Re: Tranny problem anybody have any ideas
[Re: Boise Chall]
#820784
10/13/10 04:37 PM
10/13/10 04:37 PM
Posts: 146 michigan
tonycpe
michigan
Just so you know , your trans guy is screwing you.
Old Fogey Racing Ltd.
[Re: Boise Chall]
#820785
10/13/10 05:44 PM
10/13/10 05:44 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
the loose bolts are the ones that hold the valve body to the case. He said everything looked good in the trans except for the 1 cracked pressure plate. He said it would need what he called a "soft rebuild" and everything would need to be cleaned.
Not sure what this guy means by a "soft rebuild"? the whole thing needs to be dissasembled to get it clean. Also, the "cracked pressure plate" comment? What pressure plate cracked? Is he refering to one of the steels in the clutch pack, or a drum piston, or the rear bellvule (sp) spring, or the really thick plates that hold the clutch packs in the drums (not sure how you would crack one?)
Your really in a bad situation. Even if the guy fixes the trans for free, I'm not sure I would trust his work. maybe have him fix it, then have someone go back through it?
[Re: Y3 70 BEE]
#820788
10/20/10 04:45 PM
10/20/10 04:45 PM
Posts: 1,051 Slidell, La.
doctor_mopar
Slidell, La.
A few years ago I removed my Turbo Action 10 " Converter from my 904 and installed a Boss Hog converter. ( I wanted a little less stall ) It was not worth a Damn and came apart in less than 1000 miles, and left shrapnel all through the trans. Took alot of cleaning, and had metal embedded in clutches ,valve body, governor. When I rebuilt it, I put the Turbo Action converter back in, and threw ![](/ubbthreads/images/graemlins/frowwn.gif) the Boss Hog out with the trash !
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Tranny problem anybody have any ideas Update -1
[Re: Boise Chall]
#820796
11/19/10 05:59 PM
11/19/10 05:59 PM
Posts: 43 Ohio
Johnny Pace
Ohio
Let me tell you my similar experience i went through recently that might shed some light on your situation. i race my dart regularly, it's now a 408 stroker, but at the time only had a 318 that would push the car to low 14's. the tranny was rebuilt and i purchased a 3000 stall B&M converter when it went together..(also i'll point out that a 3500 converter for the street is completely fine...i drove a 4500 to the track every weekend for years without a problem, flash speed and their advertised stall speed are very diff things) any ways, on a pass down the track (on motor) i lost 3rd gear completely, shifted into first, second, every gear but drive. i checked my linkage a thousand times, adjusted it slightly and it appeared to fix the problem...for a week..then it did the same thing...i called my trans guy and gave him h@ll about my 1000 mile tranny blowup i just had.. like your guy he said he'll go through it for free, but also said that my pan full of shavings was most likely a blown converter. i thought he was an idiot until i went to pull the converter off of the pump. the converter had internally blown up and basically ate the front of the pump shaft off..these shavings then clogged the valve body, which restricted pressure for the shift. long story short, i apologized, gave him his deserving $250 for the rebuild and intense cleaning my tranny needed...and then proceeded to call B&M and give them hell instead. they basically said it's out of warranty, i'm on my own, and i basicaly said i'm done with their crap and my next one will be a TCI with an anti baloon plate. long story short, neither the trans builder or the converter company is gonna own up to it. i know nothing about boss hogg and i work for what we'll call...(americas #1 performance warehouse)..they might be good, no idea...my mistake was running nitrous on a garbage $300 converter, i felt no shudder, shake or anything, and had no idea the converter went until the valve body clogged, also probably only made 20 nitrous passes on the motor, and it had beena bout 5 months since the last one...so learn from that as well..and back to your problem, your tranny builder seems very unprofessional..loose bolts? come on..but that would just cause pressure leaks and stop you from shifting..the other parts found in the pan show his parts failed, either as a result of the converter going, or on thier own....i'd be leaning to his fault since now he also gave you a seized pump, and i'd be the first person to blame a budget converter, but in this case i think it's on him, and the converter and trans both need gone through. if there's shavings in the pan, there's shavings everywhere else. if the converter checks out ok then again better business b this guy...hope my long winded story and opinion helps you.
[Re: Johnny Pace]
#820799
11/20/10 01:21 AM
11/20/10 01:21 AM
Posts: 659 Boise Idaho
Boise Chall
Boise Idaho
I think in this case the tranny went and took the converter with it. Don't get Me started on People getting screwed over on paint work. I was on the sh@t end of that stick with an AAR Cuda clone I built and painted a guy and never got paid for it. But I think that would something for a different forum.
