Re: 5.9 magnum hates mods?
[Re: Ultanium]
#809953
11/11/10 08:44 PM
11/11/10 08:44 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
I'm also thinking valve timing is off.
"Fuel sync" does very, very little (emissions mainly, and a skosh of low-end torque) - BUT, if way off, the distributor rotor can be misaligned with the cap towers - that's why is needs to be set right. Many early MPI systems weren't even sequential - they were batch fired.
Rick
[Re: RawnDart]
#809957
04/21/13 09:55 AM
04/21/13 09:55 AM
Posts: 16 Bellville, Texas
Ultanium
Bellville, Texas
Just a final post about this project. I installed a polished TB from a board member, and it helped a little, but I never was able to get this truck right. My guess is the cam was a little off, and I sold the truck to help pay for new toys. If anyone else does a Dak, may I suggest a couple things? First, start with a 96 or newer truck so you can tune the thing, or get the other M1 intake and put a carb on it. Second, double and triple check the cam timing! Save yourself the headache, and buy or borrow a degree wheel. This truck should have been well into the 13's at the track, not 17's. I'm now working on a 71 Demon 340, and have bought a degree wheel, do not trust the marks.
Tom
