Re: 440 vs hemi ? - how do the blocks differ? [Re: JohnRR] #795245
09/08/10 02:24 PM
09/08/10 02:24 PM
East Coast, NJ
fig426 Offline
fig426  Offline
East Coast, NJ
How much does the conversion kit cost?
Chris from New Jersey
Re: 440 vs hemi ? - how do the blocks differ? [Re: fig426] #795246
09/08/10 02:42 PM
09/08/10 02:42 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
over 5k
Re: 440 vs hemi ? - how do the blocks differ? [Re: JohnRR] #795247
09/08/10 02:49 PM
09/08/10 02:49 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
In theory you could run the same piston as a stock 440 but compression will be extremly low.
Re: 440 vs hemi ? - how do the blocks differ? [Re: HotRodDave] #795248
09/08/10 02:53 PM
09/08/10 02:53 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Do you think it would have enough compression to even start? You will have a cylinder with about 90cc more volume, then there is possible piston to valve clearance issues considering valve notches aren't anywhere even remotely in the right place ... but it's a nice thought ...
Re: 440 vs hemi ? - how do the blocks differ? [Re: JohnRR] #795249
09/08/10 08:17 PM
09/08/10 08:17 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I am not recomending doing this, just saying it could be done. My lawn mower runs on something like 5.5 to 1 compression. Normal 440 pistons sit at or below deck, the valve notches in a hemi piston do not genneraly extend below deck, normally only for the really big cam ones. If for some crazy reason you were forced to run that rediculously low compression sort of deal an ideal cam would not have valves opening more than a few thousands at TDC.
Again I would never recomend anyone do this, just saying you could, but it will be a very weak motor.
