Re: 514 on the dyno
[Re: AndyF]
#804355
11/03/11 09:06 PM
11/03/11 09:06 PM
fast68plymouth
So. Burlington, Vt.
the "if it were me" response is.......i would get another OOTB intake so i could do a back to back test against the ported one.
Re: 514 on the dyno
[Re: fast68plymouth]
#804356
11/04/11 03:30 AM
11/04/11 03:30 AM
Posts: 4,076 Mo.
racerx
Mo.
That would be a interesting comparison
Re: 514 on the dyno
#804357
11/04/11 08:39 AM
11/04/11 08:39 AM
Posts: 13,400 Marion, South Carolina [><]
an8sec70cuda
I'd really like to see that.
Re: 514 on the dyno
[Re: AndyF]
#804362
11/04/11 02:56 PM
11/04/11 02:56 PM
Posts: 4,076 Mo.
racerx
Mo.
Here is a side by side shot showing unported vs. ported.
Sense there both there a comparison would be nice
Re: 514 on the dyno
[Re: WheelsUp73]
#804365
11/04/11 10:58 PM
11/04/11 10:58 PM
Posts: 31,076 Oregon
AndyF
This one is a dyno motor. My car has a different motor in it.
Re: 514 on the dyno
[Re: Labratt]
#804367
11/05/11 11:29 AM
11/05/11 11:29 AM
Posts: 10,018 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Andy's giving out EXCELLENT information...along with pics,and "DO-NOTHINGS" like you have to throw your little wize-azz remarks in! I don't get it! I'm sure this is why more than a FEW knowledgeable people stay away from this site!
Lab, good to speak up. Knowledge like that is hard won and I appreciate it a great deal, as do many, looking from the post count. I wish I had the $$ to do a dyno motor like this- then after many, many changes build another motor based on everything I learned and run THAT one!
Re: 514 on the dyno
[Re: Labratt]
#804370
11/07/11 01:43 PM
11/07/11 01:43 PM
Posts: 577 Arkansas
Adrielp
Arkansas
Andy, what rpm have you gone up to? Also, is the power curve still rising at the end of the pull. In theory, if the heads/cam combo can support the higher rpm, one would assume there maybe more power available but I don't know if that would higher rpms would suit this motor with the 4.15 stroke. I would think 8500(or a lil higher) maybe the highest plateau but who knows, I'm not a skilled engine builder like you guys, just a young student.
Adriel Paradise Substation Design Engineer III
