Re: Started My Build For Next Years Drag Week ...UPDATE
[Re: tboomer]
#810876
05/03/11 10:06 AM
05/03/11 10:06 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Nice fab work,Raff! It should look good with that diamond plate!!
Well I decided to cut the back wall under the tubes so I can drop the chassis in tack and weld it all up then on the install I'll weld the upper bars via the back window area then weld the back wall back up... I'm going to do that today and drop the chassis... thanks Ted... it'll look much better once its welded and painted... the tubing thats rusted at the back was in the pole barn and got wet... oh well a scotch brite will take care of that
[Re: tboomer]
#810878
05/03/11 10:16 AM
05/03/11 10:16 AM
MR_P_BODY
What are you using for paint on the bars?
Its like POR-15 but its called Chassis Saver(alot of semi shops use it)
[Re: tboomer]
#810880
05/03/11 10:29 AM
05/03/11 10:29 AM
MR_P_BODY
I saved that thread about roll cage paint...I want to redo mine..
One thing about the POR-15 and Chassis Saver types they brush on and lay out smooth... I painted the trans with it and it layed out nice... I have to touch it up where I didnt clean it too good and it pealed some but I did a POOR job of cleaning in a couple of area's... I wanted to sand blast the case but was leary of getting sand in places
[Re: Labratt]
#810882
05/06/11 01:56 PM
05/06/11 01:56 PM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
Awesome pics!
Keep 'em coming!
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
[Re: cudadon]
#810884
05/06/11 08:31 PM
05/06/11 08:31 PM
MR_P_BODY
Well I have the body up on the hoist with the chassis on the floor and have been welding all day for the last 2 days... till I ran out of argon this evening... I'll pick up 2 bottles tomorrow... hope to have the chassis done by next weekend... this is what it looks like today
[Re: emarine01]
#810887
05/06/11 10:41 PM
05/06/11 10:41 PM
MR_P_BODY
But..... theres no gun rack
Here in Mich cant have them exposed... but there's enough tubing to hang some hooks on
[Re: MR_P_BODY]
#810888
05/11/11 01:02 AM
05/11/11 01:02 AM
MR_P_BODY
Chassis is completed... I started painting it today just to see what it looks like in the morning(dry)... I'm using a sort of POR-15 but this is called Chassis Saver that semi truck shops use... I'll see tomorrow... I still need to weld in the trans cross member in the morning... other than that I THINK its done... I'll get some pics tomorrow
[Re: MR_P_BODY]
#810889
05/11/11 01:52 AM
05/11/11 01:52 AM
Posts: 1,845 Tampa
DusterDave
Tampa
Wow, you made great progress! At this rate, you'll finish in time to make Drag Week with time to spare!
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#810890
05/11/11 02:23 AM
05/11/11 02:23 AM
MR_P_BODY
My buddy and myself made the decision not to go on drag week... we will go to one that a guy puts on in this area... 5 tracks BUT you can trailer the car to each track IF you want... if I'm done I will drive the route... its in the Mich and Canada area.... next year we will do drag week unless its farther out west OR fuel prices are too steep.... I have to true the rearend in the next day or so and weld the brackets on it... then it'll be a rolling chassis
[Re: RTSE4ME]
#810892
05/11/11 07:02 PM
05/11/11 07:02 PM
MR_P_BODY
That is nice work Mr P. Wish I could do that. Stupid question time.....How do you mount the body on a tube frame car?
I have 6 tabs that I weld on to the chassis then weld to the sills and back end... the front end bolts on... I was hopeing to be done today with the trans cross member but I'm 1 part short
