Re: Four (4) Headlights on relay's ?........
[Re: Ludington1]
#79783
08/07/08 02:46 AM
08/07/08 02:46 AM
Posts: 6,100 Valencia, España
NachoRT74
Valencia, España
you can use 14 without problem
[Re: Ludington1]
#79785
08/07/08 09:52 AM
08/07/08 09:52 AM
Posts: 3,968 North Riverside IL & Lowell IN
GTXKen
super gas
super gas
One more for this thread... what size of fuse are you guys putting between the alternator stud and the relays?
Thanks, Darren
I'd have to look and get back to you on the size but mine has a fusable link and a fuse
[Re: Ludington1]
#79786
08/07/08 10:07 AM
08/07/08 10:07 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks, Darren
I have a 15a low beam and 20a high beam fuse. Depends on what bulbs you are running. Mine are aftermarket H4's.
If you take the resistance of the low beam filament, then divide 14 (avg voltage while running) by your resistance reading, then multiply it times to (bulbs). You will get the amperage draw for the low beams. I'd go up to the next size to account for any surge. And do the same for the high beam. (high beam filament will be lower resistance than the low beam).
Example
Bulb resistance 1.5ohms (just a random figure) Avg running voltage 14v
14v divided by 1.5ohms = 9.3a x 2 bulbs = 18.6a (i'd run a 20a fuse)
