Re: Viper Brake conversion Q's
[Re: feets]
#817675
10/04/10 08:39 PM
10/04/10 08:39 PM
Posts: 813 Ontario,Canada
brads70
Ontario,Canada
Andy's Viper caliper kit on stock rotors will fit a 15" wheel. The Viper caliper kit on 13" rotors will fit 17" wheels.
Both kits use front calipers.
http://www.arengineering.com/caliper_menu/calipermenu.html
Thanks for the link! I have seen it before, the problem I have is that I have 73-74 E-body spindles and the AR kit won't work as it uses drum spindles. Brad
[Re: AndyF]
#817676
10/30/10 11:46 PM
10/30/10 11:46 PM
brads70
Ontario,Canada
Here is a picture of the Viper calipers that you were asking about.
What year calipers are these? Will they work on a 15 " rim? What thickness rotor are these for? What are you asking for them, if they are still available? Thanks Brad
[Re: AndyF]
#817678
10/31/10 10:30 AM
10/31/10 10:30 AM
brads70
Ontario,Canada
Ok thanks! were they 3rd gen calipers? I'm in learning mode at the moment! Would they have fit under 15" rims? I'm guessing no? Thanks again! Brad
[Re: Vert]
#817681
03/06/11 11:37 PM
03/06/11 11:37 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
I made the brackets from scratch, so no cad drawings, sorry... The rotors are 360mm diameter.. The application was like 2007 SL600/SL55 (Feets can rattle off the factory part number probably. ) I just had them redrilled for the bolt pattern I wanted. Some other specs off rockauto..
[Re: Vert]
#817682
03/07/11 02:44 AM
03/07/11 02:44 AM
Posts: 31,022 Oregon
AndyF
Wow, how did I miss this post? I have a loaded set of Viper calipers off a 2004 model. Still hoping to convert someday on the Cuda. Like Andy's product but also concerned about custom rotor availability on a consumable part. OzHemi, you have cad drawings for that adapter? And a p/n for the Mercedes rotor?
Baer makes rotors for the Viper conversion. The Baer rotors cost a lot more than my rotors, but they look cooler and they are a lot lighter. Just depends on what you're trying to do with the car and how thick your wallet is.
[Re: AndyF]
#817683
03/07/11 01:59 PM
03/07/11 01:59 PM
Posts: 3,488 Annapolis, MD, USA
Vert
Annapolis, MD, USA
Oz and Andy, thanks for the replies. I'm still playing mind games with myself. For a car with a 528 RB hemi, that I rarely drive (and rarely above the speed limit) I want 4 new wheels, new tires for them, drum spindles to replace my disc spindles, and a caliper mounting kit with rotors. The Viper calipers will probably end up being the cheapest part, next to a set of spindles I haven't bought yet. Don't think for a moment I think your product prices are out of line. I think they're quite reasonable. If I keep this up I'll have $75k in a $75k car.
[Re: Vert]
#817684
03/07/11 03:59 PM
03/07/11 03:59 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
I don't the spindles should be that pricey. The pair I picked up for this very swap were 15 bucks each - in good shape - from a yard in central OR.
[Re: Vert]
#817685
03/07/11 04:23 PM
03/07/11 04:23 PM
OzHemi
Garden Grove, CA
No problem... aside from the calipers, the rotors are only like $160 - $165 from memory right from the Mercedes dealer. (think I paid $20 to have them both redrilled for the bolt pattern..let the place who built my wheels do it, since they are all drill bolt patterns in things) So it makes for a very economical setup, if you are able to make the caliper brackets like I did. Oh, and the hubs too...I used some new ones from Oz.. but you could use drum ones, cut down old rotors, etc..
