Re: Hideaway headlight relay
[Re: shadowauto]
#815394
09/30/10 04:15 PM
09/30/10 04:15 PM
Posts: 3,683 The Historic Hudson Valley
MONC
Hi I understand that You have to center your motor there is a marke on the casing or just count the turn and divide the rotation by two and make sure when You install the rod that your door are half close or half open and it should work give it a try Francis.
Right, this is what I was trying to say in my earlier post, forgot all about the mark on the casing. (Thanks for the memory jogging . ![](/ubbthreads/images/graemlins/laugh2.gif)
I believe all of this is stated in the manual as well.
[Re: convx4]
#815406
10/06/10 12:35 AM
10/06/10 12:35 AM
Posts: 6,100 Valencia, España
NachoRT74
Valencia, España
I made that diagram long time ago ![](/ubbthreads/images/graemlins/biggrin.gif) need to mention the advantage to hook on RUN circuit like is originally instead ACC like I suggested there, is to be able to keep the doors open when turn on lights, key in off, and then turn off the lighst without close the doors, for service or washing purpouse
[Re: attaboy]
#815410
10/15/10 09:52 AM
10/15/10 09:52 AM
Posts: 543 Indiana, Just Off I-70
BradD
Not to be a d**k here, but that is always the first thing to check. Always clean the connections first. Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
