Re: torsion bar removal tool
[Re: earlybee]
#80959
06/28/08 11:48 PM
06/28/08 11:48 PM
Interesting, so even if teeth marks were evident, no matter how light, you would replace them.
#80961
06/28/08 11:56 PM
06/28/08 11:56 PM
Posts: 12,248 Looking for a way out of Middl...
IMGTX
Small Scratches can become big cracks very fast in a piece of metal under stress. Hence the reason for polishing Rod sides etc.
[Re: IMGTX]
#80962
06/29/08 03:47 PM
06/29/08 03:47 PM
Posts: 2,315 MOPAR HEADQUARTERS IN ALDEN NY
hemigod426
Scratches caused by tools etc cause stress marks that can cause failure. If the Vise grips don't leave marks then no harm done. Most tools do not have serations on them just flats to prevent scratches.
I never used a tool, ever. I always loosened the LCA and slid it back if the bar didn't come out on it's own. Many people don't clean the rear of the Tbar socket or release the Tbar completely by removeing the UCA stop. If you don't you will need the tool.
up north where the t-bars and hex sockets become one with rust the only way to get it out is the tool, or if you ever bent them racing, from wheelly pops, they wont be easy to get out. to monkey with loosing up lcas, to tap it all back, you will have to take apart sway bar links,strut rods,brakes,wheel,lower ball joint,ect...with tool its 5 minute job, dont even have to take front wheel off.jack up car, impact t-bar jack bolt loose,clamp on tool, remove rear clip, and tap out towards rear ![](/ubbthreads/images/graemlins/wrench.gif)
MOPAR OR NO CAR
[Re: earlybee]
#80963
06/29/08 04:06 PM
06/29/08 04:06 PM
Posts: 8,964 Pizza Bucket
snuggles
Pizza Bucket
Well, the teeth marks cause fatigue cracks over time. You may get lucky for a while but the snap failure at any time will make you wiser if you live thru it.
I had a bar snap but was in my own drive. I neverr had them out of that car.
[Re: snuggles]
#80964
06/29/08 09:24 PM
06/29/08 09:24 PM
It seems I'll be spending a few bucks on T-bars now, great! Not to jack the original posters thread, but any ideas where to get a pair, and should I stay with the stock size, or go up a size or two on the diameter. Thanks.
[Re: hemigod426]
#80966
06/29/08 10:30 PM
06/29/08 10:30 PM
383 car, I guess the same as 440?
#80970
06/29/08 11:17 PM
06/29/08 11:17 PM
Posts: 8,064 Arlington, Texas
earlybee
Arlington, Texas
I got a set of 960s from Monicatti after looking for the best deal. Their a board sponsor here so tell them your a member, Torsion Bar Set - 0.960 Price:$177.65 Part Number :P5249158 http://www.monicattichrysler.com/comersus/store/comersus_searchItem.asp Type in torsion bar in the search box.
[Re: earlybee]
#80972
06/30/08 09:05 AM
06/30/08 09:05 AM
Thanks for the advice Hemigod426, front disc brake conversion is probably in the future. Also thanks very much earlybee for the hook on the t-bars. The .960 are probably the way to go. Do I need a discount code, and where would I get one?
[Re: snuggles]
#80973
08/09/08 03:27 PM
08/09/08 03:27 PM
Posts: 1,074 So Cal, USA
Fab64
So Cal, USA
can bars with small nicks be dressed?
According to the FSM, they can. My 1967 manual says:
"Inspect torsion bars for scores and nicks. Dress down all scratches and nicks to remove sharp edges, then paint repaired area with a good rust preventative."
[Re: Fab64]
#80974
08/09/08 04:08 PM
08/09/08 04:08 PM
Posts: 1,213 Los Angeles, CA
Mobarge
Los Angeles, CA
Whatever you do, be sure to get the tool. Hemigod's looks a lot better than the other one I bought years ago. Nice and solid. I destroyed the other tool I bought after using it a couple of times.
And, while the bars are out, why not do the .92 torsion bar upgrade. I did, and it was totally worth it.
'71 SSP - SOLD!
[Re: BDW]
#80978
12/22/10 09:14 PM
12/22/10 09:14 PM
Posts: 683 Northern NJ
68 Sat
Northern NJ
Don't waste your time with any other contraption then Hemigods removal tool. I used it last night to remove my torsion bars and it works liked a charm. Really well built and saved my ass. Just buy it
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor
1969 Dodge Coronet 500
1956 Desoto Hemi
1955 Chrysler C300
