Page 3 of 19 1 2 3 4 5 18 19
Re: 514 on the dyno [Re: greendart408] #804212
02/08/11 09:20 PM
02/08/11 09:20 PM
AndyF Offline OP
AndyF  Offline OP
This is good news. How much hp and torque is the new dyno stuff good for?? I forgot to ask Paul when I talked to him last..
Should be good for 1500 hp now but we need to verify that. We'll have a temp sensor in the dyno now so we can watch the temp of the water exiting the dyno. The new pump should hold 1500 hp but some of the older plumbing on the pressure side is restrictive so it might not actually handle that much power. That is the next upgrade on the list.
Re: 514 on the dyno [Re: MRMOPAR622] #804213
02/08/11 09:21 PM
02/08/11 09:21 PM
AndyF Offline OP
AndyF  Offline OP
Andy,with the big bore block wouldn't the 572-13 heads be a better choice? Only a question.
Sure, or B1 heads. But I don't have either of those so I'm running what I have.
Re: 514 on the dyno [Re: AndyF] #804214
02/08/11 11:21 PM
02/08/11 11:21 PM
KY
juicedcuda Offline
juicedcuda  Offline
KY
What size carb are you running?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: 514 on the dyno [Re: juicedcuda] #804215
02/08/11 11:26 PM
02/08/11 11:26 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
now nice job Andy,thats why bb's exist! power baby
Re: 514 on the dyno [Re: juicedcuda] #804216
02/09/11 02:21 AM
02/09/11 02:21 AM
AndyF Offline OP
AndyF  Offline OP
It is one of the new Holley Ultra Dominator 1150 carbs. These are nice carbs. All aluminum, external linkage, billet metering blocks with full adjustment, etc. This carb had a nice fuel curve right out of the box.
Re: 514 on the dyno [Re: AndyF] #804217
02/09/11 07:09 PM
02/09/11 07:09 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Hey Andy......Can you post the dyno sheet?.....also, have you put any of these dyno'd motors into cars, and if so, what have they run at the track?
If you can't handle the truth, you're living a lie.......
Re: 514 on the dyno [Re: Big Squeeze] #804218
02/09/11 10:55 PM
02/09/11 10:55 PM
AndyF Offline OP
AndyF  Offline OP
I bought a Duster race car so I can run the engines at the track, but it will take some time before the car is ready to go.
Re: 514 on the dyno [Re: AndyF] #804219
02/10/11 01:55 AM
02/10/11 01:55 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Cool.......Thanks......What's the Duster going to weigh and is this 514 going into it?
How about a dyno sheet?
Re: 514 on the dyno [Re: AndyF] #804220
02/17/11 07:00 PM
02/17/11 07:00 PM
Denmark
Dart of Denmark Offline
Denmark
Well it took a long time but we're ready to start running the 514 again. We had to install a new water pump for the dyno which cost a bunch of money, and then a bunch of the plumbing for the dyno cell had to be redone to handle the additional water flow. We also had to replace the existing load cell on the dyno and upgrade some sensors. So it took several months to fit all that work in around all of the other activity that was going on. But now the new dyno cell is back up and running. The new load cell has been calibrated and has had a few runs on it. So I'll be able to start getting some new numbers for this 514 this week.
Re: 514 on the dyno [Re: Dart of Denmark] #804221
02/18/11 11:37 PM
02/18/11 11:37 PM
AndyF Offline OP
AndyF  Offline OP
We did get about dozen dyno pulls made today. Engine is making about 830 hp at the moment. I'll do some intake manifold swaps and see what happens. We had the usual glitches that always seem to show up when running a lot of dyno tests so that slowed us down a bit. I'll have to look at the dyno sheets but I think this motor is making almost 750 ft-lbs.
Re: 514 on the dyno [Re: AndyF] #804222
02/19/11 02:48 PM
02/19/11 02:48 PM
AndyF Offline OP
AndyF  Offline OP
My mistake, torque peak is 715 ft-lbs at 5500 rpm. Almost all of the pulls showed 700 to 715 ft-lbs peaking right at the 5500 or 5600 point.
So far we've tried the Indy 440-3X and the Edelbrock Super Victor intake. I'm planning on running all of the MW intakes that I have on hand so that includes an Indy 440-2, B1 intake with adapter plates and an Indy dual plane. Only MW intake that I don't have is a MP 337 but I've run it before.
Re: 514 on the dyno [Re: AndyF] #804223
02/19/11 03:30 PM
02/19/11 03:30 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I look forward to the DP results. Thanks for sharing.
Re: 514 on the dyno [Re: AndyF] #804224
02/20/11 10:02 AM
02/20/11 10:02 AM
NC
440Jim Offline
440Jim  Offline
NC
You do some great dyno comparison swaps.
830/715 was that with the Indy 440-3X ?
What was the hp peak rpm?
I look forward to the intake/carb spacer comparison.
Re: 514 on the dyno [Re: AndyF] #804225
02/20/11 10:17 AM
02/20/11 10:17 AM
NC
440Jim Offline
440Jim  Offline
NC
I went through this topic to try and get the combo info all in one place. This is what was posted, so far:
514 CID
Mopar block with 4.440 bore and 4.150 stroke.
Indy MW EZ heads CNC ported by Modern Cyl Head, about 360 cfm.
Jesel rocker arms, 1.85 I and 1.70 E.
Solid roller cam with 266/272 duration.
Flat top pistons, gas ported
Compression around 12.4
Dry sump oil system
1150 cfm Holley Ultra Dominator
440-3X intake (will swap several)
Headers: ?? dia x ?? length x ?? collector dia
Re: 514 on the dyno [Re: 440Jim] #804226
02/20/11 11:58 AM
02/20/11 11:58 AM
gregsdart Offline
gregsdart  Offline
What ring size and type?
Re: 514 on the dyno [Re: gregsdart] #804227
02/20/11 12:46 PM
02/20/11 12:46 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Dyno sheet???
Re: 514 on the dyno [Re: 440Jim] #804228
02/20/11 01:49 PM
02/20/11 01:49 PM
AndyF Offline OP
AndyF  Offline OP
Headers are 2x32 with a 3.5 x 15 collector. They are probably a little small for this engine. I had them built years ago for my 650 hp engine. I hate to go buy another set for this engine so I'm probably leaving some power on the table.
I've run both the 440-3X and the Super Victor and the power curves look basically the same. SV was 715 ft-lbs at 5500 and 830 hp at 6700 rpm. The 440-3X was 715 ft-lbs at 5500 with 816 hp at 6700 rpm.
Re: 514 on the dyno [Re: AndyF] #804229
02/21/11 04:13 PM
02/21/11 04:13 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Thats cool!
Re: 514 on the dyno [Re: gregsdart] #804230
02/21/11 06:41 PM
02/21/11 06:41 PM
AndyF Offline OP
AndyF  Offline OP
Rings came with the pistons from Diamond. It is an 0.043 top ring. I don't recall the details on the rings but they were more "trick" than what I usually run. It was something that Diamond picked for the motor.
Re: 514 on the dyno [Re: Big Squeeze] #804231
02/22/11 10:52 PM
02/22/11 10:52 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Dyno sheet???
Are my posts not showing up?
