Page 2 of 3 1 2 3
Re: Tranny problem anybody have any ideas [Re: 451Mopar] #820763
10/05/10 04:37 AM
10/05/10 04:37 AM
Boise Idaho
Boise Chall Offline OP
Boise Idaho
No he didn't install it I did. Yes i am running the TV cable it's new and it's adjusted properly. The tranny cooler and tranny lines are new and yes I blew compressed air thru them before I installed them. Although the guy that built this sounds like he knows what he's doing This is the second tranny he built for me that went away in less than 2,000 miles. I paid for all the right parts so It would handle the abuse I told him I was going to put on this tranny I don't know if they actually got put in the tranny or not but I'm sure they did. The last tranny that went away he let me stand there while he took it apart so he was cool that time
Re: Tranny problem anybody have any ideas [Re: Boise Chall] #820764
10/05/10 09:20 PM
10/05/10 09:20 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Sounds like your doing everything right. Sorry to sound like a jerk and doubt you, but I don't know you, and I the trans I did last week didn't have any kickdown linkage.
It sounds like you might have to trust your transmission builder? At least he says he will fix it for free?
I think if the slippage was just the converter then the clutches should look good. It is a good idea to have the converter cleaned/checked and rebuilt with all the problems your having.
On the otherhand, I with everyone elses opinion that the clutches are slipping, or there is a really bad fluid leak? You may want to pull the valve body and pressure check the clutches and servos with compressed air, just to see if you notice any really obvious air/pressure leaks.
Re: Tranny problem anybody have any ideas [Re: 451Mopar] #820765
10/10/10 01:58 AM
10/10/10 01:58 AM
Southwest, Mi.
74Cuda Offline
74Cuda  Offline
Southwest, Mi.
I would highly recomend flushing out the trans cooler tank in the radiator because it takes more that compressed air. Because it could be full of crap and it is getting back in the fresh trans causing trouble.
And if you are only running a cooler with your 3500 converter, it should be 1/2 the size of your radiator or the trans will cook itself.
Re: Tranny problem anybody have any ideas [Re: 74Cuda] #820766
10/10/10 02:21 AM
10/10/10 02:21 AM
Boise Idaho
Boise Idaho
I have the tranny out of the car now I'm just waiting for the shop that built the tranny to get some free time so we can take the tranny apart. I'm hoping to get it done Monday afternoon. I will post the results after we see what's inside.
Re: Tranny problem anybody have any ideas [Re: 74Cuda] #820767
10/12/10 08:51 PM
10/12/10 08:51 PM
Boise Idaho
Boise Idaho
Ok the guy that built the tranny was able to take the tranny apart today. He found a cracked pressure plate and all of the valve body bolts finger loose or backed out a couple threads. He said the pressure plate most likely cracked because of heat and the loose bolts on the valve body didn't matter he said it didn't have to be a perfect seal. The filter was full as stumpy said with a bunch of finely ground up aluminum. He said it was the torque converter that went bad and caused the problem. What do you guys think ?????
Re: Tranny problem anybody have any ideas [Re: Boise Chall] #820768
10/12/10 09:06 PM
10/12/10 09:06 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Whiskey and trans building don't mix. Find a new builder.
Re: Tranny problem anybody have any ideas [Re: Y3 70 BEE] #820769
10/12/10 09:17 PM
10/12/10 09:17 PM
Boise Idaho
Boise Idaho
He's going to warranty the tranny but it's the torque converter that I'm worried about. If the TC was the problem I don't know if I want to try another one from the same company. The Tc company will fix it for $60 plus shipping but is it worth possibly trashing another tranny ? Could the loose valve body have caused this problem ?
Re: Tranny problem anybody have any ideas [Re: Boise Chall] #820770
10/12/10 09:55 PM
10/12/10 09:55 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
SEE comment above .....
SEE if you can have him FIX the trans that he messed-up .. but be-sure he is sober !
Re: Tranny problem anybody have any ideas [Re: dOc !] #820771
10/12/10 10:18 PM
10/12/10 10:18 PM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
Auto transmissions work by hydraulic pressure. A perfect seal is essential.
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: Tranny problem anybody have any ideas [Re: Boise Chall] #820772
10/12/10 10:35 PM
10/12/10 10:35 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
That puts you in a tough spot. Do you let him screw it up again for "free" or take it elsewhere and pay again? I suppose the fact that it's paid for (and you won't get your money back) means you have to give him another shot. I'm sure the thought isn't comforting...
By the way, how would one know if his TC was bad???
Re: Tranny problem anybody have any ideas [Re: Fat_Mike] #820773
10/13/10 12:08 AM
10/13/10 12:08 AM
Boise Idaho
Boise Idaho
When I pulled the TC drain plug out it was full of metal shavings and I could see broken parts inside. It also had something that looked like a plate that I could move with my finger through the hub about an inch or so each way. I don't know much about TC's but it didn't look like it did when I put it in 900 miles ago. Could the loose valve body be the reason the TC went bad ????
Re: Tranny problem anybody have any ideas [Re: Boise Chall] #820774
10/13/10 10:44 AM
10/13/10 10:44 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
If it would work with loose bolts, Mother Mopar would not ask for 35 inch pounds of torque on them. Plate warpage was due to fluid pressing on an unsupported plate. IMHO he forgot to tighten the screws.
Craig
Re: Tranny problem anybody have any ideas [Re: Boise Chall] #820775
10/13/10 10:56 AM
10/13/10 10:56 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Which valve body bolts were loose , the ones holding it to the case or the ones holding the halves together ? What did the rear support where the mainshaft rides look like ? If all the crap came from the convertor it should have destroyed that part and the possibly mainshaft.
If he is going to warranty it he knows that what he did had to do with it going south .
I would get a better convertor.
Re: Tranny problem anybody have any ideas [Re: johnedod] #820776
10/13/10 11:07 AM
10/13/10 11:07 AM
Southwest, Mi.
74Cuda Offline
74Cuda  Offline
Southwest, Mi.
Thats like saying that it does not matter if the head boles in the engine are loose because the pistons move a lot of air.
That guy needs to be ran out of business, after he repairs your trans, gets you a new converter and you watch him torque the valve body bolts.
How big is your cooler, and are you running the trans fluid through the radiator tank and then through the cooler?
Back in the 70's I ran a B&M J 5000 stall on the street all of the time and it was sweet.
Talk to Rick at A&A transmission and have him build you a nice 3200 stall convereter.
Re: Tranny problem anybody have any ideas [Re: JohnRR] #820777
10/13/10 12:33 PM
10/13/10 12:33 PM
Boise Idaho
Boise Idaho
the loose bolts are the ones that hold the valve body to the case. He said everything looked good in the trans except for the 1 cracked pressure plate. He said it would need what he called a "soft rebuild" and everything would need to be cleaned. The cooler I run is 12 x 14 and I have it running through the radiator then through the cooler. My engine temps are normally 180-190 I have 185 T-stat.
Re: Tranny problem anybody have any ideas [Re: Boise Chall] #820778
10/13/10 01:06 PM
10/13/10 01:06 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Be sure all the lines and cooler get a good flushing.
Re: Tranny problem anybody have any ideas [Re: Boise Chall] #820779
10/13/10 01:13 PM
10/13/10 01:13 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Boy the 727 is about the easiest tranny to build if he can't do that he needs to retire. All the crap you see in the converter could have been from the tranny.
If it is a big name converter I would have it rebuilt and sell it. Ask them if anything failed as the tranny guy could just be feeding you another line of crap. Then get a slightly smaller converter if your cam can handle it.
If he knew that he was the one who screwed up he should be able to rebuild the tranny correctly as there are not many trannies simpler than the 727
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Tranny problem anybody have any ideas [Re: denfireguy] #820780
10/13/10 01:53 PM
10/13/10 01:53 PM
JohnRR Offline
JohnRR  Offline
Craig
Maybe that's why they loosened because the spec is 75 inch pounds
Re: Tranny problem anybody have any ideas [Re: Boise Chall] #820781
10/13/10 01:56 PM
10/13/10 01:56 PM
JohnRR Offline
JohnRR  Offline
The guy is an if he is trying to tell you them being finger tight is ok. I actually have a gasket between the VB and case in my 2000 Ram 47RE to help against the pressure loss, is it needed , probably not but my trans still works well behind my hot rod Cummins 127k miles later.
Re: Tranny problem anybody have any ideas [Re: Boise Chall] #820782
10/13/10 02:30 PM
10/13/10 02:30 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
with metal debris in it, I would take that thing all the way down to the bare case and start over . cleaning everything including the valvebody
AND have the convertor opened up and ck'd
Page 2 of 3 1 2 3
