Re: My first full restoration attempt - 1970 'Cuda
[Re: jbc426]
#822358
03/16/11 11:24 AM
03/16/11 11:24 AM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
After priming, sealing, the TX9 base coat and several clear coats.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#822360
03/16/11 11:26 AM
03/16/11 11:26 AM
jbc426
West Coast, USA
...and door jamb. Because there was so little wear and virtually no rust, I decided to leave the interior as the factory had sprayed it. The car had factory undercoating, which was in remarkably good shape as well. Later, I used some of Resto Ricks undercoating to touch up some spots that needed it and then cleaned and repainted it. Sorry Dave, there were no Q-tips injured in the touch up of the factory undercoating.
[Re: jbc426]
#822361
03/16/11 11:39 AM
03/16/11 11:39 AM
jbc426
West Coast, USA
The car was finally back at my house for the long process of bodywork, priming and blocking and priming and blocking and priming and blocking......etc, etc.
The body was pretty straight to begin with....or so I thought. We spent just over 200 hours with long boards and such. I never thought it would end.
[Re: jbc426]
#822363
03/17/11 12:16 PM
03/17/11 12:16 PM
Posts: 4,227 Bloomington, IN
HoosierTA
Bloomington, IN
Deja vu! I was able to get back my Challenger R/T. it has the same damage to a 1/4 from an evening when I saw my rear M-50 come rolling past me! It has alluminum slots, with long shank lug nuts, that liked to loosen on the driver side.
Made a sick feeling in the stomach, for sure.
'70 Challenger R/T 383 '16 Hemi Durango SSV (work vehicle) '15 Ram Police SSV
[Re: The70RTChallenge]
#822365
03/18/11 01:52 PM
03/18/11 01:52 PM
jbc426
West Coast, USA
I had to replace the seat bracing on both sides, because back in the early 80's, I tried to invent my own subframe connectors and they were just in the way. Ahhhh, the folly of youth.
[Re: jbc426]
#822366
03/18/11 01:54 PM
03/18/11 01:54 PM
jbc426
West Coast, USA
I knew I messed up when I took them off and had a set squireled away for many years just waiting for this moment to make good on my mis-steps.
[Re: jbc426]
#822367
03/18/11 01:56 PM
03/18/11 01:56 PM
jbc426
West Coast, USA
Back in the old days, the car body used to flex with a stock headed 440. I am going to run a motor with a bit more steam, so I installed a set of quality subframe connectors.
I figured after seeing what a lot of guys have to do to their sheet metal to deal with the rust issues most of these car have I can always spend the time to remove them if need be, and done with a bit of care, no one would ever be able to tell they were there.
[Re: jbc426]
#822368
03/18/11 02:07 PM
03/18/11 02:07 PM
jbc426
West Coast, USA
Once everything was all welded and ground, I used Resto Rick's undercoating to blend the new stuff in with the remaining, original undercoating.
[Re: jbc426]
#822369
03/18/11 02:12 PM
03/18/11 02:12 PM
jbc426
West Coast, USA
I freshened up each part and made some bolt on modifications/upgrades to the front and rear suspension and brakes.
[Re: jbc426]
#822370
03/18/11 02:17 PM
03/18/11 02:17 PM
jbc426
West Coast, USA
...FirmFeel stage 2 box, bigger tie rods, bigger front swaybar and larger front 11 3/4discs, added rear sway bar and Doctor Diff rear discs with Caltracs and mono's.
[Re: jbc426]
#822371
03/18/11 09:39 PM
03/18/11 09:39 PM
Looks good. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: jbc426]
#822373
03/18/11 11:18 PM
03/18/11 11:18 PM
Posts: 333 Vandergrift,PA
The70RTChallenge
Vandergrift,PA
ANYTHING can be done. just need the right set of hands....Keep the pics comming ![](/ubbthreads/images/graemlins/punkrocka.gif)
[Re: NV69B7RR]
#822374
03/18/11 11:32 PM
03/18/11 11:32 PM
jbc426
West Coast, USA
Thanks guys. Yah, Mopars were truely engineered for rapid transit out in the open spaces of Nevada and the like. The tire technology back then was a bit scary to go deep into the triple digits, but lots of folks did becuase they could.
[Re: jbc426]
#822375
03/19/11 01:47 PM
03/19/11 01:47 PM
jbc426
West Coast, USA
Looking across the cowl. Black cars....every little spec of dust shows up with the flash. It looks beter in person, especially after a color sand and buff.
