Re: what will it run 418 stroker ?1/8 mile [Re: all spooled up] #816796
10/02/10 12:16 AM
10/02/10 12:16 AM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
i ran a best of 7.311@94.73 ,60FT was 1.62,launching at 2000,shift at 6000.i also ran 7.35@94.31 ,7.32@94.3 ,7.315@94.55 i dropped the tire pressure down to 18 psi and ran it just like i do on the street,9sec phil was down there also,gave me some tips.thanks phil,
Re: what will it run 418 stroker ?1/8 mile [Re: hp340nos] #816797
10/02/10 10:12 AM
10/02/10 10:12 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Very nice Mike. ...and you got to drive it home.....sweet.
For the record, the track is up on a mountain, he will/would run at least a tenth faster " down off the mountain". A little tuning, some more carb and I bet its 11.10's. Not bad for a truck with factory iron heads. The 60's definately hurt the overall ET, but its not a dedicated race vehicle either. Good job first time out.
RIP Monte Smith
Re: what will it run 418 stroker ?1/8 mile [Re: CompWedgeEngines] #816798
10/02/10 10:31 AM
10/02/10 10:31 AM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
Great results. Anytime you can drive it to the track and run those kind of numbers, you should be very very happy. Great job!
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: what will it run 418 stroker ?1/8 mile [Re: ChrgrCuda] #816799
10/02/10 12:22 PM
10/02/10 12:22 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
thanks guys had alot of fun.
Re: what will it run 418 stroker ?1/8 mile [Re: hp340nos] #816800
10/02/10 01:09 PM
10/02/10 01:09 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Very good run. Its almost identical to what my 63 runs. Its a driver also and my best 1/8 is 7.28 @ 94 mph and the 1/4 on that pass was 11.49 @ 116. You are easy 11.50's right now. Thats a good running combo. Ron
Re: what will it run 418 stroker ?1/8 mile [Re: 383man] #816801
10/02/10 01:27 PM
10/02/10 01:27 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
thanks ron,nice car you have there.yes i need bigger carb,little shorter tire height.these are m/t 295/65-15(29.5"tall) et street radial,probably go to a 325/50-15 or 275/60-15 a( 27.5"tire)this should help the gearing off the line.
