Re: NEED INFO ASSEMBLING COIL OVERS
[Re: racerhog]
#818404
09/30/10 06:16 PM
09/30/10 06:16 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
put spring on the trans jack under the lift and used ties
home of the Sox and Martin Hemi Duster
[Re: B G Racing]
#818407
09/30/10 07:38 PM
09/30/10 07:38 PM
See, zipties do serve a purpose other than cheap handcuffs! ...er, not that you had them lying around for that purpose... ![](/ubbthreads/images/graemlins/laugh2.gif)
#818408
09/30/10 08:15 PM
09/30/10 08:15 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
And here I thought zip ties wouldn't have cut it ![](/ubbthreads/images/graemlins/shock.gif)
Well done
[Re: HEMIFRED]
#818414
09/30/10 10:58 PM
09/30/10 10:58 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
[Re: HEMIFRED]
#818415
09/30/10 11:25 PM
09/30/10 11:25 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
the above courtesy of a BG phone call
I think somebody else posted that around 2:15 ![](/ubbthreads/images/graemlins/whistling.gif)
Monte
[Re: HEMIFRED]
#818417
10/01/10 08:11 AM
10/01/10 08:11 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Monte
true but BG called right after he posted this at 12.28.
Barnyard Bob
Reged: Mar 28 2006 Loc: Eighty Four, PA Re: NEED INFO ASSEMBLING COIL OVERS [Re: WILD BILL] #6224775 - Thu Sep 30 2010 12:28 PM Edit Reply Quote Quick Reply
Fred,are the springs the coorect length for the shock?I had a similar problem with a set that I was putting a 12" spring on and it was built for a 10" spring.Usually spin the adjusters all the way down and push the slotted top retainer in at an angle till it sits flush on the spring. Also try collasping the spring and use a couple of heavy wire ties to hold it and install the spriing and retainer that way.Be carefull and use substancial ties
then he whinned about it here so I made that post
- Thu Sep 30 2010 05:57 PM Edit Reply Quote Quick Reply
Glad you thought of that
Thanks Monte
I wasn't whinning,you wouldn't read the post completely.You were whinning so I called and got you to stop talking long enough to listen,since you can't read.It's a Joisey thing.All I heard from you was "I can't,I can't" take a lesson from the current presidents campain slogen"yes we can"now drop your pants. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: HEMIFRED]
#818420
10/01/10 10:43 AM
10/01/10 10:43 AM
Posts: 705 Michigan
Hemiroid
drop pants ?
LOL!! Ok, that picture is wrong in so many ways ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: earthmover]
#818421
10/01/10 12:31 PM
10/01/10 12:31 PM
HEMIFRED
SOUTH JERSEY
hay fred so you come out to roxboro speed way in north carolina......good old country racing at its best
I have been there twice. once we had a Ronnie Sox Memorial race and then the year before last.
Roxboro has just listed Grudge night Friday the 15th .
I should be there with Eugene Coard and the Ronnie Lyles car.
Free BBQ chicken and wet T shirt contest
Going to try Piedmont on Oct 14 or Oct 17
That picture is of Hemiparts after he got beat by my Duster when he was driving the Motown Missile. Chris was all posed up for a serious shot and I snuck up just as they took the picture
