Page 9 of 19 1 2 7 8 9 10 11 18 19
Re: 514 on the dyno [Re: AndyF] #804332
10/04/11 06:55 PM
10/04/11 06:55 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I think I'll just keep beating on the EZ heads to see if I can hit the 900 hp mark. Just seems like an interesting challenge.
Nice updates Andy. It is a neat concept but, I think you should upgrade the top-end and go for 1100HP.
Re: 514 on the dyno [Re: Streetwize] #804333
10/04/11 10:30 PM
10/04/11 10:30 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Russ Flagle told me SRs & EZs were similar ports except the SRs ex port is better. Perhaps 50 hp better. Don
Re: 514 on the dyno [Re: cudadon] #804334
10/08/11 03:00 AM
10/08/11 03:00 AM
AndyF Offline OP
AndyF  Offline OP
Yes, the SR and the -1 have raised exhaust ports which on this engine probably would improve the power a fair amount. Also, the -1 heads have larger intake runners. So even though they flow roughly the same, the extra volume would probably help make more power.
But changing heads is not part of the plan. I already know that better heads would make more power. -1 heads would make more power, then B1 heads would make even more power and then Predator heads would make even more power.
I'm more interested in sticking with one basic combination and sorting it out. So I'll just stick with the EZ heads and see where it goes. 900 hp seems like a reasonable goal at this point.
Biggest debate I'm having at the moment is if I should stay with the 4.440 x 4.150, or increase the stroke. I could slide a 4.50 crank in there to pick up the size as well as the compression. I'm just not sure that bigger is better when the motor is already limited by the heads. Maybe smaller with more RPM makes more power?
Re: 514 on the dyno [Re: AndyF] #804335
10/08/11 12:15 PM
10/08/11 12:15 PM
gregsdart Offline
gregsdart  Offline
"Biggest debate I'm having at the moment is if I should stay with the 4.440 x 4.150, or increase the stroke. I could slide a 4.50 crank in there to pick up the size as well as the compression. I'm just not sure that bigger is better when the motor is already limited by the heads. Maybe smaller with more RPM makes more power? "
That was exactly my question when I built the motor I now have. I felt that the 4.15 stroke x 4.5 bore combo offered the best size for the 440-1 heads. Maybe I was off the mark, maybe not. I had a billet 4.5 crank at the time, chose the 4.15.
It would seem that at some point the total amount of air filling the cylinder at a given rpm must be reduced as the motor gets bigger, reducing running compression? Ring friction goes up, the biggest drag on the motor. Crankcase windage gets worse. Which would start to clip the hp up top more than just the differance in size of the motor.
At this point I still wonder if even smaller motor with the biggest bore possible might be the answer, say (edit)4.500 by 3.9 in strke for about 496 cubes. That would put the motor more in the sweet spot of what I have, a running range of 6400 to 7500 rpm..
Re: 514 on the dyno [Re: dirty magnum] #804336
10/08/11 01:18 PM
10/08/11 01:18 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
can you post dyno sheet so we can see
dyno sheets?
about 820 hp or it made 820 , can you post sheets so we can see power band ect.
good luck getting dyno sheets, he NEVER post them.......
Keep holding your breath.......He doesn't even have enough sack to answer why he won't post a dyno sheet, so IMHO, this whole thread is pretty useless.....
The bracketry is nice to look at though.....
If you can't handle the truth, you're living a lie.......
Re: 514 on the dyno [Re: Big Squeeze] #804337
10/09/11 12:24 AM
10/09/11 12:24 AM
mi
dirty magnum Offline
mi
well said useless
Re: 514 on the dyno [Re: dirty magnum] #804338
10/09/11 12:48 AM
10/09/11 12:48 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Andy may not have a dyno sheet printed up. He was just trying tests and all logged on computer. I'm just saying
Re: 514 on the dyno [Re: AndyF] #804339
10/09/11 01:51 AM
10/09/11 01:51 AM
Andy, have you looked at the dyno fuel system I have seen them, more than one not up to making as much power us Mopar engine guys can make There are reasons, usually, why a motor won't respond to changes , on the dyno and at the track Finding them is the challenge sometimes IHTHS
Re: 514 on the dyno [Re: Cab_Burge] #804340
10/22/11 02:35 AM
10/22/11 02:35 AM
AndyF Offline OP
AndyF  Offline OP
I think the fuel system is fine. I might upgrade the regulator since it acts a little funny sometimes, but the fuel system holds 7 psi during the pulls so the carb should be getting plenty of fuel.
My new connecting rods showed up the other day. I'm going to upgrade to the Oliver 7.100 rods this winter and add some compression.
Re: 514 on the dyno [Re: gregsdart] #804341
10/22/11 10:29 AM
10/22/11 10:29 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Greg I agree with what you think on the HP issue. However I've seen some head limited engines produce good E.T.s. That leads to the question. Can some combinations benefit from more low end power through the range? Take Jakes 63 Savoy. 572,-13 heads,Indy cross ram w/carters,cal tracks,approx 3675lbs. 899@150 The math suggests it makes way more than we think. But i'll bet the torque curve looks as flat as Nebraska..
Doug
Re: 514 on the dyno [Re: dvw] #804342
10/22/11 11:00 AM
10/22/11 11:00 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Andy
Not refering specifically to this build but i wondered what your opinions or experiences are with the super sucker dominator adaptor, or super sucker spacers in general. The reason i ask, is Dwayne suggested it might help my combo some and while i respect his greatly more knowledgable opinion than mine, it would also be nice to hear others experiences of them good or bad.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: 514 on the dyno [Re: deaks] #804343
10/24/11 01:38 AM
10/24/11 01:38 AM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Mick..I've wondered about the Super Suckers myself!
Re: 514 on the dyno [Re: deaks] #804344
10/24/11 03:11 AM
10/24/11 03:11 AM
Idaho
LaRoy Engines Offline
Idaho
Andy
Mick
First chance I've had to read this thread.
I'm not on the level of Dwayne or Andy, I'm one of the "others", but I have tried the Super Sucker on single plane, single carburetor, engine combinations from 620-920 HP and have found the Super Sucker to increase horsepower every time.
And Andy, Thank you for the idea to put the window in the water return line, it would have saved our bacon in the contest. Plus, I for one, do believe the power you make with the 514 combination you are running. Our 500 with the Victor heads, HS Rockers, 13.5:1, the Indy 3X, 1150 Dominator and wet sump will pull those numbers. I think 900 HP is possible.
Re: 514 on the dyno [Re: LaRoy Engines] #804345
10/24/11 09:20 AM
10/24/11 09:20 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Thank you, can i also ask does the 2" pick up more than the 1" and have you tried the 4150 to 4500 adaptor and what you thought of that.
This question is to Andy, Heyoldguy or anyone else reading this thread, Andy, please say if you would like me to take this question to email.
Mick
best 60ft 1.36
Re: 514 on the dyno [Re: LaRoy Engines] #804346
10/24/11 02:53 PM
10/24/11 02:53 PM
AndyF Offline OP
AndyF  Offline OP
Hi Jim,
Welcome to the board. Always great to have experienced engine builders adding their knowledge to the forum.
I spent a lot of years in Idaho growing up but I haven't been back in awhile.
My 514 is underperforming if anything. A lot of guys are making way more power per cubic inch than I'm getting out of this motor. Have you worked on the EZ heads much? You sure got some great numbers out of those cast iron heads.
Re: 514 on the dyno [Re: deaks] #804347
10/24/11 02:57 PM
10/24/11 02:57 PM
AndyF Offline OP
AndyF  Offline OP
Carb spacers are just one of those things that you need to try to see how it works. Most engines will gain power with a taller spacer, but it doesn't always reduce the ET. We use 3 or 4 inch tall spacers on the dyno to add power, but in a car that tall of a spacer often causes a stumble unless you add a bunch of volume to the accel pump.
Re: 514 on the dyno [Re: AndyF] #804348
10/27/11 06:35 AM
10/27/11 06:35 AM
Idaho
Idaho
Hi Jim,
Thanks, Andy
Yes, I agree, there is more remaining in the 514.
As to the EZ heads, I picked up a set 18 months ago and spend a day fiddling with them and they went to 350cfm. I thought, "That's enough for now," and put them back on the shelf. Still gathering dust, but some day.....I'll turn them over to my son.
My son Cody is our real head porter. The iron heads are a result of an article by Cam Benty in the Dec, 1982 issue of Popular Hot Rodding. Cam did an article on my Dad's 440 and my son read it in 2004. Cody wanted to attempt what Dad had done back then, pulled out the old flowbench and began destroying cylinder heads. He finally figured it out after producing a huge pile of scrap iron.
In 2008 I was running 906 heads on my 451" Road Runner at the chassis dyno at Westech. I had a 383 on the engine dyno at the same time and when I came out of the dyno room, some guy was taking pictures of the Road Runner on the rollers. It was Cam Benty. He wanted to know how the 451 was making 554 RWHP on 91 octane and a single 4bbl. We started talking about the cylinder heads. He was interested in doing an article about the 906 heads but it never happened. I did however, get his autograph on a copy of the article about my Dad.
Enough, I thought this was supposed to be about your 514.
I really like those Super Performance gaskets you use. I've used other types and it took dynamite and tire tools to remove the intake. With the Super Performance gaskets I just unbolt and lift. Rats, I went and looked at the package, they are Superformance gaskets.
Re: 514 on the dyno [Re: LaRoy Engines] #804349
10/27/11 10:04 AM
10/27/11 10:04 AM
gregsdart Offline
gregsdart  Offline
With great numbers already, where do you think more power lurks? Inquiring minds would like to know
I remember you were thinking of more stroke.
Enough in a bigger bore to consider? Other areas?
Re: 514 on the dyno [Re: gregsdart] #804350
10/28/11 07:12 PM
10/28/11 07:12 PM
AndyF Offline OP
AndyF  Offline OP
I'm going to add some compression and put a bigger cam in it. Right now the cam is only 266/276 with .400 lobe lift. The guys at Crane have suggested a 280/286 with .452 lobe lift.
I also have a few other upgrades in the works including some intake manifold porting and a new oil pan.
Re: 514 on the dyno [Re: AndyF] #804351
11/03/11 06:46 PM
11/03/11 06:46 PM
AndyF Offline OP
AndyF  Offline OP
The intake is back from Wilson. They did a super nice job on it. I don't know how they port these things, but the finish is super nice all the way down the runners.
