Re: a500 or 200r4 in a Dart
[Re: Supercuda]
#801672
09/15/10 07:26 PM
09/15/10 07:26 PM
Posts: 12,487 Kalispell Mt.
HotRodDave
Kalispell Mt.
Sorry but I build a lot of tranny for a living and just don't see much differance in the price for cores or rebuild kits, and labor is about the same. I do have harder time finding hard parts and even rebuildable cores for the 200r4 and they need a lot more in general, usually more than just a rebuild, the dode trans usually do not have hard part failure. Also see a lot more cases break on the 200r4.
A lot of the aftermarket companies just automatically mark up mopar stuff because they sell less of it than the GM junk.
450 hp with an a-500 is a piece of cake and not a lot over $600 from scratch.
[Re: wireweld]
#801675
09/15/10 10:05 PM
09/15/10 10:05 PM
Posts: 1,062 Amherst,NY
challengermike
Amherst,NY
Are you talking about this trans? http://www.cpttransmission.com/2004R_trans.htmIf so it might hold up to what your running right now,any more i would say no.That trans isnt very far from stock.Go to turbobuick or turbobuicks and ask over there,im pretty sure they will say the same as i did. And no the 904 vb is different. I just noticed that the input is changed and it does have more stuff done to it than i thought.It might hold up ok. Also if you do decied to go with a 2004r vince janis builds really nice ones i think cheaper than art carr.He is highly recommended on turbobuick.
[Re: wireweld]
#801683
09/16/10 09:22 AM
09/16/10 09:22 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
This tranny will be behind a 600 hp 560 tq, ez efi port injected, smallblock 416. Looking at the dimensions, it looks like you would have to redo the tranny hump support regardless of which tranny I use. Someday I hope to build a 1000 hp turbo smallblock, but for now this is what I will run. Here is the 200r4 quote 2400 tranny 575 Wilcap adapter 900 3500 stall converter 350 misc parts Here is the a500 2900 tranny I have a turbo action 10" converter that I would use. This is with a reverse manual vb. Does the a500 use the same vb as the 904? The 200r4 is from Art Carr in California and the a500 is from SMR Transmissions.
can't use a non-lockup 904 converter on a lockup A500...input shaft splines are different.
[Re: wireweld]
#801684
09/16/10 09:48 AM
09/16/10 09:48 AM
Posts: 28,114 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
One of the guys in my club has a 360/a500 in his 75 Dart. the t-bar crossmember was cut and a heavier plate welded in. Other than shortening the driveshaft it dropped right in.
[Re: wireweld]
#801685
09/16/10 11:25 AM
09/16/10 11:25 AM
Posts: 1,061 New Mexico
dmerc
New Mexico
I am wondering since I am not using torsion bars anymore. Does the torsion bar support have to remain in the tunnel? Could I remove it altogether and just strengthen the crossmember more?
Dealing with the torsion bar hump was one of the big issues on my 700R4. Since you arent going to have that it would really simplify things. Either way you go will be quite a bit of work but the first time the thing goes into overdrive you won't be able to wipe the smile off your face. It's that cool.
[Re: wireweld]
#801687
09/16/10 07:57 PM
09/16/10 07:57 PM
HotRodDave
Kalispell Mt.
You can use a non lock up converter with the a-500 if you swap everything in front of the front end of the input shaft with non-lockup parts from a 904.
