Re: Engine Carnage... Would you say bad luck? Long story [Re: 727builder] #818172
10/01/10 10:29 AM
10/01/10 10:29 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
I always run a button in my solid cammed big blocks.Good luck
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: Engine Carnage... Would you say bad luck? Long story [Re: moparmxz] #818173
10/01/10 10:46 AM
10/01/10 10:46 AM
PA
moparacer Offline
moparacer  Offline
PA
Im not bashing, Just going by what the machine shop told him. Any of you with Indy's ever look at the washers under your spings???
Yep, and mine looked just like those did.
I was getting metal in the oil and couldn't figure out where. And that's where it was coming from.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Engine Carnage... Would you say bad luck? Long story [Re: moparmxz] #818174
10/01/10 11:50 AM
10/01/10 11:50 AM
NC
440Jim Offline
440Jim  Offline
NC
I have never run one and never had a problem.
Any chance something jammed in the cam or valve train causing the chain to break? Cam bearing got tight, etc.??
Re: Engine Carnage... Would you say bad luck? Long story [Re: 440Jim] #818175
10/01/10 11:56 AM
10/01/10 11:56 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Iskys catalog doesn't show a button necessary till you get into the roller cams. Granted, this is a GUESS off of the pics - could the damage to the spring washers be from valve float, which will also let the cam walk forward, since at that time there is no lifter pressure to hold it in place? Just throwing it out there.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Engine Carnage... Would you say bad luck? Long story [Re: Evil Spirit] #818176
10/01/10 03:02 PM
10/01/10 03:02 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
It has always been a lot of focus on the lifters keeping the cam back. I would say that is minor, and on an engine with worn lifters it is not there at all.
What about the force to drive the oilpunp? I always though that was the main reason for keeping the cam back. And if so, maybe the broken suction pipe let false air into the oilpump, so it did not make so much resistance to run, thus causing the cam to walk to the front? Just a possible cause....
Re: Engine Carnage... Would you say bad luck? Long story [Re: Oyvind Mopar] #818177
10/02/10 01:40 PM
10/02/10 01:40 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Just thinking out loud here about if either the timingchain is the cause, or the oilpickup tube...
Could the broken/loose connection of the oilpickup tube have caused air to be sucked into the oilpump, which would be somewhat similar to suction cavitation I think. Could the intermittened shockwaves and vibration of this be transmitted through the intermediate shaft into to the camshaft, in turn causing the chain to break?
Re: Engine Carnage... Would you say bad luck? Long story [Re: 440Jim] #818178
10/04/10 08:16 AM
10/04/10 08:16 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
I never had a problem with out one either ,but i did notice my timing being a little steadier with one. For no more than they cost i,ll keep running one just to eliminate any chance of cam walk.
