My flow bench is a small-capacity SuperFlow 110. Porter Racing Heads' is a Saenz 600 that can pull 28", instead of testing at a much lower pressure and applying conversion factors like I do. These tests of my Hughes CNC-ported Victors and PRH-ported MP Stage VIs were done w/ a 4.375" bore adapter, except my test of the Stage VI was on a 4.25" w/ the head offset to unshroud the valve. I'll retest it on a 4.375" later to see what difference it makes.
None of the exhaust tests used a "flow tube", which I've seen add 20+ cfm at high lifts over not having one attached. Also, I couldn't find an exhaust test for the same Stage VI intake port that Dwayne tested, so I've provided exhaust data from a different cylinder on the same head.
My Victor test #3 cylinder:
Lift -- Int / Exh
.100 --- 73 / 54
.200 -- 155 / 105
.300 -- 224 / 162
.400 -- 282 / 200
.500 -- 317 / 219
.550 -- 329 / 229
.600 -- 343 / 236
.650 -- 346 / 244
.700 -- 350 / 247
PRH Victor test #3 cylinder:
Lift -- Int / Exh
.100 --- 75 / 58
.200 -- 169 / 109
.300 -- 237 / 157
.400 -- 280 / 201
.500 -- 318 / 229
.550 -- 329 / 239
.600 -- 341 / 246
.650 -- 347 / 253
.700 -- 345 / 256
My Stage VI test #1 intake/ #3 exhaust cylinder:
Lift -- Int / Exh
.100 --- 68 / 52
.200 -- 140 / 102
.300 -- 200 / 148
.400 -- 250 / 183
.500 -- 288 / 207
.550 -- 305 / 217
.600 -- 305 / 224
.650 -- 308 / 229
.700 -- 310 / 236
PRH Stage VI test #1 cylinder:
Lift -- Int / Exh
.100 --- 69 / 53
.200 -- 143 / 108
.300 -- 213 / 146
.400 -- 262 / 181
.500 -- 293 / 211
.550 -- 305 / 222
.600 -- 307 / 231
.650 -- 307 / 237
.700 -- 307 / 243
Something else to note: Probably because of the significantly shorter distance between the mounting surface of the head adapter and the blower motor in the bench housing, the exhaust readings taken on a SF-110 can (and do) vary when the cylinder is tested w/ the exhaust port facing the bench and then reversed to face away from the bench. Dwayne saw the same thing w/ his old 110, but says his 600 doesn't show the same behavior.
Both of my tests above were done w/ the heads' exhaust ports facing the bench. When retesting the same Stage VI #3 exhaust after the head was flipped around, it picked up the high-lift by as much as 12 cfm in comparison and put the #s right in line w/ what Dwayne got for the #1 port.
Lift -- 1st / 2nd (turned around)
.500 -- 207 / 211
.550 -- 217 / 223
.600 -- 224 / 233
.650 -- 229 / 240
.700 -- 236 / 248
When I get some time to do additional testing, I'll retest the Victor exhaust port turned around and see how much of the difference between Dwayne's bench and mine is still there.
