Thermoquad problem #79654
06/25/08 09:21 PM
06/25/08 09:21 PM
Mechanicsburg, PA
LemonTwiist Offline OP
Mechanicsburg, PA
I rebuilt a 4973S 71 Auto Thermoquad for a 340 recently and find that it will not keep running when I start the engine. The only way to keep the engine running is to pump the pedal and all I see is the accelerator pump squirters putting fuel into the intake. any ideas on adjustments or am I missing something?
Re: Thermoquad problem [Re: LemonTwiist] #79655
06/25/08 10:17 PM
06/25/08 10:17 PM
tn
r69cuda Offline
r69cuda  Offline
tn
Did you remeber to put the 2 rubber O rings in?
Re: Thermoquad problem [Re: LemonTwiist] #79656
06/25/08 10:38 PM
06/25/08 10:38 PM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
71 TQ's are unique. I would try to get in touch with Member "Demon Sizzler" here on the board...I believe he is the most familiar with them by far.
If nothing else, It looks like you're only 20 min or so from me...I may be able to swing by and give you a hand with it, if you think it would help.
Let me know.
Re: Thermoquad problem [Re: r69cuda] #79657
06/26/08 06:13 AM
06/26/08 06:13 AM
Mechanicsburg, PA
Mechanicsburg, PA
The zip kit that I got did not come with any rubber o-rings. There are two metal flat washers that I don't know where they go. Would they use washers for the jets? I think I read somewhere that the jets for 71 screwed in. Not pressed in?
Re: Thermoquad problem [Re: 440trk] #79658
06/26/08 06:22 AM
06/26/08 06:22 AM
Mechanicsburg, PA
Mechanicsburg, PA
Thanks I PM'd you
Re: Thermoquad problem [Re: LemonTwiist] #79659
06/27/08 12:48 AM
06/27/08 12:48 AM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
Thanks I PM'd you
Sent ya an e-mail back.
Re: Thermoquad problem [Re: 440trk] #79660
06/27/08 11:19 PM
06/27/08 11:19 PM
Mechanicsburg, PA
Mechanicsburg, PA
OK here's the latest. If I put a rag in the front primary ports the engine runs fine. When I remove the rag the engine dies. Is that a vacuum leak? or is it a problem of too much air being ingested into the carb? Whats the fix?
Re: Thermoquad problem [Re: LemonTwiist] #79661
06/29/08 07:53 AM
06/29/08 07:53 AM
Mechanicsburg, PA
Mechanicsburg, PA
ANYONE Have any ideas?
Re: Thermoquad problem [Re: LemonTwiist] #79662
06/29/08 10:47 AM
06/29/08 10:47 AM
ILL
mark7171 Offline
mark7171  Offline
ILL
it soounds like your choking it for cold starts with a rag.
by chance its close enough to meet the resistance it needs to pull the venturi.
Re: Thermoquad problem [Re: mark7171] #79663
06/29/08 11:54 AM
06/29/08 11:54 AM
Mechanicsburg, PA
Mechanicsburg, PA
I would agree, but there is not mention in any of the sources I have found that tells me how to adjust the idle set screws or the idle circuit. There seems to be not enough vacuum at idle to pull the fuel through the venturi
Re: Thermoquad problem [Re: LemonTwiist] #79664
06/29/08 10:24 PM
06/29/08 10:24 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Usually the mix screws end up about 2.5 turns out.
To set basic idle speed for a firs start up after rebuild I flip the carb over and open the speed screw as much as I can with out uncovering much of the transfer slot, mabey .050 of it.
This will almost always get them idleing where you can adjust them.
Re: Thermoquad problem [Re: HotRodDave] #79665
06/30/08 06:46 AM
06/30/08 06:46 AM
Mechanicsburg, PA
Mechanicsburg, PA
"To set basic idle speed for a firs start up after rebuild I flip the carb over and open the speed screw as much as I can with out uncovering much of the transfer slot, mabey .050 of it.
This will almost always get them idleing where you can adjust them"
OK you lost me. I'm not sure what you are referring to. I have a 71 carb and I don't recall seeing any screw that would affect the transfer slot?
Re: Thermoquad problem [Re: LemonTwiist] #79666
06/30/08 08:46 AM
06/30/08 08:46 AM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
Here is a link to Demon's site, I think that you might have the primaries misadjusted.
How are the shafts?
New base gasket?(use the thick one, not the thin one that most kits come with.)
If you can't figure it out get someone that can.
These are great carbs for a street driven car.
Do a bunch of reading before you start tearing away at it.
http://www.thermoquads.com/page204.html
