Re: brake problem/question [Re: Tinman761] #799555
09/12/10 11:52 PM
09/12/10 11:52 PM
holler when you find it
Re: brake problem/question [Re: RapidRobert] #799556
09/12/10 11:52 PM
09/12/10 11:52 PM
Illinois
Tinman761 Offline OP
Illinois
they have bled out with good streams when i have bled them. thanks for the help, Joe
Re: brake problem/question [Re: Tinman761] #799557
09/13/10 12:03 AM
09/13/10 12:03 AM
Kenosha, Wi
GOLDMYN Offline
GOLDMYN  Offline
Kenosha, Wi
Joe, I'm just going to throw this out there. Could you have a bearing problem, since that is something you also just changed ?. I once had a bad wheel bearing and it got so hot I thought I was burning pancakes? I recently read in one of the Mopar magazine that the green bearings were not for street use and there have been many problems with them
Semper Fi
Re: brake problem/question [Re: GOLDMYN] #799558
09/13/10 12:12 AM
09/13/10 12:12 AM
Illinois
Illinois
well i thought about that also but when i removed the left side it seemed dry except for the seepage from the wheel cylinder, but the right side had some what i thought looked like lube around the shaft, but i thought it was brake fluid leaking from cylinder. as far as the green bearing go, i am hearing about that more and more. i thought those were the hot set up, thanks, joe
Re: brake problem/question [Re: 446acuda] #799559
09/13/10 12:17 AM
09/13/10 12:17 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
By law, all brake fluid has to be compatible
Exactly. Also, all brake fluid is synthetic, so it's a non-issue. DOT 3/4/5.1 is glycol-based, and DOT 5 is silicone-based.
It's Swifty! Swifty, you toad sucker!
Re: brake problem/question [Re: Tinman761] #799560
09/13/10 12:29 AM
09/13/10 12:29 AM
Illinois
Illinois
thanks for all the great suggestions, what are everyones thoughts on the green bearings possibly causing the problems? Joe
Re: brake problem/question [Re: Tinman761] #799561
09/13/10 02:21 AM
09/13/10 02:21 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
You may have a leaky axle seal, but I doubt green wheel bearings caused your brake problems.
Here is everything you ever wanted to know about the "green wheel bearing debate". Note, this is also where the rant in a recent Mopar magazine on green bearings originated:
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Re: brake problem/question [Re: DoctorDiff] #799562
09/13/10 06:51 AM
09/13/10 06:51 AM
Illinois
Illinois
thanks Dr. anyone else?
