Re: Hideaway headlight relay [Re: shadowauto] #815394
09/30/10 04:15 PM
09/30/10 04:15 PM
The Historic Hudson Valley
MONC Offline
MONC  Offline
Hi I understand that You have to center your motor there is a marke on the casing or just count the turn and divide the rotation by two and make sure when You install the rod that your door are half close or half open and it should work give it a try Francis.
Right, this is what I was trying to say in my earlier post, forgot all about the mark on the casing. (Thanks for the memory jogging .
I believe all of this is stated in the manual as well.
Re: Hideaway headlight relay [Re: MONC] #815395
09/30/10 05:14 PM
09/30/10 05:14 PM
New Mexico, USA
attaboy Offline OP
attaboy  Offline OP
New Mexico, USA
Ther's nothing to install. Everything is in place and has been working up until recently. Nothing has been taken apart, the rod has not been removed. It's all as I left it after initial restoration a few years ago. It's just that it stopped returning the headlight covers to the closed position after turning off the lights. I really don't think that "centering" the motor is the problem here. It's an electrical problem, not a mechanical mechanical problem. Everything works perfectly when I bypass the existing electrical circuits and power the motor directly with 12 volts. The doors open and the doors close perfectly.
Re: Hideaway headlight relay [Re: attaboy] #815396
09/30/10 06:30 PM
09/30/10 06:30 PM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
so it operates with the wire way- so I'm thinking that the relay itself has a problem with the close contact inside.
Re: Hideaway headlight relay [Re: 71_deputy] #815397
09/30/10 10:01 PM
09/30/10 10:01 PM
New Mexico, USA
attaboy Offline OP
attaboy  Offline OP
New Mexico, USA
I would think that the problem is in the relay except for the fact that I checked with a VOM meter and verified that when I turn on the headlights the Blu/Yel wire becomes energized while the Red/Blk is not. When I turn off the headlights the Blu/Yel wire is deengerized and the Red/Blk is energized. Seems to be working correctly?
attaboy
Re: Hideaway headlight relay [Re: attaboy] #815398
09/30/10 10:49 PM
09/30/10 10:49 PM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
not to get nasty here- but connect it all back together and recheck both wires.
reason is that without a load on it- the meter will it ok
but with something connected and showing almost nothing would point to the relay's conact being bad- try it and let us know!!!
John Mac
Re: Hideaway headlight relay [Re: 71_deputy] #815399
10/01/10 01:24 PM
10/01/10 01:24 PM
New Mexico, USA
attaboy Offline OP
attaboy  Offline OP
New Mexico, USA
You're not being nasty. You're helping and I appreciate it. I didn't think of the "no load" possibility. I'll try it again all hooked up. Also, there is always the remote possibility that the problem is as simple as a non connection within the connector itself. At any rate, I'll hook it back up and keep you posted.
Re: Hideaway headlight relay [Re: attaboy] #815400
10/01/10 05:17 PM
10/01/10 05:17 PM
MONC Offline
MONC  Offline
Agree with 71 Deputy, may be a load issue.
I think I had that issue as well at some point.
Listen for the "click" of the relay.
You can also take the cover off the relay ( carefully) and check the contacts in there.
I think I did that as well.
Re: Hideaway headlight relay [Re: MONC] #815401
10/01/10 05:55 PM
10/01/10 05:55 PM
New Mexico, USA
attaboy Offline OP
attaboy  Offline OP
New Mexico, USA
Interesting. It'll be difficult to rear the relay because it's located under the dash but I'll try it. Maybe it's a simple thing like dirty contacts on the relay.....or just simply that the connector pins to the motor isn't mating well.
Re: Hideaway headlight relay [Re: shadowauto] #815402
10/01/10 07:55 PM
10/01/10 07:55 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
its just the contacts inside the motor itself.... dan
Re: Hideaway headlight relay [Re: ph23vo] #815403
10/02/10 04:41 PM
10/02/10 04:41 PM
MONC Offline
MONC  Offline
You should be able to remove the relay easily enough. I think mine was attached with 1 nut/bolt.
I agree that it sounds like a contact issue, whether it is relay or motor, as the car was sitting for a while, and worked fine beforehand.
Re: Hideaway headlight relay [Re: MONC] #815404
10/05/10 09:18 PM
10/05/10 09:18 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
I used a Chevy truck accessory relay in place of the factory on a 70 dodge charger.
Re: Hideaway headlight relay [Re: convx4] #815405
10/05/10 09:19 PM
10/05/10 09:19 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
More info saved from the web.
Sorry for not remembering who.
Re: Hideaway headlight relay [Re: convx4] #815406
10/06/10 12:35 AM
10/06/10 12:35 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I made that diagram long time ago
need to mention the advantage to hook on RUN circuit like is originally instead ACC like I suggested there, is to be able to keep the doors open when turn on lights, key in off, and then turn off the lighst without close the doors, for service or washing purpouse
Re: Hideaway headlight relay [Re: ph23vo] #815407
10/09/10 03:32 PM
10/09/10 03:32 PM
New Mexico, USA
attaboy Offline OP
attaboy  Offline OP
New Mexico, USA
if it's the motor contacts then why would the motor work perfectly opening and closing when going directly from the battery and bypassing the relay?
attaboy
Re: Hideaway headlight relay [Re: attaboy] #815408
10/11/10 02:40 PM
10/11/10 02:40 PM
MONC Offline
MONC  Offline
Makes sense.
Did you check the relay contacts?
Re: Hideaway headlight relay [Re: MONC] #815409
10/14/10 07:33 PM
10/14/10 07:33 PM
New Mexico, USA
attaboy Offline OP
attaboy  Offline OP
New Mexico, USA
Well, I think I found at least part of the problem: One of the connections in the rubber connector coming from the motor (the one that closes the headlight door) was rusty and wasn't making a good connection. I cleaned it out with a dremmel and the headlight doors now close as well as open. Such a silly little thing causing such a huge investment in time and energy. Welcome to the wonderful world of 40 year old Mopars I guess. Thanks guys for all your help!attaboy
Re: Hideaway headlight relay [Re: attaboy] #815410
10/15/10 09:52 AM
10/15/10 09:52 AM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
Not to be a d**k here, but that is always the first thing to check. Always clean the connections first.
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: Hideaway headlight relay [Re: BradD] #815411
10/16/10 06:12 PM
10/16/10 06:12 PM
MONC Offline
MONC  Offline
Glad to hear you found the problem !
Figured it had to be a connection thing, as you mentioned the car was sitting for a while.
