Re: pinion angle
[Re: GEORGE68HEMIRR]
#822628
10/05/10 08:03 PM
10/05/10 08:03 PM
Posts: 5,080 organ
maximum entropy
organ
at the risk of being flagellated by the 'pinion master, -5 is ok. i run mine about -6 on the street with ss springs and it has been very reliable. i do get a little vibration at high speed cruise, but that's just the way it's got to be until i backhalf it and get the angle closer to zero.
Re: pinion angle
#822630
10/05/10 09:01 PM
10/05/10 09:01 PM
Posts: 5,080 organ
maximum entropy
organ
-7 is near ideal with ss springs. it won't be the smoothest at high speed cruise, and it may need ujoints every couple of years, but i have had no problems at -6 (actually more like -6.5).
Re: pinion angle
#822632
10/06/10 12:11 AM
10/06/10 12:11 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
so if i use the pinion degree indicator on my pinion yoke to measure degrees i would need plus 2 degrees on my pinion to get minus 2 degrees nose down which is ideal for the street and occasionally for the track.....what do you think?
No, plus 2* pinion will get you 3* nose down pinion angle compared to your 5* down tranny centerline angle. mike
Re: pinion angle
#822634
10/06/10 12:04 PM
10/06/10 12:04 PM
Posts: 5,080 organ
maximum entropy
organ
i wouldn't run -2 with ss springs at the track. that's a driveline killer.
Re: pinion angle
[Re: Sport440]
#822636
10/06/10 08:34 PM
10/06/10 08:34 PM
Posts: 4,210 New York
polyspheric
New York
BTW: to make a "degree" sign, press & hold the ALT key, while typing 0 1 7 6
Boffin Emeritus
Re: pinion angle
[Re: polyspheric]
#822637
10/06/10 10:01 PM
10/06/10 10:01 PM
Sport440
Canton, Ohio
Okay 45 ALT key 0176
45, nothing
Okay 45 ALT key 0 1 7 6
45, nothing, alright quit screwing with me.
Re: pinion angle
[Re: Sport440]
#822640
10/07/10 01:14 AM
10/07/10 01:14 AM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
45, nothing
45º....45º....45º... 45º
Re: pinion angle
[Re: 64Post]
#822641
10/07/10 01:35 AM
10/07/10 01:35 AM
Sport440
Canton, Ohio
45, nothing
Allright, Even if I do figure out how to create a degree symbol. Im still going to just use this
45*... 45*...45*...45* Get used to it. mike
Re: pinion angle
[Re: Sport440]
#822642
10/07/10 11:01 AM
10/07/10 11:01 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Every time I read one of these pinion angle posts my right nipple starts to bleed.
Measure trans. Make pinion the same, as in parallel. Tip the front down an additional 5*. That's 5* pinion angle. Done like dinner.
Free advice and worth every penny... Factory trained Slinky rewinder.........
Re: pinion angle
[Re: DoctorDiff]
#822645
10/07/10 03:26 PM
10/07/10 03:26 PM
Posts: 878 hudson valley n.y.
GEORGE68HEMIRR
super street
super street
hudson valley n.y.
Normally, a true 4 degree negative pinion angle is the maximum I recommend. This is relative to the transmission center-line, not to the driveshaft or the ground.
I like to see 2 degrees negative for a street car.
If the transmission slopes downward 5 degrees toward the rear, the pinion should slope upward 2 degrees toward the front.
This is referred to as 3 degree negative pinion angle. I consider 4 degree negative to be the maximum for a true street car. thank you doctor diff....thats what i am going to do.....i will report back when i am done with the test drive.....3 degrees negative pinion angle
