Re: Lakewood Traction Bars
[Re: slantzilla]
#824933
10/10/10 08:16 AM
10/10/10 08:16 AM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Ran them on my Dart just for fun (got them in a trade) and my sixty foot dropped. Most Mopar guys just automatically dismiss them because they heard from someone that they don't work, I prefer real world trial and error instead of hearsay.
I'm a firm believer in the "if it works then it works" philosophy (so is Yogi Beara), BUT I'm curious as to why thesuperstock guys/Ramchargers always used snubers instead and all the MP books state not to use tractions bar, only snubbers?
Probably because they ran SS springs. Traction aids are not supposed to be used with them other than a snubber.
Showing my age a bit here. I think the SS springs came out with the 68 Cuda and Dart. Later it all went link bars. I was wondering what they did pre 68. Was it trac bars, snubber or nothing?
[Re: keith airgrabber]
#824934
10/10/10 08:45 AM
10/10/10 08:45 AM
Challenger 1
Cincinnati, Ohio
I have mine on too. They work and I have always thought they looked cool.
I'm sorry but I always thought they looked dorky. Look how low to the ground yours are. lol Plus a pinion snubber weighs alot less.
[Re: Challenger 1]
#824935
10/10/10 09:33 AM
10/10/10 09:33 AM
Posts: 2,578 sweden
1Fast340
sweden
you dont think the front springmounts ataching to what litle frame is available under these cars would be a better place to direct all the rotational forces from the rear axle compared to putting all that force straight up into the much thinner floor?
[Re: 1Fast340]
#824936
10/10/10 10:35 AM
10/10/10 10:35 AM
torkrules
I'm neurotic
I'm neurotic
Someone must know what the Mopar engineers had in mind when they specified the snubber and said not to use the trac bars. I know we are killing this topic but I'm a sucker for these two sided arguments. I'll see what I can dig up from my old books.
[Re: torkrules]
#824937
10/10/10 12:55 PM
10/10/10 12:55 PM
Posts: 277 Southwest, Mi.
74Cuda
Southwest, Mi.
Traction bars are for GM cars and pinion snubbers are for mopars. I never had a GM get me of the line so I believe that Mopar engineers know what they are doing.
[Re: Challenger 1]
#824938
10/10/10 01:20 PM
10/10/10 01:20 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
I know...it's GREAT. Guys see ours and think we don't know anything. Their attitude gets all condescending...ROFL
[Re: torkrules]
#824939
10/10/10 01:21 PM
10/10/10 01:21 PM
Posts: 2,578 sweden
1Fast340
sweden
yep its intresting when looking at stuff deeper than just saying "this is the way it is because thats how it has been done foreverer" only real good reasons i can see is that it would help keeping the axletubes from twisting in the centersection, it would also help in alowing the rear suspension to still work side to side so to speak,while tractionbars should be able to lessen boddy roll when under full power, but im not an engineer:) would be very intresting if you found any deeper info on this
[Re: 1Fast340]
#824940
10/10/10 02:29 PM
10/10/10 02:29 PM
torkrules
I'm neurotic
I'm neurotic
Ok, according to Larry Shepherd and the old Direct Connection book (see that's how old I am), he says, traction bars are not recommended. So there not saying "DO NOT USE THEM". The reason stated is that they may cause the axle tubes to bend or undesirable handling. They should NOT be used with super stock springs (goes without saying).
Not sure how they would bend the axle tubes other than the fact they are outboard, but I would think Fords and GMs would have the same problems. As far as ill handling, well superstock springs can do that for you too.
The snubber is optional on the automatic but should be used for safety. They say it's a must on 4 speed cars. They recommend re-enforcing the floor.
[Re: torkrules]
#824941
10/10/10 02:50 PM
10/10/10 02:50 PM
Posts: 2,578 sweden
1Fast340
sweden
good info there problem with the axletubes are probably from the fact that the pinion want to climb the ringgear and that its more sensible to stop this motion by having a snubber stop the movement upwards compared to having the tractionbars holding the tubes from rotatatin while the front of the centersection wants to go up, this also explains why cars with a torque arm hooks so well once everything is right
[Re: torkrules]
#824942
10/10/10 03:17 PM
10/10/10 03:17 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
How well traction bars work is directly related to the amount of thought and effort in tuning them. Just slapping a pair on is only the first step. Clamping or unclamping the springs and trimming the snubbers to set preload must also be done for them to work well. But at least you can set preload from side to side to prevent the torque from trying to pick up the passenger side tire, which helps traction and helps keep the car in a straight line. If you can tell me how to preload one side with a pinion snubber, I'm listening. That is, how without using SS springs that are mismatched from side to side, ride unnecessarily hard, and affect normal handling. Leaf springs by nature aren't suited to transmit torque - by the time they are stiff enough not to wrap up they are way too stiff to let the back work. A softer spring package with properly tuned slapper bars can work extremely well with a little tuning. And no, I didn't forget about shocks; that's a whole other topic.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: 1Fast340]
#824943
10/10/10 03:18 PM
10/10/10 03:18 PM
Posts: 1,978 Southaven, MS
BossRide
Southaven, MS
Has anyone ever really bent an axle tube on a street car? I'd say for most cars, they are a good way to control spring wrap or wheel hop.
The Blue Goose
My instagram: Bossride
[Re: 1Fast340]
#824945
10/10/10 03:56 PM
10/10/10 03:56 PM
BossRide
Southaven, MS
Are the axle tubes pressed in like an 8.8" Ford? If so, can you weld them to the housing?
The Blue Goose
[Re: Evil Spirit]
#824947
10/10/10 06:00 PM
10/10/10 06:00 PM
BossRide
Southaven, MS
Ahhh.. I just got an 8 3/4... didn't really pay attention to the differences...
The Blue Goose
