eat better than I do 4000 is plenty fair. Take care, Holgar
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: 68 440 engine restoration [Re: 1_WILD_RT] #825291
10/09/10 10:16 AM
10/09/10 10:16 AM
Warrenton, VA
Warrenton, VA
Even if he's a good friend, I've done favors for friends and it usually costs me. If it was me, I would do an estimate in writing for all the parts that you can get prices for and get a quote from your machine shop. Dan, he can't pay you enough just for your time to find the correct valve covers, brackets and pulleys on top of the leg work just to get the rest of the parts. I'd want to have all the parts to his satisfaction and be paid for them as I go before I started.
Re: 68 440 engine restoration [Re: mopar4ya] #825292
10/09/10 04:52 PM
10/09/10 04:52 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
The 440 in my 68 Charger is actually a 71 block dressed as a 68. I have the correct intake, valve covers, fan, avs carb restored by Scott at Harms automotive, correct H.P. exhaust manifolds, correct spark plug wire looms and heat shields, throttle cable bracket, throttle spring bracket, throttle spring, heater hose bracket, water pump housing, oil cap/breather, and aircleaner. In my opinion the 71 block is a better block because of the reinforcing rib cast into it. All the detail items we sell. The total cost for me was less than $2,500.00 including the cost of the 71 440 engine. My engine retains its stock bore and pistons. My engine machinists/builder treated me right. They are called Outrageously Vintage, a Mopar oriented machine shop (www.outrageouslyvintage.com). (Thanks Bob and Cici) The block recieved a few simple oiling mods and the heads (906) were done right with a clean up of the ports, bronze guides, positive seals, new valves and springs. The seats were hardened the good old fashion way with heat and cooling with oil They are building my 426 Hemi as we speak. As good as my 440 runs it's coming out over the winter and the Hemi is going in! Good luck with your project.
Nobody gets in to see the wizard!
Ain`t no way!
Ain`t no how!
Re: 68 440 engine restoration [Re: badblack68] #825293
10/09/10 05:31 PM
10/09/10 05:31 PM
Warrenton, VA
Warrenton, VA
Nice! In Dan's case, used exhaust manifolds $300, cam, lifters, springs $300, used intake $100, used 440 AVS carb $150, carb restoraton $350, rings, bearings, gaskets, misc $500, used 68 valve covers needing work $75, water pump, oil pump $100, 402 oil pan $125, valve job and assemble heads $300, KB pistons $300, boring, honing, grinding and polish crank, balancing, machine work, install can bearings, size rods, etc $$900... if you're lucky, assemble everything and paint $750 nuts and bolts intake, exhaust, heat shields, wire separators, more than you think $400, starter?, motor mounts? That's almost $4500 not counting pulleys, brackets, a/c stuff and chasing down parts.
Re: 68 440 engine restoration [Re: RoadRunnerJD] #825294
10/09/10 06:34 PM
10/09/10 06:34 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
I listed everything out on paper today the best I could. There is a lot of guesstamating here. All the machine work will be done in my shop, except the balancing.
The above post is almost dead on to what I added up. When I was done I was a little over 5K and would still need pulleys and a few other things I know I missed. He wants a new starter, alternator,and fuel pump. I told him up front I wasn't going to do anything with his A/C, that was up to him.
Holgar, I,m done doing this work for nothing!! unless it's for a friend. If I want to work on sht for free I have enough of my own junk to last me and you a life time LOL! Please don't comment on that .
How many hours would it take to build a quench motor,glass bead all the parts,metal finish all the parts and have everything painted? I am figuring 25 hours, and I know it will take longer that that.
Dan
Re: 68 440 engine restoration [Re: mopar4ya] #825295
10/10/10 10:43 AM
10/10/10 10:43 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Hi Scott,
Dan!
3500-4k is a STEAL for that job especially considering the work required to do a quench piston setup PROPERLY and get the most out of it . If he is balking at that price I would tell him to come and get his parts and GOOD LUCK.
Re: 68 440 engine restoration [Re: badblack68] #825296
10/10/10 10:50 AM
10/10/10 10:50 AM
JohnRR Offline
JohnRR  Offline
How the heck did you do it for $2500 using OV when they advertise the heads you talk about in the for sale section from time to time for 900-1000??? So you built the rest of the engine (LABOR for machine work) and hunted down absolutely everything you needed for 1600 ???
