Dual quads vs Six pack #81039
06/28/08 05:18 PM
06/28/08 05:18 PM
Iowa
73ChargerSE440 Offline OP
Iowa
Which is the better choice?
What are the pros and cons of each?
Re: Dual quads vs Six pack [Re: 73ChargerSE440] #81040
06/28/08 06:06 PM
06/28/08 06:06 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Maximum hp, maximum torque, very good all around driveability? Tunnel ram with 2 four barrels every time. Dave
Re: Dual quads vs Six pack [Re: 73ChargerSE440] #81041
06/28/08 07:02 PM
06/28/08 07:02 PM
God's Country Maryland
GODSCOUNTRY340 Offline
My single 4bbl, 850 Holley out ET'ed my Six Pack by 4 tenths. When you think about it, the Six Pack came off the line on the center 2bbl (300cfm) where the 850 came off with 850cfm.
Re: Dual quads vs Six pack [Re: GODSCOUNTRY340] #81042
06/28/08 07:42 PM
06/28/08 07:42 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Depends on the build of the rest of the motor. If it's say a ~500hp street/strip 440, a single 4 could perform as just as good as a dual quad manifold(assuming your talking about something like the edelbrock ch-28, not a tunnel ram) or a 6-pack setup.
6-packs are nice but they are mainly bling/bragging rights. Yes they can perform well, but a well tuned/selected 4bbl could perform equally or better than a 6-pack. Same goes for a dual quad intake. More carbs does not necessarily mean better power, although it does mean more work to tune.
Re: Dual quads vs Six pack [Re: GODSCOUNTRY340] #81043
06/28/08 07:51 PM
06/28/08 07:51 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
As per the org question, theres no doubt a dual 4 will hang out a six-pack in almost everyway, but im and I know alot of others that will run head to head with a single 4 most anyday.
Although Ive never heard how sixpackgut made out with his SP with the sheetmetal TR intake deal.
Even recently a mag did a comp. of the six-pack vs the large single 4 to see if the SP still had the azz to back up the shock of 3x2`s and I beleive the six-pack (not near oem stock carbs) but neither was the 4bbl still outdid the single just a bit.
Should of bought it instead of just looking but it wasnt a mopar specific mag.
If I didnt have so much in my SP deal id have 2-4`s but balh blah blah a single 4, airgap ect is as commom as...well whats under the hood of most every chrysler,ford or chevy...a single 4.
And really a dual 4 setup does not cost that much more then a single but you can sink alot in a SP setup. If the SP still didnt cut it I dont think QF and ProMax would be selling the parts they do for them.
But of course theres a reason I feel this way..
Re: Dual quads vs Six pack [Re: 73ChargerSE440] #81044
06/28/08 10:54 PM
06/28/08 10:54 PM
Missouri
bb74swngr Offline
mopar addict
bb74swngr  Offline
mopar addict
Missouri
Dual quad for two years now. Swinger street car sleeper, 440, AT, PS, PB, AC, CC, lotsa TQ. Have zero tuning problems...it's just a four barrel until WOT. Having fun.
Russ n Virginia:)
BigBlock 74 Swinger
Re: Dual quads vs Six pack [Re: bb74swngr] #81045
06/28/08 11:05 PM
06/28/08 11:05 PM
Missouri
bb74swngr Offline
mopar addict
bb74swngr  Offline
mopar addict
Missouri
By the way, my previous car was a 70 Chally 440 SP Vert with AT, PS, PB, and AC. Had zero tuning problems...it was just a two barrel until WOT. Had lotsa fun. They are both great!!!!
Russ n Virginia:)
BigBlock 74 Swinger
Re: Dual quads vs Six pack [Re: bb74swngr] #81046
06/28/08 11:51 PM
06/28/08 11:51 PM
Pataskala, Ohio
GTX70sixpack Offline
Pataskala, Ohio
If we are talking about a stock set-up, street driven, you can't beat the six pack for driveability (cold start, road manners, mpg, and power). The factory dual quad setups are cold natured and tend to use more fuel, wot is great however.
When you start talking about after market intakes, carb options etc; sure you can out perform stock set-ups, and loose drivability in exchange for performance "sometimes".
In stock trim I prefer the sixpack, I have two currently and plan on adding a third. I was also planning on adding a crossram setup but it was for a road trip car and I've been thinking twice with fuel cost what they are.
I get 16.5 mpg if I drive sane with 3:54s in my GTX. I have heard 11 mpg with the 440 crossram.
65 Belvedere II Station Wagon
69 Coronet R/T convertible
70 GTX
70'cuda
99 Dodge Diesel dually 4X4
Re: Dual quads vs Six pack [Re: GTX70sixpack] #81047
06/29/08 01:45 PM
06/29/08 01:45 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
The Edelbrock 2x4 set up offers awesome performance and eye appeal at half the price of a six pack set up. A single four will make as much as or more power (RPM or Team G?) but c'mon, single 4bbl V8s are EVERYWHERE.
Keep old mopars alive.
Re: Dual quads vs Six pack [Re: 2boltmain] #81048
06/29/08 01:53 PM
06/29/08 01:53 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
so. they could be on to something.
id go dual quad if i had to choose one or the other. a 4 bbl will win for most levels of play. ages 12 and up. batteries not included. run with adult supervision.
Re: Dual quads vs Six pack [Re: 73ChargerSE440] #81049
06/30/08 11:31 AM
06/30/08 11:31 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
The carbs are really just air and fuel mixers and if they do that properly it is the design of the intake manifold that has more bearing on what works the best. For all out power the factory six pack intakes will hold back power as will the factory Hemi 2X4 intake.
For streetability it is hard to beat the stock six pack setup and the factory Hemi 2x4 intake setup works nicely as well.
I've run both for 30 years now and currently my factory 2x4 Hemi setup makes my six pack look stupid at both the high rpm and the low rpm of the power range. They are both very street driveable though. I've spent lots of hours tuning the Hemi (but now that it's close to right it won't need anymore fiddling) the factory six pack calibration has run great right out of the box but there's probably a bit of power left on the table with tuning.
Sheldon
Re: Dual quads vs Six pack [Re: 73ChargerSE440] #81050
06/30/08 12:41 PM
06/30/08 12:41 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I love dual quads, ran them alot and never had any problems. I've never ran a six pac on a MoPar ever, so I can't judge...
CrAzYMoPaRGuY
Re: Dual quads vs Six pack [Re: CrAzYMoPaRGuY] #81051
06/30/08 01:13 PM
06/30/08 01:13 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
I have never seen a comparison of the latest 440 Edelbrock dual quad int against the six pac.All of the old flat factory type intakes are way down on power as was shown in the recent Hot Rod mag tests.However it is my opinion that the newer Edelbrock might be the six pac's equal.It appears to be a dual quad Performer, much higher than the old stuff, dual plane with large runners.Edelbrock makes a very nice air cleaner to match too.Much cheaper too.
Leave the gun.......take the Cannoli's....Mike
Re: Dual quads vs Six pack [Re: mike s] #81052
07/03/08 04:59 PM
07/03/08 04:59 PM
Iowa
Iowa
Sorry guys I have been on vacation, does the dual quad set-up use a 600cfm by chance I have an Edelbrock off my 318.
Re: Dual quads vs Six pack [Re: 73ChargerSE440] #81053
07/03/08 05:39 PM
07/03/08 05:39 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Dual quads vs Six pack [Re: DPelletier] #81054
07/03/08 06:19 PM
07/03/08 06:19 PM
Iowa
Iowa
440.....what would I have to do use the one 600 I have, add another 1200 cfm a 440 stroker setup or change cams or both?
Re: Dual quads vs Six pack [Re: RUNCHARGER] #81055
07/03/08 06:58 PM
07/03/08 06:58 PM
DPelletier Offline
DPelletier  Offline
I agree (assuming the carbs are of adequate size)
Sheldon
You didn't tell them that your Hemi is a wicked fast 472! ..........not that I would know for sure seeing as how I haven't gone for a ride yet!
j/k
Re: Dual quads vs Six pack [Re: DPelletier] #81056
07/06/08 05:11 PM
07/06/08 05:11 PM
Iowa
Iowa
What kind of mods do I need to do for 1200cfm 440 Stroker? 440 stroker + cam? or just jet down the 1406 Edelbrocks I was leaning toward the CH-28 by Edelbrock for intake.
Re: Dual quads vs Six pack [Re: 73ChargerSE440] #81057
07/06/08 05:28 PM
07/06/08 05:28 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Edelbrock actually reccommends 2 600cfm carbs on the CH-28. On both my 440s I have used 2 500cfm carbs and it worked FANTASTIC. If a person already has a 600cfm Eddy carb I would buy one more and call it good. Alot of small block chevy guys run dual 600s on their eddy 2x4 set up and claim success. My 360 will run an OFFY 2x4 and dual 500s.
Re: Dual quads vs Six pack [Re: 2boltmain] #81058
07/07/08 05:44 PM
07/07/08 05:44 PM
Iowa
Iowa
