Page 5 of 16 1 2 3 4 5 6 7 15 16
Re: Started My Build For Next Years Drag Week ...UPDATE [Re: BBR] #810815
01/03/11 06:20 PM
01/03/11 06:20 PM
MR_P_BODY Offline OP
Only 9 months left! Better get to crackin' you have a long way to go!
Dale signed up on 460Ford.com and we've been talking about DW over there a little. I sure hope it's a little farther South this year!
Yeah I go in a day or so to pick up my tubing for
the chassis... been working on the body and still
cutting stuff out... I just talked to Turbo Action
about one of my converters I have and with the numbers
I gave Paul he said it should stall right at 5000
to 5200 so that will be about perfect... but he's not
real sure how how it will be in OD... but I'll find
out.... I have no clue where they plan on running
drag week this year
Re: Started My Build For Next Years Drag Week ...UPDATE [Re: MR_P_BODY] #810816
01/07/11 05:47 PM
01/07/11 05:47 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
Mark your calendar!
Looks like September 11-16 are the dates and locations will be announced on or around the 15th.
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: Started My Build For Next Years Drag Week ...UPDATE [Re: BBR] #810817
01/07/11 09:21 PM
01/07/11 09:21 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
We need progress pics! Get something done everyday, cuz September will be here before you know it!
I know this is jumping ahead, but.....who is doing the paint job, and what color will it be? I need to know, so I can get a visual of what it will look like when its done.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Started My Build For Next Years Drag Week ...UPDATE [Re: DusterDave] #810818
01/07/11 10:37 PM
01/07/11 10:37 PM
I work on it just about every day.... I'll do the
paint myself...I'm not sure on the color yet but
have been thinking about a few choices... thought
about turbine bronze... I have to check my stash to
see what colors I have... pretty sure I have a gal
of flame red still, might have some silver metallic
or might have some black still.... I'm still up in
the air as to color... I want something that stands
out... I dont think I'll go black cause this wont have AC
Re: Started My Build For Next Years Drag Week ...UPDATE [Re: DusterDave] #810819
01/09/11 01:26 PM
01/09/11 01:26 PM
This is a pic today
Re: Started My Build For Next Years Drag Week ...UPDATE [Re: MR_P_BODY] #810820
01/09/11 01:28 PM
01/09/11 01:28 PM
Last... hopefully it will start going the other direction
within a week(putting stuff on)
Re: Started My Build For Next Years Drag Week ...UPDATE [Re: MR_P_BODY] #810821
01/12/11 02:35 PM
01/12/11 02:35 PM
Just about done cutting things out... this is where it
stands now... I still need to trim around the wheel
wells... I cant cut the back of the bed off yet...
thats where I have my caster legs mounted... as soon
as I get some tubes mounted to the back cross brace
I can cut it off
Re: Started My Build For Next Years Drag Week ...UPDATE [Re: MR_P_BODY] #810822
01/12/11 02:37 PM
01/12/11 02:37 PM
Re: Started My Build For Next Years Drag Week ...UPDATE [Re: MR_P_BODY] #810823
01/12/11 02:38 PM
01/12/11 02:38 PM
Re: Started My Build For Next Years Drag Week ...UPDATE [Re: MR_P_BODY] #810824
01/12/11 02:40 PM
01/12/11 02:40 PM
last for now
Re: Started My Build For Next Years Drag Week ...UPDATE [Re: MR_P_BODY] #810825
01/12/11 03:18 PM
01/12/11 03:18 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Must be burning a lot of fire wood to work out in the garage at 23 degree's.
Re: Started My Build For Next Years Drag Week ...UPDATE [Re: rowin4] #810826
01/12/11 03:23 PM
01/12/11 03:23 PM
Nope... gas powered radiant heat... I keep the shop
at 64* and that cost about $35 a month
Re: Started My Build For Next Years Drag Week ...UPDATE [Re: MR_P_BODY] #810827
01/12/11 03:46 PM
01/12/11 03:46 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
.... That thing sure looks like the start of a Mud racer to me
Re: Started My Build For Next Years Drag Week ...UPDATE [Re: emarine01] #810828
01/12/11 03:52 PM
01/12/11 03:52 PM
LOL... I think they all sorta start in the same place...
just a shell... I'll take out about another 25 lbs
then it'll start going the other way
Re: Started My Build For Next Years Drag Week ...UPDATE [Re: MR_P_BODY] #810829
01/12/11 04:06 PM
01/12/11 04:06 PM
tboomer Offline
tboomer  Offline
Raff...You sure are busy for a retired fella!! Looks like it is coming along
Re: Started My Build For Next Years Drag Week ...UPDATE [Re: tboomer] #810830
01/12/11 05:22 PM
01/12/11 05:22 PM
Fixing the body took longer than I expected but
its about ready... I was going to pick up my
chassis tubing tomorrow but I'm gonna hold off
till Tuesday to pick it up... my buddy wants to
come along, that why Tuesday... he wants some
tubing also for his project also
Re: Started My Build For Next Years Drag Week ...UPDATE [Re: tboomer] #810831
01/26/11 11:55 PM
01/26/11 11:55 PM
This is what it was the other day... I added a few bars
since then... then started looking at the steering
and how far back the rack will be... this MIGHT be
a issue... the way I see it now the rack will be below
the frame rails right in the middle of the engine
(fore and aft) so its going to be a tricky oil pan
at the minimum.... at least I have a month to think
this out
EDIT
Just doing some quick measurements I see that is not
really any problems... where I thought the engine was
going to be isnt true... just got to move the firewall
and the heater... I'm sure I can work around that
Re: Started My Build For Next Years Drag Week ...UPDATE [Re: MR_P_BODY] #810832
01/27/11 12:06 AM
01/27/11 12:06 AM
rowin4 Offline
rowin4  Offline
Looks like it's finally going together instead of apart. Look's like you might need a couple more jack stands.
Re: Started My Build For Next Years Drag Week ...UPDATE [Re: rowin4] #810833
01/27/11 12:26 AM
01/27/11 12:26 AM
Yeah its FINALLY going in the other direction...
I screwed up on my dimensions(in my head) so its
not all that bad... like everything in a small car
things are close... but I did gain radiator clearance
Re: Started My Build For Next Years Drag Week ...UPDATE [Re: MR_P_BODY] #810834
01/27/11 12:41 AM
01/27/11 12:41 AM
mt. vernon, oh.
aarcudaden Offline
Dennis the Menace
aarcudaden  Offline
Dennis the Menace
mt. vernon, oh.
Im really looking forward to seeing pics of this thing when its starting to come together
