440 in a 97-newer Dakota? #824290
10/07/10 11:32 AM
10/07/10 11:32 AM
MN
JERICOGTX Offline OP
MN
My buddies kid wants to build a 97 or newer Dakota and install a 440 in it. Does anyone even make motor mounts, or headers for this? Also how big of a tire can fit in the wheelwell before tubbing it? For drag racing what can be done to the front suspension? Do these things have rack and pinions or steering boxes? Never looked at one before...
Thanks.
Jeff
69 GTX 68 Road Runner
Re: 440 in a 97-newer Dakota? [Re: JERICOGTX] #824291
10/07/10 11:43 AM
10/07/10 11:43 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Jeff, http://www.dakota-durango.com/forum/ is a good source for research.
To answer a few of your questions:
They have rack and pinion steering.
As far as I know, no motor mounts/headers, everything will have to be fabbed.
Biggest rear tire without tubbing will prob be 9".
A few notes:
The lug pattern will be an issue on rim selection.
They are very heavy!
Those are some of the reasons I chose a Gen II (the 97 - 06 (I think) are Gen III)
Re: 440 in a 97-newer Dakota? [Re: TheOtherDodge] #824292
10/07/10 12:10 PM
10/07/10 12:10 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
Kayfysh had a 440 in his truck.
IIRC he used abody fenderwell headers.
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: 440 in a 97-newer Dakota? [Re: BBR] #824293
10/07/10 12:46 PM
10/07/10 12:46 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
engine-swaps.com has some parts i believe.
Re: 440 in a 97-newer Dakota? [Re: blownzoom440] #824294
10/07/10 04:07 PM
10/07/10 04:07 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Re: 440 in a 97-newer Dakota? [Re: ProSport] #824295
10/07/10 04:40 PM
10/07/10 04:40 PM
MN
MN
Does anyone know what others are doing for the 6 bolt hub to 5 bolt hubs on the front end? Rear is no big deal since we will be installing ladderbars, and a Dana60.
Re: 440 in a 97-newer Dakota? [Re: JERICOGTX] #824296
10/07/10 04:48 PM
10/07/10 04:48 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
I'm an idiot. I forgot Kayfysh's truck was a 94 or so.
70cuda383 also has one.
RMRW 2018
RMRW 2020
Re: 440 in a 97-newer Dakota? [Re: BBR] #824297
10/07/10 04:54 PM
10/07/10 04:54 PM
Maryland
Sick 660r Offline
Sick 660r  Offline
Maryland
the newer dakotas are a pain in the ass. I just bought a 94 because of this. I have a 10" slick on my 2000 with stock 15" dakota rims with plenty of room for more. There is not much out there to change the lug pattern up front but you could have the hubs and rotors drilled for 5 lug. A 440 will be a tight fit and will need custom headers.
2000 dakota 418 magnum paxton novi 2k T56
Re: 440 in a 97-newer Dakota? [Re: TheOtherDodge] #824298
10/07/10 04:57 PM
10/07/10 04:57 PM
Maryland
Sick 660r Offline
Sick 660r  Offline
Maryland
A few notes:
gen 2 should be 91-96 and gen 3 is 97-04. A second gen is so much easier after having both.
Re: 440 in a 97-newer Dakota? [Re: Sick 660r] #824299
10/07/10 08:44 PM
10/07/10 08:44 PM
southwest Alabama
challenger73400 Offline
southwest Alabama
I have a 97 but I did a lot of work to get it like you see it.I used S-10 control arms, spindles and brakes. I cut the dodge control arms and welded the S-10s to it moving each front tire in two inches and raking the caster back to 7 degrees. This allowed me to drop the front end.
I had to fab my headers and mounts. I used a 400 block and moved it back 6" trough the firewall and stroked it to 470.
Re: 440 in a 97-newer Dakota? [Re: TheOtherDodge] #824300
10/07/10 09:09 PM
10/07/10 09:09 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
A few notes:
You can run a 13.5 on a Gen III, I use 11" Hoosier slicks on 10" rims.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: 440 in a 97-newer Dakota? [Re: challenger73400] #824301
10/07/10 09:09 PM
10/07/10 09:09 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
That right there is why I have a Gen III.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: 440 in a 97-newer Dakota? [Re: Adobedude] #824302
10/07/10 09:57 PM
10/07/10 09:57 PM
MN
MN
Adobedude, what did you do for spindles/hubs for 5 lug rims?
Jeff
Re: 440 in a 97-newer Dakota? [Re: Adobedude] #824303
10/07/10 10:51 PM
10/07/10 10:51 PM
Maryland
Sick 660r Offline
Sick 660r  Offline
Maryland
you can keep your pain in the ass gen 3 and ill keep my easy gen 2
Re: 440 in a 97-newer Dakota? [Re: JERICOGTX] #824304
10/07/10 11:29 PM
10/07/10 11:29 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Jeff
Those are 6 lug Bogarts.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: 440 in a 97-newer Dakota? [Re: Sick 660r] #824305
10/07/10 11:30 PM
10/07/10 11:30 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Hater.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: 440 in a 97-newer Dakota? [Re: Adobedude] #824306
10/08/10 06:19 PM
10/08/10 06:19 PM
okla.
sam64 Offline
sam64  Offline
okla.
i put 5 lug rotors on a 2000,i beleive they were off an 88 model.
Re: 440 in a 97-newer Dakota? [Re: sam64] #824307
10/08/10 07:28 PM
10/08/10 07:28 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
No you didn't, that's an impossible swap. I would start here to get an idea of the swap: http://www.bigblockdakota.com/ Thats GregZ's website, he also runs http://www.magnumhp.com/ which has some parts available for the swap. Someone mentioned www.dak-dur.com I would stay away from that place, they are going through a complete uproar over powers that be and everyone is leaving and deleting their info. I AM NOT saying that because I run a site, just giving you a heads up. Now, on my site I have a write up on some stuff that barely gets talked about when doing a small or big block carb swap into these trucks. You will need to sign up then read this thread: http://www.racemagnum.com/showthread.php?t=3119 As for 5 lug rotors, you will need custom hubs made or have your hubs and rotors redrilled for the 5 lug pattern. Rear end I would just swap in an 8 3/4" or 9".
