Re: Mig welding Q&A
[Re: RobX4406]
#814062
09/28/10 12:37 AM
09/28/10 12:37 AM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
About 15. At 20 it may steady the arc a bit in a windy garage but youll use a bit more gas. Above 20 and your wasting money. All you want is a small pocket of inert gas that will not react with the arc. Argon will have a smooth finish. Co2 will alow a lot of heat and flatten the bead. A 75/25 mix is good for most.
That guy that sold you that tank is also the guy that will exchange the empty one, RIGHT? Hummmmm.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
Re: Mig welding Q&A
[Re: 74-440Charger]
#814066
09/28/10 10:00 AM
09/28/10 10:00 AM
Posts: 75,134 A Banana Republic near you.
JohnRR
One more question for the experts here what pressure do you run the gas at on your mig? Thanks
The proper gas regulator is a flow meter not a pressure gauge , I'm not sure what the correlation is between CFM and psi , I usually set it at 20cfm.
Re: Mig welding Q&A
[Re: Commando1]
#814068
09/28/10 07:48 PM
09/28/10 07:48 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Nothing wrong with that helmet for the home user/hobbyist. The higher end units look nicer and have a higher quality shell and (where it really counts) a much better headband/hinge mechanism. But the lenses are likely no better.
Interesting. I am going HF today anyway so that looks like a done deal, too. ![](/ubbthreads/images/graemlins/thumbs.gif)
Harbor Freight: The company you LOVE to Hate.
Ive got one of the HF $ 49.00 adjustible lens helmet and it just doesnt get dark enough at its highest setting 12. After a few seconds of welding the bright light blinds me like in your dark welding pic.
Im back with a old broken strap helmit now, it works much better. The work looks like your lighter welding pic.
Maybe I got a bad one, but I got another buddy who has a adjustible and he has the same complaint. I dont know if he got his from Harbor freight or not, But right now neither one of us will use those adjustible helmets.
IMO, you have to get the expensive ones for them to work right but I could be wrong. Like I said, maybe I got a bad one, or maybe the Chinese have fixed the problems with those helmets. mike
Re: Mig welding Q&A
[Re: Sport440]
#814070
09/29/10 12:41 PM
09/29/10 12:41 PM
JohnRR
You get what you pay for, I would think your vision is worth more than 49 bucks.
Re: Mig welding Q&A
[Re: BSharp]
#814071
09/29/10 04:38 PM
09/29/10 04:38 PM
Dave_J
Auburn WA
Just my opinion. You should always have the ground clamp as close to your weld area as possable. But on any vechile you need to disco the battery. Thats about all you can do. I have heard of people removing the ECM/Computers. If your going to weld anywhere within 4 feet of the ECM, I'd remove it for sure.
