GOT THEM ON W/ PICS NEED INFO ASSEMBLING COIL OVERS
#818382
09/30/10 11:32 AM
09/30/10 11:32 AM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
Bought a full set of Santhuff springs and shocks.
The fronts are giving me problems getting the spring compressed enough to install the top plate. They are 350 lb . I have a spring compressor but it will not adapt to these springs. Is there any tool I need or special compressor?
home of the Sox and Martin Hemi Duster
Re: NEED INFO ASSEMBLING COIL OVERS
[Re: blown572dart]
#818384
09/30/10 11:41 AM
09/30/10 11:41 AM
Posts: 970 Backwater, PA
bwdst6
Bob George Racing #1 Fan
Backwater, PA
Stupid question: Did you jack the front end off the ground? here... or here...
This post is available in double vision where drunk.
[Re: HEMIFRED]
#818386
09/30/10 12:03 PM
09/30/10 12:03 PM
HEMIFRED
SOUTH JERSEY
I just saw where on another brand they removed the knob ans slid the platform over it. out to shop and check mine
[Re: HEMIFRED]
#818387
09/30/10 12:06 PM
09/30/10 12:06 PM
bwdst6
Backwater, PA
I would say that if the set in the lower picture I posted doesn't fit make a custom set similar to it. I would also make it clamp around the coil sping bar for safety, so it can't slip off.
If you can't compress your shock then have you tried adjusting in to it's lowest compression seting?
[Re: bwdst6]
#818388
09/30/10 12:12 PM
09/30/10 12:12 PM
HEMIFRED
SOUTH JERSEY
I have a set like the bottom ones . the problem is the arms extend into the center of the spring which prevents the shock from going thru the spring
[Re: HEMIFRED]
#818389
09/30/10 12:25 PM
09/30/10 12:25 PM
bwdst6
Backwater, PA
I have a set like the bottom ones . the problem is the arms extend into the center of the spring which preventsnthe shoch going thru
Then you can make a custom set. All that should be needed is two jack screws, 4 nuts and then you would have to make two custom connecting plate to pass through the coil and around the shock.
Or you could do it quicker with the half-@ssed method by taking off the lower control arm, assembling the coil over to the upper strut tower and lower control arm and then lowering the front end to compress the coil over. Then with the lower control arm still assembled to the coil over try to bolt it back to the frame! DISCLAIMER: I AM NOT RECOMMENDING THIS!!!
[Re: bwdst6]
#818392
09/30/10 01:12 PM
09/30/10 01:12 PM
HEMIFRED
SOUTH JERSEY
I appreciate the suggestions bt (I don't think we are talking about the same type coil overs. These are nothing like what you have pictured. Those are entirely different.
My spring is compressed between the lower screw plates and the top plate under the shock eye. This style you slide the spring down over the top of the shock and then place a special upper springs seat that locks under the shock eye around the shaft and sits inside the spring to cenetr it.
this shows the top and bottom platforms it sits on the red T is the upper that is removeable. I can comporess mine enough to do that
[Re: HEMIFRED]
#818393
09/30/10 01:20 PM
09/30/10 01:20 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Aren't the bottom seats adjustable? Can you not thread the bottoms all the way down, install the spring and the top, and then rethread the bottoms up to compress the spring?
[Re: WILD BILL]
#818395
09/30/10 01:28 PM
09/30/10 01:28 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Fred,are the springs the coorect length for the shock?I had a similar problem with a set that I was putting a 12" spring on and it was built for a 10" spring.Usually spin the adjusters all the way down and push the slotted top retainer in at an angle till it sits flush on the spring. Also try collasping the spring and use a couple of heavy wire ties to hold it and install the spriing and retainer that way.Be carefull and use substancial ties.
[Re: abodiesonly1]
#818399
09/30/10 01:47 PM
09/30/10 01:47 PM
B G Racing
Eighty Four, PA
From that pic it looks like the wrong spring.
If it's a front shock it's probably correct.They are a heavy rated spring and a bear to install.
[Re: abodiesonly1]
#818400
09/30/10 01:50 PM
09/30/10 01:50 PM
HEMIFRED
SOUTH JERSEY
the spring is 12" the measurement inside the deat with shock's full extention is 11 5/8"
It needs more than the difference to allow top seat to slide under.
back in the shop
