Re: What should this cost?
[Re: Russ]
#82009
07/01/08 12:55 PM
07/01/08 12:55 PM
Posts: 3,753 Gulf Coast of Florida
Russ
super gas
super gas
took out the thermostat,put the plugs back In,and drove it about 3 miles,now It feels like It's running on 3 cylinders at a stop sign,but clears up when I take off,got back home,and the coolant Is gurgling Into the overflow tank
2001 Durango 5.9 Magnum
99 Durango 5.9 Magnum
Parting out 99 Durango 5.9,99 Ram 1500 and 98 Ram 1500 5.9
WANTED.Ram Truck,Durango/Dakota parts and parts trucks!!PM Me.
GO BUCKS!!!!
Go GATORS!!!!
[Re: Russ]
#82011
07/01/08 02:11 PM
07/01/08 02:11 PM
Posts: 18,424 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I told you how to diagnose it.
[Re: Russ]
#82012
07/01/08 03:15 PM
07/01/08 03:15 PM
DaytonaTurbo
Manitoba, Canada
Okay, I over heated my 87 daytona a few times and the problem never was a head gasket. In fact I never did have to do a head gasket in that car even after really overheating it a few times. Turns out the problem was a plugged heater core. For some reason on these cars, once the heater core plugs, the motor overheats. More so it's noticeable because the temp gauge swings back and forth a lot, where when the cooling system is functioning properly the needle doesn't move once you get up to operating temp. Not wanting to have to change the heater core, I gave the entire cooling system a good flush, then spent some time flushing the heater core. Then refilled the entire cooling system with distilled water/coolant, blurped the cooling system and guess what? No more overheating. All the head gasket changes in the world wouldn't have fixed that problem for me.
[Re: Russ]
#82014
07/02/08 09:27 PM
07/02/08 09:27 PM
Russ
super gas
super gas
took It to 3 different places,and all said,the motor was shot,and not worth even an engine swap,so i took it to the crusher,and bought this
GO BUCKS!!!!
Go GATORS!!!!
