Accusump install pics
#808014
09/19/10 02:10 PM
09/19/10 02:10 PM
Posts: 617 Corvallis,OR
540CUDA
super street
super street
Corvallis,OR
Im looking to avoid a costly replay of Cudabins misfortune. Does anyone have some pics and advise they would be willing to post? Im using Indy-1's as well and plan to upgrade with some drainbacks to the pan over the winter. Thanks Tony
PRH 540,T-ram,-1's tagged and insured. 9.24et 146.13mph 1.30 60'3300#s
Re: Accusump install pics
[Re: 540CUDA]
#808016
09/19/10 03:12 PM
09/19/10 03:12 PM
Posts: 4,293 Morrow, OH
markz528
Morrow, OH
No pics but mine is mounted on the driver side of the engine plate..............
[Re: 540CUDA]
#808018
09/19/10 03:32 PM
09/19/10 03:32 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
if possible use a 4 port remote filter base. Using the extra outlet for your connetion makes it very easy to feed the accusump with clean oil and return it to the same place your filter does. That way you supply oil diretly to the critcal area, some herechose to use the port where the oil pressure gauge isand that's no good.
here where it mounts
home of the Sox and Martin Hemi Duster
[Re: HEMIFRED]
#808021
09/19/10 04:10 PM
09/19/10 04:10 PM
Posts: 6,295 U.S.
moparniac
U.S.
fred do you have another pic where it feeds into the block down there? if so thx ![](/ubbthreads/images/graemlins/thumbs.gif) I have a melling HV oil pump
Mopar Performance
[Re: HEMIFRED]
#808024
09/20/10 09:30 PM
09/20/10 09:30 PM
Posts: 903 Saskatchewan, Canada
cudabin
The Indy Maxx block has #8 threaded port to run an external pickup directly to the front of the block. Could you plumb the accusump to that, or does the fact that it is a suction line mean it would just drain it right away??
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: 540CUDA]
#808027
09/20/10 11:32 PM
09/20/10 11:32 PM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
I tucked mine up under the front bar...
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#808028
09/21/10 02:34 PM
09/21/10 02:34 PM
markz528
Morrow, OH
Here is a picture of mine. I use the Accusump filter adapter to plumb into. It has a large fitting port so that the #10AN line is not restricted. ![](http://home.fuse.net/markz440/acc.jpg)
[Re: markz528]
#808029
09/21/10 03:42 PM
09/21/10 03:42 PM
540CUDA
super street
super street
Corvallis,OR
Thank you for all the pics and replies, very helpful. I have another question, what pressure should I set up the system at if using an electric valve? I see they (accusump) have a few different options. My Titan pump runs at 70psi. I am using a CV products remote filter mount. It only has three ports, but theres a port Im not using. Would that be a good supply to the reservoir? like the 4-port Fred is suggesting. Thanks
[Re: HEMIFRED]
#808032
09/22/10 01:49 PM
09/22/10 01:49 PM
540CUDA
super street
super street
Corvallis,OR
So for the manual lever system you just open the valve before you make the run? or do you have a have a cable/lever to open it should the need arise. I guess I dont understand how it would automatically release pressurized oil with a manual ball valve at the accumulator. Sorry for the ignorance.
[Re: 540CUDA]
#808033
09/22/10 03:29 PM
09/22/10 03:29 PM
Posts: 2,930 Odessa, Tx.
cudarex
Odessa, Tx.
It has pressurized oil in it so before your start car turn valve to release oil into motor for priming. Acumulator will recharge once motor starts and then you can turn valve off for next start or leave valve open until just before you kill motor and then turn off valve.
