Re: Odd 440 block pad marking?
[Re: polkat]
#801871
09/17/10 09:36 PM
09/17/10 09:36 PM
Posts: 29,662 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
No HP. You can have HP or LC but not both for an engine this year. That is my theory. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: Alaskan_TA]
#801872
11/21/10 03:59 AM
11/21/10 03:59 AM
Posts: 1,324 Western Pa
joewhite440
Western Pa
No HP.
That is my theory.
I have a 71 G440 with the HP 2 stamp on the pad. It has the 1C in the Vin on the rail. It is the Green/Blue color like the Big C bodies had. What is the compression Ratio and what rods and pistons did they use in them. Were they 370 or 350 Horse? Just Curious!
Joe
[Re: joewhite440]
#801873
11/21/10 09:44 AM
11/21/10 09:44 AM
Posts: 1,445 Sterling Heights, Michigan 483...
daniel_depetro
I don't think it's suppose to be 'LC'? ![](/ubbthreads/images/graemlins/shruggy.gif) Here is a 1968 440 (non-High Performance 350 horsepower) and T/F-727 I picked up in 2006/07 for $400.00. It also has a 'C' stamped into it without an 'L' accompanying it. This combo was personally removed from a running station wagon by a guy I know well. He has no idea what he did the carburetor though, not that I wanted it anyways. He even threw in a set of original factory chrome valve covers! ![](http://img137.imageshack.us/img137/230/1968d440350hppadaq6.jpg) ![](http://img137.imageshack.us/img137/4658/1968d440350hpmr5.jpg) Here is the passenger side of the engine with the head removed. ![](http://img227.imageshack.us/img227/83/p1030346wd1.jpg)
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
[Re: 440beep]
#801875
11/21/10 11:36 AM
11/21/10 11:36 AM
Posts: 1,101 Retired now in Tennessee
Chi_Town_Runner
Sometimes I'm just simplistic. The backwards "B" may only be the fact that the line worker stamping it had the punch oriented upside down or stamped it from the opposite side of the block as he normally would do. A "B" appears backwards depending on how it's orientated. Just my ![](/ubbthreads/images/graemlins/Twocents.gif) Frank ![](/ubbthreads/images/graemlins/beer.gif)
Remember - 2 wrongs don't make a right - but 3 rights make a left!
[Re: Chi_Town_Runner]
#801876
11/21/10 02:52 PM
11/21/10 02:52 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Three pistons were installed at the factory.
Flat top 66-71 All 440 350 0r 370,375 h.p. rated 10-1 440-6 w/4 valve relief-440-6 only (1/2 point higher rated 10.5) 72-78 low comp 8.5-1. (piston comp distance changed).
Rods have nothing to do with engine comp ratio.Both are the same length.
Only difference between 350h.p and 375 h.p. were cam,valve springs,dist,exh man,and carb.
Leave the gun.......take the Cannoli's....Mike
my 440 block comp. ratio
[Re: mike s]
#801877
12/20/10 05:46 PM
12/20/10 05:46 PM
Posts: 1,319 Ohio
jlatessa
Ohio
OK, some new questions; I have a block from a 71 New Yorker, it has the big rods, steel crank and flat-top pistons that are .100 in the hole at TDC. It had 906 open chamber heads. On the boss, G440, 1 19 HPA Block casting #s 10-22-70 and 2536430-70 and 27143 on the pan mating surface. The other stencilled #s on the lower boss near the pan are illegible. I'm assuming this was a 370 horse Chrysler with these components. What was the comp. ratio with the pistons so far in the hole?? Can't be 10.0:1 can it? Thanks Joe Latessa ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
Re: my 440 block comp. ratio
[Re: jlatessa]
#801878
12/20/10 10:50 PM
12/20/10 10:50 PM
Posts: 2,601 Great White North
Furyman
Great White North
Your 71 Engine was advertised as a 9.5 to 1 compression.370 horse U code.What are the date codes on the 906's ? I believe it should have 346 casting # heads.
"Long Live Mopars"
[Re: mike s]
#801879
12/20/10 11:02 PM
12/20/10 11:02 PM
Furyman
Great White North
There are 5 pistons used in 70-71...all new part #'s. 3420214 Used in 70 in the 9.7 350 horse T code C-Body engine. Used in 71 in the 9.5 370 horse U code B/C HP eng.
3420218 70-71 V Code 6 Pak Piston.In 70 Advertised @ 10.5.In 71 advertised @ 10.3
3549426 Used in 70 U code Hp's 9.7 to 1
3549528 71 T code C-Body 440 9.0 to 1
3004539 70-71 Export Only 440 Low Compression
"Long Live Mopars"
