Re: Critirque this launch! (video)
[Re: cheapstreetdustr]
#814565
09/27/10 08:49 AM
09/27/10 08:49 AM
Posts: 10,038 Frostbitefalls MN (Rocky&Bullw...
gregsdart
i can not see how the wheelie bars make the hit too hard. lowering them will not not make the problem go away, just aid(sp word) it ![](/ubbthreads/images/graemlins/Twocents.gif)
aldough i have never worked on a car this fast with ladderbars. so maybe i should just shut up.
they dont make the "hit to hard" the timing of when they hit ...is wrong. and the amount of leverage that's interupted when they hit is too much.. it is upsetting whats goin on...
cheapst
I agree. That is why at this point they are as high as I am willing to run them. They allow a two foot wheel stand as it is. Too much leverage with a 30 inch ladder bar has led to very high shock settings. Another problem, and one not easily solved is the height of the Center of gravity. I believe too high of a c/g creates a situation where the front of the car can rise too quickly and is hard to slow down without upsetting weight transfer. If I could lower the back of the car, I would, but the tubs hit the tires as it is. The car looks to be too high down track also. I can keep limiting the front travel a touch at a time, and maybe that will improve things.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: sshemi]
#814567
09/27/10 09:05 AM
09/27/10 09:05 AM
gregsdart
Raising the instant center would increase leverage, which looks to be the wrong direction. I have plenty of hit now. Actually If I could lower it without upsetting the speed of front end rise, I would. But in the past lowering the ladder bar increased the speed that the front would rise to the point it changed where it left the beams. I was almost leaving vertically, and had a .02 change in vehicle reaction time.
[Re: gregsdart]
#814568
09/27/10 11:49 AM
09/27/10 11:49 AM
Posts: 2,128 sweden
sshemi
sweden
can you raise the ladderbars one hole? where are they now?
[Re: Quicktree]
#814571
09/27/10 05:22 PM
09/27/10 05:22 PM
Posts: 2,128 sweden
sshemi
sweden
i take that back about raising the bars. just realized you cant move the ic forward without moving it too much upward.
Can you move some weight around?
[Re: sshemi]
#814573
09/27/10 05:52 PM
09/27/10 05:52 PM
Quicktree
I realy think your car needs fourlink.
![](/ubbthreads/images/graemlins/iagree.gif)
[Re: B1duster]
#814577
09/27/10 10:37 PM
09/27/10 10:37 PM
gregsdart
I remember having set the compression settings up front real stiff due to much higher wheel stands before. I think all I need to do is soften the shocks a bit. I bet its bouncing off the tires.
[Re: gregsdart]
#814578
09/27/10 11:54 PM
09/27/10 11:54 PM
Posts: 105 ontario
Clockwork
ontario
Nice car! Try a little more pressure in the rear tires? ![](/ubbthreads/images/graemlins/Twocents.gif)
572ci B1 7.90 172MPH
[Re: Clockwork]
#814579
09/28/10 05:45 AM
09/28/10 05:45 AM
gregsdart
I keep increasing tire pressure each pass, in very small increments. At 9.5 psi now up from 8.75, will keep going till it starts to spin or gets inconsistent.
[Re: gregsdart]
#814580
09/28/10 10:44 AM
09/28/10 10:44 AM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
EVERYONE HERE RUNNING MID 8'S ON LADDER BARS PLEASE FORM A LINE ON THE RIGHT. ![](/ubbthreads/images/graemlins/biggrin.gif) I just about have any front end travel. your rear shocks are way too stiff for compression I have mine 2 clicks from dead soft. rebound in the middle. wheelie bars 4". those tires were 14x32's and sidewalls were beat. I changed to 33x10.5W's and now 1.22 60's 1.26 60's VIDEO
home of the Sox and Martin Hemi Duster
