8 seconds and broke
#823082
10/05/10 11:41 PM
10/05/10 11:41 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
Most everyone read the issues I had at norwalk, so tonight I decided to take the car to ORP and see if all my findings corrected the issues with fuel pressure and timing.... First pass off the trailer 8.97 at 157....pretty nice I thought. Car pulled well, hooked good with a 1.37 short time and 5.82 @123 at the 1/8th....
So My buddy Phil (philbilly) decided it was time to play with the boost controller so we could start to make some more steam in the first part of the track. Now mind you, he is the crew chief for Corey Mac, and has a very fast 4.20's in the 1/8th nitrous mustang so I dont mind him helping me out... so we set up a map where if the car was making 2 lbs we turned it up to 4 and if it was making 5bs we turned it up to 10 and if it was making 15 lbs we turned it up to 20 so we should see some good gains, but we were not just cranking the thing up to max volume.....this is where it gets good.....
Stage the car, put it on the tbrake, and I can tell its makin more power because I can feel it pushing thru the brake a little bit....light goes green and for the first time in the car I thought holy sh%t this is gonna be fun, all I can see is sky, all I can hear is the whistle of the turbo, and in 1.03 seconds according to the racepak, it was all over, car comes down hard and huge bang, clunk, clunk, clunk turn the car off and roll towards the wall. thoughts run wild...its all over, there are gonna be bill miller rods all over ORP....Copes transmission is gonna have a chunks hanging out....wait, do I still have both feet, ok good.... is it the flexplate, u-joints....what could it be. Jump out of the car and there is not a lick of fluid on the track...nothing I can see is broken, 4 wheeler pulls up and tows me back to the pit...clunk, clunk, clung, grind, clunk clunk.... get back and start her up to investigate....cars cranks ok, starts ok...put her in gear, drive shaft spins and thats it.....clunk clunk clunk.....I blew up the rear end....Dana S60 with a tru-trac and 3:55 gears.... 35 spline axles....not sure whats broke.....but its effin broke.... Tomorrow a call to DTS to see what they want me to do.... Mike up there was certain that with a radial street tire and a turbo I wouldnt brake that tru-trac, but it could be ring and pinion I guess. Time will tell.
So we pull the racepak to see what it shows and the boost controller must not have worked as planned. we left at 4lbs like anticapated and in 1.03 seconds it ramped to 24lbs of boost, which I know by dyno experience, thats about 1250hp and 1000ft lbs of torque... it felt amazing, like I was on a ride to outerspace....for a brief second.....
So its broke, and next year...it will be faster!!!!!!
Re: 8 seconds and broke
[Re: blownzoom440]
#823085
10/06/10 05:11 AM
10/06/10 05:11 AM
Posts: 1,845 Tampa
DusterDave
Tampa
The silver lining is, rear ends aren't as expensive as engines. Looking forward to hearing what actually broke inside.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#823086
10/06/10 08:14 AM
10/06/10 08:14 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I'll tell you now that that rear wont survive in that car. Get a strange ultracase 9 inch with large pinion shaft upgrade. When you put that much torque to a rear with a ratio that low, than add to it a hard street gear, the outcome will be continuously disasterous. Dont spend another dime on that rear if you want to go faster. You can get large pinion 9 inch pro gears in 3.50,3.60,3.89 etc..
[Re: DusterDave]
#823087
10/06/10 08:25 AM
10/06/10 08:25 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Noooo doubt.
[Re: joshking440]
#823088
10/06/10 10:27 AM
10/06/10 10:27 AM
Posts: 2,648 GA
Boosted
GA
Man I hate that happened but dang what a car you have.....
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
[Re: Boosted]
#823089
10/06/10 12:34 PM
10/06/10 12:34 PM
Posts: 200 AB
Efidart
AB
Haven't had any problems with 3.89 non pro gears in a 9" strange center section on the street and going low 8's with more weight. Wouldn't run anything but a spool in your car, and my money is on the tru trac being in pieces!
TT Predator headed 572 7 Second Street Car. Fastest Mopar Drag Week 2015 Fastest Mopar & Dodge Drag Week 2017 Pro Street Power Adder Champion Drag Week 2017
[Re: goody340g]
#823090
10/06/10 01:42 PM
10/06/10 01:42 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
that sucks, next yr maybe i can round up the parkers and my dad and bro. and come see that beast go down the track.
Next year I will be at Martin a little more...I told Sean that I was gonna put his dragster on the trailer with a street car in a heads up race....
[Re: joshking440]
#823092
10/07/10 12:27 AM
10/07/10 12:27 AM
Posts: 32 Brunswick Ohio
dusta340
Brunswick Ohio
get that rear fixed and bring to my indoor track aka chassis dyno and save lots of time getting that thing fiqured out
[Re: TRENDZ]
#823093
10/07/10 08:40 AM
10/07/10 08:40 AM
Challenger 1
Cincinnati, Ohio
I agree, time for a 9"...
[Re: joshking440]
#823095
10/08/10 02:37 PM
10/08/10 02:37 PM
Posts: 5,067 Orlando Florida
blown572dart
Orlando Florida
.....I blew up my rear end
Your lucky because I would have BROKE your rear end ![](/ubbthreads/images/graemlins/eeek.gif)
Fix it so when I get there it is in good working order. ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: blown572dart]
#823096
10/08/10 05:15 PM
10/08/10 05:15 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
The only guy I know (other than richard simmons)with the fascination of the rearend.......
[Re: joshking440]
#823098
10/08/10 09:44 PM
10/08/10 09:44 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Josh, what was your trap RPM on your 8 sec pass?
[Re: DusterDave]
#823099
10/08/10 09:50 PM
10/08/10 09:50 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
[Re: joshking440]
#823100
10/10/10 11:15 AM
10/10/10 11:15 AM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Could it have been a mistake on the programming? You went from 2 psi to 4 psi and the car hit 24 psi.
I imagine it was a monster kick in the backside when you let off the brake. Too bad it ended quickly.
