Re: Voltmeter conversion in 67 B-Body; need graphics help
[Re: JimG]
#797174
06/29/12 08:53 AM
06/29/12 08:53 AM
Posts: 531 Virginia
JimG
Virginia
Rear view.
After I cut the hole in the frame, I used electronics breadboard to fill the gap and mount the voltmeter to. It's strong, a good insulator, and seemed like just the ticket.
I drilled and tapped the potmetal(?) cluster frame for 6-32 and held the breadboard/voltmeter assembly in place with some socket head screws. I ran out of washers, hence the missing one.
[Re: JimG]
#797175
06/29/12 08:56 AM
06/29/12 08:56 AM
Posts: 531 Virginia
JimG
Virginia
The voltmeter tilted upward when it was first mounted, so I slipped two washers behind the breadboard to get the angle right.
It looks a little sleazy, but it works. Long term, I need to do something better than that, I just haven't figured it out yet.
[Re: JimG]
#797176
06/29/12 09:03 AM
06/29/12 09:03 AM
Posts: 905 SD
zrxkawboy
SD
Looks good so far. Thanks for sharing!
It's Swifty! Swifty, you toad sucker!
[Re: JimG]
#2256882
02/20/17 11:05 PM
02/20/17 11:05 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Thanks for the update, Jim. It doesn't look bad. Most would probably never notice sitting in the car. I'd call it a good upgrade. I moved my battery to the trunk with a cutoff switch a few years ago, and thus had to cut the alt. wire feeding the ammeter, and route the alternator power back through the cutoff switch so it actually kills the car. Thus, my ammeter now only shows draw. I'm sure there is a way to get power from the switched side back to the ammeter to make it function properly again, but I feel like if I'm going to get under the dash and do that, I might as well upgrade to a volt meter. (that's what brought me to your thread.)
Thanks again-
